7. Global Filters
The GlobalFilter interface has the same signature as GatewayFilter. These are special filters that are conditionally applied to all routes.
This interface and its usage are subject to change in future milestone releases.
7.1. Combined Global Filter and GatewayFilter Ordering
When a request matches a route, the filtering web handler adds all instances of GlobalFilter and all route-specific instances of GatewayFilter to a filter chain. This combined filter chain is sorted by the org.springframework.core.Ordered interface, which you can set by implementing the getOrder() method.
As Spring Cloud Gateway distinguishes between “pre” and “post” phases for filter logic execution (see How it Works), the filter with the highest precedence is the first in the “pre”-phase and the last in the “post”-phase.
The following listing configures a filter chain:
Example 59. ExampleConfiguration.java
public GlobalFilter customFilter() {
    return new CustomGlobalFilter();
public class CustomGlobalFilter implements GlobalFilter, Ordered {
    public Mono<Void> filter(ServerWebExchange exchange, GatewayFilterChain chain) {
        log.info("custom global filter");
        return chain.filter(exchange);
    public int getOrder() {
        return -1;
7.2. Forward Routing Filter
The ForwardRoutingFilter looks for a URI in the exchange attribute ServerWebExchangeUtils.GATEWAY_REQUEST_URL_ATTR. If the URL has a forward scheme (such as forward:///localendpoint), it uses the Spring DispatcherHandler to handle the request. The path part of the request URL is overridden with the path in the forward URL. The unmodified original URL is appended to the list in the ServerWebExchangeUtils.GATEWAY_ORIGINAL_REQUEST_URL_ATTR attribute.
7.3. The ReactiveLoadBalancerClientFilter
The ReactiveLoadBalancerClientFilter looks for a URI in the exchange attribute named ServerWebExchangeUtils.GATEWAY_REQUEST_URL_ATTR. If the URL has a lb scheme (such as lb://myservice), it uses the Spring Cloud ReactorLoadBalancer to resolve the name (myservice in this example) to an actual host and port and replaces the URI in the same attribute. The unmodified original URL is appended to the list in the ServerWebExchangeUtils.GATEWAY_ORIGINAL_REQUEST_URL_ATTR attribute. The filter also looks in the ServerWebExchangeUtils.GATEWAY_SCHEME_PREFIX_ATTR attribute to see if it equals lb. If so, the same rules apply. The following listing configures a ReactiveLoadBalancerClientFilter:
Example 60. application.yml
spring:
  cloud:
    gateway:
      routes:
      - id: myRoute
        uri: lb://service
        predicates:
        - Path=/service/**
By default, when a service instance cannot be found by the ReactorLoadBalancer, a 503 is returned. You can configure the gateway to return a 404 by setting spring.cloud.gateway.loadbalancer.use404=true.
The isSecure value of the ServiceInstance returned from the ReactiveLoadBalancerClientFilter overrides the scheme specified in the request made to the Gateway. For example, if the request comes into the Gateway over HTTPS but the ServiceInstance indicates it is not secure, the downstream request is made over HTTP. The opposite situation can also apply. However, if GATEWAY_SCHEME_PREFIX_ATTR is specified for the route in the Gateway configuration, the prefix is stripped and the resulting scheme from the route URL overrides the ServiceInstance configuration.
Gateway supports all the LoadBalancer features. You can read more about them in the Spring Cloud Commons documentation.
7.4. The Netty Routing Filter
The Netty routing filter runs if the URL located in the ServerWebExchangeUtils.GATEWAY_REQUEST_URL_ATTR exchange attribute has a http or https scheme. It uses the Netty HttpClient to make the downstream proxy request. The response is put in the ServerWebExchangeUtils.CLIENT_RESPONSE_ATTR exchange attribute for use in a later filter. (There is also an experimental WebClientHttpRoutingFilter that performs the same function but does not require Netty.)
7.5. The Netty Write Response Filter
The NettyWriteResponseFilter runs if there is a Netty HttpClientResponse in the ServerWebExchangeUtils.CLIENT_RESPONSE_ATTR exchange attribute. It runs after all other filters have completed and writes the proxy response back to the gateway client response. (There is also an experimental WebClientWriteResponseFilter that performs the same function but does not require Netty.)
7.6. The RouteToRequestUrl Filter
If there is a Route object in the ServerWebExchangeUtils.GATEWAY_ROUTE_ATTR exchange attribute, the RouteToRequestUrlFilter runs. It creates a new URI, based off of the request URI but updated with the URI attribute of the Route object. The new URI is placed in the ServerWebExchangeUtils.GATEWAY_REQUEST_URL_ATTR exchange attribute.
If the URI has a scheme prefix, such as lb:ws://serviceid, the lb scheme is stripped from the URI and placed in the ServerWebExchangeUtils.GATEWAY_SCHEME_PREFIX_ATTR for use later in the filter chain.
7.7. The Websocket Routing Filter
If the URL located in the ServerWebExchangeUtils.GATEWAY_REQUEST_URL_ATTR exchange attribute has a ws or wss scheme, the websocket routing filter runs. It uses the Spring WebSocket infrastructure to forward the websocket request downstream.
You can load-balance websockets by prefixing the URI with lb, such as lb:ws://serviceid.
If you use SockJS as a fallback over normal HTTP, you should configure a normal HTTP route as well as the websocket Route.
The following listing configures a websocket routing filter:
Example 61. application.yml
spring:
  cloud:
    gateway:
      routes:
      # SockJS route
      - id: websocket_sockjs_route
        uri: http://localhost:3001
        predicates:
        - Path=/websocket/info/**
      # Normal Websocket route
      - id: websocket_route
        uri: ws://localhost:3001
        predicates:
        - Path=/websocket/**
7.8. The Gateway Metrics Filter
To enable gateway metrics, add spring-boot-starter-actuator as a project dependency. Then, by default, the gateway metrics filter runs as long as the property spring.cloud.gateway.metrics.enabled is not set to false. This filter adds a timer metric named spring.cloud.gateway.requests with the following tags:
In addition, through the property spring.cloud.gateway.metrics.tags.path.enabled (by default, set to false), you can activate an extra metric with the tag:
These metrics are then available to be scraped from /actuator/metrics/spring.cloud.gateway.requests and can be easily integrated with Prometheus to create a Grafana dashboard.
To enable the prometheus endpoint, add micrometer-registry-prometheus as a project dependency.
7.9. Marking An Exchange As Routed
After the gateway has routed a ServerWebExchange, it marks that exchange as “routed” by adding gatewayAlreadyRouted to the exchange attributes. Once a request has been marked as routed, other routing filters will not route the request again, essentially skipping the filter. There are convenience methods that you can use to mark an exchange as routed or check if an exchange has already been routed.
  • ServerWebExchangeUtils.isAlreadyRouted takes a ServerWebExchange object and checks if it has been “routed”.
  • ServerWebExchangeUtils.setAlreadyRouted takes a ServerWebExchange object and marks it as “routed”.
APP信息
