10. Configuration
Configuration for Spring Cloud Gateway is driven by a collection of RouteDefinitionLocator instances. The following listing shows the definition of the RouteDefinitionLocator interface:
Example 66. RouteDefinitionLocator.java
public interface RouteDefinitionLocator {
    Flux<RouteDefinition> getRouteDefinitions();
By default, a PropertiesRouteDefinitionLocator loads properties by using Spring Boot’s @ConfigurationProperties mechanism.
The earlier configuration examples all use a shortcut notation that uses positional arguments rather than named ones. The following two examples are equivalent:
Example 67. application.yml
spring:
  cloud:
    gateway:
      routes:
      - id: setstatus_route
        uri: https://example.org
        filters:
        - name: SetStatus
          args:
            status: 401
      - id: setstatusshortcut_route
        filters:
        - SetStatus=401
For some usages of the gateway, properties are adequate, but some production use cases benefit from loading configuration from an external source, such as a database. Future milestone versions will have RouteDefinitionLocator implementations based off of Spring Data Repositories, such as Redis, MongoDB, and Cassandra.
10.1. RouteDefinition Metrics
To enable RouteDefinition metrics, add spring-boot-starter-actuator as a project dependency. Then, by default, the metrics will be available as long as the property spring.cloud.gateway.metrics.enabled is set to true. A gauge metric named spring.cloud.gateway.routes.count will be added, whose value is the number of RouteDefinitions. This metric will be available from /actuator/metrics/spring.cloud.gateway.routes.count.
APP信息
