5. Route Predicate Factories
Spring Cloud Gateway matches routes as part of the Spring WebFlux HandlerMapping infrastructure. Spring Cloud Gateway includes many built-in route predicate factories. All of these predicates match on different attributes of the HTTP request. You can combine multiple route predicate factories with logical and statements.spring-doc.cn
5.1. The After Route Predicate Factory
The After route predicate factory takes one parameter, a datetime (which is a java ZonedDateTime). This predicate matches requests that happen after the specified datetime. The following example configures an after route predicate:spring-doc.cn
Example 1. application.yml
spring:
  cloud:
    gateway:
      routes:
      - id: after_route
        uri: https://example.org
        predicates:
        - After=2017-01-20T17:42:47.789-07:00[America/Denver]
This route matches any request made after Jan 20, 2017 17:42 Mountain Time (Denver).spring-doc.cn
5.2. The Before Route Predicate Factory
The Before route predicate factory takes one parameter, a datetime (which is a java ZonedDateTime). This predicate matches requests that happen before the specified datetime. The following example configures a before route predicate:spring-doc.cn
Example 2. application.yml
spring:
  cloud:
    gateway:
      routes:
      - id: before_route
        predicates:
        - Before=2017-01-20T17:42:47.789-07:00[America/Denver]
This route matches any request made before Jan 20, 2017 17:42 Mountain Time (Denver).spring-doc.cn
5.3. The Between Route Predicate Factory
The Between route predicate factory takes two parameters, datetime1 and datetime2 which are java ZonedDateTime objects. This predicate matches requests that happen after datetime1 and before datetime2. The datetime2 parameter must be after datetime1. The following example configures a between route predicate:spring-doc.cn
Example 3. application.yml
spring:
  cloud:
    gateway:
      routes:
      - id: between_route
        predicates:
        - Between=2017-01-20T17:42:47.789-07:00[America/Denver], 2017-01-21T17:42:47.789-07:00[America/Denver]
This route matches any request made after Jan 20, 2017 17:42 Mountain Time (Denver) and before Jan 21, 2017 17:42 Mountain Time (Denver). This could be useful for maintenance windows.spring-doc.cn
The Cookie route predicate factory takes two parameters, the cookie name and a regexp (which is a Java regular expression). This predicate matches cookies that have the given name and whose values match the regular expression. The following example configures a cookie route predicate factory:spring-doc.cn
Example 4. application.yml
spring:
  cloud:
    gateway:
      routes:
      - id: cookie_route
        predicates:
        - Cookie=chocolate, ch.p
This route matches requests that have a cookie named chocolate whose value matches the ch.p regular expression.spring-doc.cn
5.5. The Header Route Predicate Factory
The Header route predicate factory takes two parameters, the header and a regexp (which is a Java regular expression). This predicate matches with a header that has the given name whose value matches the regular expression. The following example configures a header route predicate:spring-doc.cn
Example 5. application.yml
spring:
  cloud:
    gateway:
      routes:
      - id: header_route
        predicates:
        - Header=X-Request-Id, \d+
This route matches if the request has a header named X-Request-Id whose value matches the \d+ regular expression (that is, it has a value of one or more digits).spring-doc.cn
5.6. The Host Route Predicate Factory
The Host route predicate factory takes one parameter: a list of host name patterns. The pattern is an Ant-style pattern with . as the separator. This predicates matches the Host header that matches the pattern. The following example configures a host route predicate:spring-doc.cn
Example 6. application.yml
spring:
  cloud:
    gateway:
      routes:
      - id: host_route
        predicates:
        - Host=**.somehost.org,**.anotherhost.org
URI template variables (such as {sub}.myhost.org) are supported as well.spring-doc.cn
This route matches if the request has a Host header with a value of www.somehost.org or beta.somehost.org or www.anotherhost.org.spring-doc.cn
This predicate extracts the URI template variables (such as sub, defined in the preceding example) as a map of names and values and places it in the ServerWebExchange.getAttributes() with a key defined in ServerWebExchangeUtils.URI_TEMPLATE_VARIABLES_ATTRIBUTE. Those values are then available for use by GatewayFilter factoriesspring-doc.cn
5.7. The Method Route Predicate Factory
The Method Route Predicate Factory takes a methods argument which is one or more parameters: the HTTP methods to match. The following example configures a method route predicate:spring-doc.cn
Example 7. application.yml
spring:
  cloud:
    gateway:
      routes:
      - id: method_route
        predicates:
        - Method=GET,POST
This route matches if the request method was a GET or a POST.spring-doc.cn
5.8. The Path Route Predicate Factory
The Path Route Predicate Factory takes two parameters: a list of Spring PathMatcher patterns and an optional flag called matchTrailingSlash (defaults to true). The following example configures a path route predicate:spring-doc.cn
Example 8. application.yml
spring:
  cloud:
    gateway:
      routes:
      - id: path_route
        predicates:
        - Path=/red/{segment},/blue/{segment}
This route matches if the request path was, for example: /red/1 or /red/1/ or /red/blue or /blue/green.spring-doc.cn
If matchTrailingSlash is set to false, then request path /red/1/ will not be matched.spring-doc.cn
This predicate extracts the URI template variables (such as segment, defined in the preceding example) as a map of names and values and places it in the ServerWebExchange.getAttributes() with a key defined in ServerWebExchangeUtils.URI_TEMPLATE_VARIABLES_ATTRIBUTE. Those values are then available for use by GatewayFilter factoriesspring-doc.cn
A utility method (called get) is available to make access to these variables easier. The following example shows how to use the get method:spring-doc.cn
Map<String, String> uriVariables = ServerWebExchangeUtils.getUriTemplateVariables(exchange);
String segment = uriVariables.get("segment");
5.9. The Query Route Predicate Factory
The Query route predicate factory takes two parameters: a required param and an optional regexp (which is a Java regular expression). The following example configures a query route predicate:spring-doc.cn
Example 9. application.yml
spring:
  cloud:
    gateway:
      routes:
      - id: query_route
        predicates:
        - Query=green
The preceding route matches if the request contained a green query parameter.spring-doc.cn
application.yml
spring:
  cloud:
    gateway:
      routes:
      - id: query_route
        predicates:
        - Query=red, gree.
The preceding route matches if the request contained a red query parameter whose value matched the gree. regexp, so green and greet would match.spring-doc.cn
5.10. The RemoteAddr Route Predicate Factory
The RemoteAddr route predicate factory takes a list (min size 1) of sources, which are CIDR-notation (IPv4 or IPv6) strings, such as 192.168.0.1/16 (where 192.168.0.1 is an IP address and 16 is a subnet mask). The following example configures a RemoteAddr route predicate:spring-doc.cn
Example 10. application.yml
spring:
  cloud:
    gateway:
      routes:
      - id: remoteaddr_route
        predicates:
        - RemoteAddr=192.168.1.1/24
This route matches if the remote address of the request was, for example, 192.168.1.10.spring-doc.cn
5.10.1. Modifying the Way Remote Addresses Are Resolved
By default, the RemoteAddr route predicate factory uses the remote address from the incoming request. This may not match the actual client IP address if Spring Cloud Gateway sits behind a proxy layer.spring-doc.cn
You can customize the way that the remote address is resolved by setting a custom RemoteAddressResolver. Spring Cloud Gateway comes with one non-default remote address resolver that is based off of the X-Forwarded-For header, XForwardedRemoteAddressResolver.spring-doc.cn
XForwardedRemoteAddressResolver has two static constructor methods, which take different approaches to security:spring-doc.cn
  • XForwardedRemoteAddressResolver::trustAll returns a RemoteAddressResolver that always takes the first IP address found in the X-Forwarded-For header. This approach is vulnerable to spoofing, as a malicious client could set an initial value for the X-Forwarded-For, which would be accepted by the resolver.spring-doc.cn
  • XForwardedRemoteAddressResolver::maxTrustedIndex takes an index that correlates to the number of trusted infrastructure running in front of Spring Cloud Gateway. If Spring Cloud Gateway is, for example only accessible through HAProxy, then a value of 1 should be used. If two hops of trusted infrastructure are required before Spring Cloud Gateway is accessible, then a value of 2 should be used.spring-doc.cn
Consider the following header value:spring-doc.cn
X-Forwarded-For: 0.0.0.1, 0.0.0.2, 0.0.0.3
The following maxTrustedIndex values yield the following remote addresses:spring-doc.cn
maxTrustedIndex result
[Integer.MIN_VALUE,0]spring-doc.cn
(invalid, IllegalArgumentException during initialization)spring-doc.cn
1spring-doc.cn
0.0.0.3spring-doc.cn
2spring-doc.cn
0.0.0.2spring-doc.cn
3spring-doc.cn
0.0.0.1spring-doc.cn
[4, Integer.MAX_VALUE]spring-doc.cn
The following example shows how to achieve the same configuration with Java:spring-doc.cn
Example 11. GatewayConfig.java
RemoteAddressResolver resolver = XForwardedRemoteAddressResolver
    .maxTrustedIndex(1);
.route("direct-route",
    r -> r.remoteAddr("10.1.1.1", "10.10.1.1/24")
        .uri("https://downstream1")
.route("proxied-route",
    r -> r.remoteAddr(resolver, "10.10.1.1", "10.10.1.1/24")
        .uri("https://downstream2")
5.11. The Weight Route Predicate Factory
The Weight route predicate factory takes two arguments: group and weight (an int). The weights are calculated per group. The following example configures a weight route predicate:spring-doc.cn
Example 12. application.yml
spring:
  cloud:
    gateway:
      routes:
      - id: weight_high
        uri: https://weighthigh.org
        predicates:
        - Weight=group1, 8
      - id: weight_low
        uri: https://weightlow.org
        predicates:
        - Weight=group1, 2
This route would forward ~80% of traffic to weighthigh.org and ~20% of traffic to weighlow.orgspring-doc.cn
5.12. The XForwarded Remote Addr Route Predicate Factory
The XForwarded Remote Addr route predicate factory takes a list (min size 1) of sources, which are CIDR-notation (IPv4 or IPv6) strings, such as 192.168.0.1/16 (where 192.168.0.1 is an IP address and 16 is a subnet mask).spring-doc.cn
This route predicate allows requests to be filtered based on the X-Forwarded-For HTTP header.spring-doc.cn
This can be used with reverse proxies such as load balancers or web application firewalls where the request should only be allowed if it comes from a trusted list of IP addresses used by those reverse proxies.spring-doc.cn
The following example configures a XForwardedRemoteAddr route predicate:spring-doc.cn
Example 13. application.yml
spring:
  cloud:
    gateway:
      routes:
      - id: xforwarded_remoteaddr_route
        predicates:
        - XForwardedRemoteAddr=192.168.1.1/24
This route matches if the X-Forwarded-For header contains, for example, 192.168.1.10.spring-doc.cn
