Performing Single Logout
Spring Security ships with support for RP- and AP-initiated SAML 2.0 Single Logout.spring-doc.cn
Briefly, there are two use cases Spring Security supports:spring-doc.cn
  • RP-Initiated - Your application has an endpoint that, when POSTed to, will logout the user and send a saml2:LogoutRequest to the asserting party. Thereafter, the asserting party will send back a saml2:LogoutResponse and allow your application to respondspring-doc.cn
  • AP-Initiated - Your application has an endpoint that will receive a saml2:LogoutRequest from the asserting party. Your application will complete its logout at that point and then send a saml2:LogoutResponse to the asserting party.spring-doc.cn
In the AP-Initiated scenario, any local redirection that your application would do post-logout is rendered moot. Once your application sends a saml2:LogoutResponse, it no longer has control of the browser.
Minimal Configuration for Single Logout
To use Spring Security’s SAML 2.0 Single Logout feature, you will need the following things:spring-doc.cn
  • First, the asserting party must support SAML 2.0 Single Logoutspring-doc.cn
  • Second, the asserting party should be configured to sign and POST saml2:LogoutRequest s and saml2:LogoutResponse s your application’s /logout/saml2/slo endpointspring-doc.cn
  • Third, your application must have a PKCS#8 private key and X.509 certificate for signing saml2:LogoutRequest s and saml2:LogoutResponse sspring-doc.cn
You can begin from the initial minimal example and add the following configuration:spring-doc.cn
@Value("${private.key}") RSAPrivateKey key;
@Value("${public.certificate}") X509Certificate certificate;
RelyingPartyRegistrationRepository registrations() {
    Saml2X509Credential credential = Saml2X509Credential.signing(key, certificate);
    RelyingPartyRegistration registration = RelyingPartyRegistrations
            .fromMetadataLocation("https://ap.example.org/metadata")
            .registrationId("id")
            .singleLogoutServiceLocation("{baseUrl}/logout/saml2/slo")
            .signingX509Credentials((signing) -> signing.add(credential)) (1)
    return new InMemoryRelyingPartyRegistrationRepository(registration);
SecurityFilterChain web(HttpSecurity http, RelyingPartyRegistrationRepository registrations) throws Exception {
    http
        .authorizeHttpRequests((authorize) -> authorize
            .anyRequest().authenticated()
        .saml2Login(withDefaults())
        .saml2Logout(withDefaults()); (2)
    return http.build();
1 - First, add your signing key to the RelyingPartyRegistration instance or to multiple instances
2 - Second, indicate that your application wants to use SAML SLO to logout the end user
Runtime Expectations
Given the above configuration any logged in user can send a POST /logout to your application to perform RP-initiated SLO. Your application will then do the following:spring-doc.cn
  1. Logout the user and invalidate the sessionspring-doc.cn
  2. Use a Saml2LogoutRequestResolver to create, sign, and serialize a <saml2:LogoutRequest> based on the RelyingPartyRegistration associated with the currently logged-in user.spring-doc.cn
  3. Send a redirect or post to the asserting party based on the RelyingPartyRegistrationspring-doc.cn
  4. Deserialize, verify, and process the <saml2:LogoutResponse> sent by the asserting partyspring-doc.cn
  5. Redirect to any configured successful logout endpointspring-doc.cn
Also, your application can participate in an AP-initiated logout when the asserting party sends a <saml2:LogoutRequest> to /logout/saml2/slo:spring-doc.cn
  1. Use a Saml2LogoutRequestHandler to deserialize, verify, and process the <saml2:LogoutRequest> sent by the asserting partyspring-doc.cn
  2. Logout the user and invalidate the sessionspring-doc.cn
  3. Create, sign, and serialize a <saml2:LogoutResponse> based on the RelyingPartyRegistration associated with the just logged-out userspring-doc.cn
  4. Send a redirect or post to the asserting party based on the RelyingPartyRegistrationspring-doc.cn
Adding saml2Logout adds the capability for logout to the service provider. Because it is an optional capability, you need to enable it for each individual RelyingPartyRegistration. You can do this by setting the RelyingPartyRegistration.Builder#singleLogoutServiceLocation property.
Configuring Logout Endpoints
There are three behaviors that can be triggered by different endpoints:spring-doc.cn
  • RP-initiated logout, which allows an authenticated user to POST and trigger the logout process by sending the asserting party a <saml2:LogoutRequest>spring-doc.cn
  • AP-initiated logout, which allows an asserting party to send a <saml2:LogoutRequest> to the applicationspring-doc.cn
  • AP logout response, which allows an asserting party to send a <saml2:LogoutResponse> in response to the RP-initiated <saml2:LogoutRequest>spring-doc.cn
The first is triggered by performing normal POST /logout when the principal is of type Saml2AuthenticatedPrincipal.spring-doc.cn
The second is triggered by POSTing to the /logout/saml2/slo endpoint with a SAMLRequest signed by the asserting party.spring-doc.cn
The third is triggered by POSTing to the /logout/saml2/slo endpoint with a SAMLResponse signed by the asserting party.spring-doc.cn
Because the user is already logged in or the original Logout Request is known, the registrationId is already known. For this reason, {registrationId} is not part of these URLs by default.spring-doc.cn
This URL is customizable in the DSL.spring-doc.cn
For example, if you are migrating your existing relying party over to Spring Security, your asserting party may already be pointing to GET /SLOService.saml2. To reduce changes in configuration for the asserting party, you can configure the filter in the DSL like so:spring-doc.cn
http
    .saml2Logout((saml2) -> saml2
        .logoutRequest((request) -> request.logoutUrl("/SLOService.saml2"))
        .logoutResponse((response) -> response.logoutUrl("/SLOService.saml2"))
You should also configure these endpoints in your RelyingPartyRegistration.spring-doc.cn
Customizing <saml2:LogoutRequest> Resolution
It’s common to need to set other values in the <saml2:LogoutRequest> than the defaults that Spring Security provides.spring-doc.cn
By default, Spring Security will issue a <saml2:LogoutRequest> and supply:spring-doc.cn
  • The Destination attribute - from RelyingPartyRegistration#getAssertingPartyDetails#getSingleLogoutServiceLocationspring-doc.cn
  • The ID attribute - a GUIDspring-doc.cn
  • The <Issuer> element - from RelyingPartyRegistration#getEntityIdspring-doc.cn
  • The <NameID> element - from Authentication#getNamespring-doc.cn
To add other values, you can use delegation, like so:spring-doc.cn
Saml2LogoutRequestResolver logoutRequestResolver(RelyingPartyRegistrationResolver registrationResolver) {
	OpenSaml4LogoutRequestResolver logoutRequestResolver
			new OpenSaml4LogoutRequestResolver(registrationResolver);
	logoutRequestResolver.setParametersConsumer((parameters) -> {
		String name = ((Saml2AuthenticatedPrincipal) parameters.getAuthentication().getPrincipal()).getFirstAttribute("CustomAttribute");
		String format = "urn:oasis:names:tc:SAML:2.0:nameid-format:transient";
		LogoutRequest logoutRequest = parameters.getLogoutRequest();
		NameID nameId = logoutRequest.getNameID();
		nameId.setValue(name);
		nameId.setFormat(format);
	return logoutRequestResolver;
Then, you can supply your custom Saml2LogoutRequestResolver in the DSL as follows:spring-doc.cn
http
            .logoutRequestResolver(this.logoutRequestResolver)
Customizing <saml2:LogoutResponse> Resolution
It’s common to need to set other values in the <saml2:LogoutResponse> than the defaults that Spring Security provides.spring-doc.cn
By default, Spring Security will issue a <saml2:LogoutResponse> and supply:spring-doc.cn
  • The Destination attribute - from RelyingPartyRegistration#getAssertingPartyDetails#getSingleLogoutServiceResponseLocationspring-doc.cn
  • The <Status> element - SUCCESSspring-doc.cn
public Saml2LogoutResponseResolver logoutResponseResolver(RelyingPartyRegistrationResolver registrationResolver) {
	OpenSaml4LogoutResponseResolver logoutRequestResolver =
			new OpenSaml3LogoutResponseResolver(relyingPartyRegistrationResolver);
		if (checkOtherPrevailingConditions(parameters.getRequest())) {
			parameters.getLogoutRequest().getStatus().getStatusCode().setCode(StatusCode.PARTIAL_LOGOUT);
Then, you can supply your custom Saml2LogoutResponseResolver in the DSL as follows:spring-doc.cn
http
Customizing <saml2:LogoutRequest> Authentication
To customize validation, you can implement your own Saml2LogoutRequestValidator. At this point, the validation is minimal, so you may be able to first delegate to the default Saml2LogoutRequestValidator like so:spring-doc.cn
@Component
public class MyOpenSamlLogoutRequestValidator implements Saml2LogoutRequestValidator {
	private final Saml2LogoutRequestValidator delegate = new OpenSamlLogoutRequestValidator();
    public Saml2LogoutRequestValidator logout(Saml2LogoutRequestValidatorParameters parameters) {
		 // verify signature, issuer, destination, and principal name
		Saml2LogoutValidatorResult result = delegate.authenticate(authentication);
		LogoutRequest logoutRequest = // ... parse using OpenSAML
        // perform custom validation
Then, you can supply your custom Saml2LogoutRequestValidator in the DSL as follows:spring-doc.cn
http
            .logoutRequestAuthenticator(myOpenSamlLogoutRequestAuthenticator)
Customizing <saml2:LogoutResponse> Authentication
To customize validation, you can implement your own Saml2LogoutResponseValidator. At this point, the validation is minimal, so you may be able to first delegate to the default Saml2LogoutResponseValidator like so:spring-doc.cn
@Component
public class MyOpenSamlLogoutResponseValidator implements Saml2LogoutResponseValidator {
	private final Saml2LogoutResponseValidator delegate = new OpenSamlLogoutResponseValidator();
    public Saml2LogoutValidatorResult logout(Saml2LogoutResponseValidatorParameters parameters) {
		// verify signature, issuer, destination, and status
		Saml2LogoutValidatorResult result = delegate.authenticate(parameters);
		LogoutResponse logoutResponse = // ... parse using OpenSAML
Then, you can supply your custom Saml2LogoutResponseValidator in the DSL as follows:spring-doc.cn
http
            .logoutResponseAuthenticator(myOpenSamlLogoutResponseAuthenticator)
Customizing <saml2:LogoutRequest> storage
When your application sends a <saml2:LogoutRequest>, the value is stored in the session so that the RelayState parameter and the InResponseTo attribute in the <saml2:LogoutResponse> can be verified.spring-doc.cn
If you want to store logout requests in some place other than the session, you can supply your custom implementation in the DSL, like so:spring-doc.cn
http
            .logoutRequestRepository(myCustomLogoutRequestRepository)
