Hello Spring Security
This section covers the minimum setup for how to use Spring Security with Spring Boot.spring-doc.cn
The completed application can be found in our samples repository. For your convenience, you can download a minimal Spring Boot + Spring Security application.spring-doc.cn
Updating Dependencies
The only step you need to do is update the dependencies by using Maven or Gradle.spring-doc.cn
Starting Hello Spring Security Boot
You can now run the Spring Boot application by using the Maven Plugin’s run goal. The following example shows how to do so (and the beginning of the output from doing so):spring-doc.cn
Running Spring Boot Application
$ ./mvn spring-boot:run
INFO 23689 --- [  restartedMain] .s.s.UserDetailsServiceAutoConfiguration :
Using generated security password: 8e557245-73e2-4286-969a-ff57fe326336
Spring Boot Auto Configuration
Spring Boot automatically:spring-doc.cn
  • Enables Spring Security’s default configuration, which creates a servlet Filter as a bean named springSecurityFilterChain. This bean is responsible for all the security (protecting the application URLs, validating submitted username and passwords, redirecting to the login form, and so on) within your application.spring-doc.cn
  • Creates a UserDetailsService bean with a username of user and a randomly generated password that is logged to the console.spring-doc.cn
  • Registers the Filter with a bean named springSecurityFilterChain with the Servlet container for every request.spring-doc.cn
Spring Boot is not configuring much, but it does a lot. A summary of the features follows:spring-doc.cn
