此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 Spring Framework 6.1.10
默认情况下,未添加注释的日期和时间字段将从 字符串。如果您愿意,可以通过以下方式更改此设置 定义自己的全局格式。@DateTimeFormatDateFormat.SHORT
为此,请确保 Spring 没有注册默认格式化程序。相反,请注册 在以下帮助下手动格式化程序:
  • org.springframework.format.datetime.standard.DateTimeFormatterRegistrar
  • org.springframework.format.datetime.DateFormatterRegistrar
例如,以下配置注册全局格式:yyyyMMdd
  • Java
  • Kotlin
  • Xml
public class ApplicationConfiguration {
	public FormattingConversionService conversionService() {
		// Use the DefaultFormattingConversionService but do not register defaults
		DefaultFormattingConversionService conversionService =
				new DefaultFormattingConversionService(false);
		// Ensure @NumberFormat is still supported
		conversionService.addFormatterForFieldAnnotation(
				new NumberFormatAnnotationFormatterFactory());
		// Register JSR-310 date conversion with a specific global format
		DateTimeFormatterRegistrar dateTimeRegistrar = new DateTimeFormatterRegistrar();
		dateTimeRegistrar.setDateFormatter(DateTimeFormatter.ofPattern("yyyyMMdd"));
		dateTimeRegistrar.registerFormatters(conversionService);
		// Register date conversion with a specific global format
		DateFormatterRegistrar dateRegistrar = new DateFormatterRegistrar();
		dateRegistrar.setFormatter(new DateFormatter("yyyyMMdd"));
		dateRegistrar.registerFormatters(conversionService);
		return conversionService;
	fun conversionService(): FormattingConversionService {
		return DefaultFormattingConversionService(false).apply {
			addFormatterForFieldAnnotation(NumberFormatAnnotationFormatterFactory())
			val dateTimeRegistrar = DateTimeFormatterRegistrar()
			dateTimeRegistrar.registerFormatters(this)
			val dateRegistrar = DateFormatterRegistrar()
			dateRegistrar.setFormatter(DateFormatter("yyyyMMdd"))
			dateRegistrar.registerFormatters(this)
<bean id="conversionService" class="org.springframework.format.support.FormattingConversionServiceFactoryBean">
	<property name="registerDefaultFormatters" value="false" />
	<property name="formatters">
		<set>
			<bean class="org.springframework.format.number.NumberFormatAnnotationFormatterFactory" />
		</set>
	</property>
	<property name="formatterRegistrars">
		<set>
			<bean class="org.springframework.format.datetime.standard.DateTimeFormatterRegistrar">
				<property name="dateFormatter">
					<bean class="org.springframework.format.datetime.standard.DateTimeFormatterFactoryBean">
						<property name="pattern" value="yyyyMMdd"/>
					</bean>
				</property>
			</bean>
		</set>
	</property>
</bean>
请注意,在 Web 中配置日期和时间格式时需要注意额外的注意事项 应用。请参阅 WebMVC 转换和格式化WebFlux 转换和格式化
