15. Reactor Netty Access Logs
To enable Reactor Netty access logs, set -Dreactor.netty.http.server.accessLogEnabled=true
It must be a Java System Property, not a Spring Boot property. |
You can configure the logging system to have a separate access log file. The following example creates a Logback configuration:
Example 71. logback.xml
<appender name="accessLog" class="ch.qos.logback.core.FileAppender">
<file>access_log.log</file>
<encoder>
<pattern>%msg%n</pattern>
</encoder>
</appender>
<appender name="async" class="ch.qos.logback.classic.AsyncAppender">
<appender-ref ref="accessLog" />
</appender>
<logger name="reactor.netty.http.server.AccessLog" level="INFO" additivity="false">
<appender-ref ref="async"/>
</logger>
