CORS
Spring Framework provides first class support for CORS. CORS must be processed before Spring Security, because the pre-flight request does not contain any cookies (that is, the JSESSIONID). If the request does not contain any cookies and Spring Security is first, the request determines that the user is not authenticated (since there are no cookies in the request) and rejects it.spring-doc.cn
The easiest way to ensure that CORS is handled first is to use the CorsFilter. Users can integrate the CorsFilter with Spring Security by providing a CorsConfigurationSource that uses the following:spring-doc.cn
@EnableWebSecurity
public class WebSecurityConfig {
		http
			// by default uses a Bean by the name of corsConfigurationSource
			.cors(withDefaults())
		return http.build();
	CorsConfigurationSource corsConfigurationSource() {
		CorsConfiguration configuration = new CorsConfiguration();
		configuration.setAllowedOrigins(Arrays.asList("https://example.com"));
		configuration.setAllowedMethods(Arrays.asList("GET","POST"));
		UrlBasedCorsConfigurationSource source = new UrlBasedCorsConfigurationSource();
		source.registerCorsConfiguration("/**", configuration);
		return source;
@EnableWebSecurity
open class WebSecurityConfig {
        http {
            cors { }
        return http.build()
    open fun corsConfigurationSource(): CorsConfigurationSource {
        val configuration = CorsConfiguration()
        configuration.allowedOrigins = listOf("https://example.com")
        configuration.allowedMethods = listOf("GET", "POST")
        val source = UrlBasedCorsConfigurationSource()
        return source
The following listing does the same thing in XML:spring-doc.cn
<http>
	<cors configuration-source-ref="corsSource"/>
</http>
<b:bean id="corsSource" class="org.springframework.web.cors.UrlBasedCorsConfigurationSource">
</b:bean>
If you use Spring MVC’s CORS support, you can omit specifying the CorsConfigurationSource and Spring Security uses the CORS configuration provided to Spring MVC:spring-doc.cn
@EnableWebSecurity
		http
			// if Spring MVC is on classpath and no CorsConfigurationSource is provided,
			// Spring Security will use CORS configuration provided to Spring MVC
@EnableWebSecurity
        http {
            cors { }
        return http.build()
<http>
	<!-- Default to Spring MVC's CORS configuration -->
	<cors />
</http>
