20. Building a Simple Gateway by Using Spring MVC or Webflux
The following describes an alternative style gateway. None of the prior documentation applies to what follows.
Spring Cloud Gateway provides a utility object called ProxyExchange. You can use it inside a regular Spring web handler as a method parameter. It supports basic downstream HTTP exchanges through methods that mirror the HTTP verbs. With MVC, it also supports forwarding to a local handler through the forward() method. To use the ProxyExchange, include the right module in your classpath (either spring-cloud-gateway-mvc or spring-cloud-gateway-webflux).
The following MVC example proxies a request to /test downstream to a remote server:
@RestController
@SpringBootApplication
public class GatewaySampleApplication {
    @Value("${remote.home}")
    private URI home;
    @GetMapping("/test")
    public ResponseEntity<?> proxy(ProxyExchange<byte[]> proxy) throws Exception {
        return proxy.uri(home.toString() + "/image/png").get();
The following example does the same thing with Webflux:
@RestController
    private URI home;
    public Mono<ResponseEntity<?>> proxy(ProxyExchange<byte[]> proxy) throws Exception {
Convenience methods on the ProxyExchange enable the handler method to discover and enhance the URI path of the incoming request. For example, you might want to extract the trailing elements of a path to pass them downstream:
@GetMapping("/proxy/path/**")
public ResponseEntity<?> proxyPath(ProxyExchange<byte[]> proxy) throws Exception {
  String path = proxy.path("/proxy/path/");
  return proxy.uri(home.toString() + "/foos/" + path).get();
All the features of Spring MVC and Webflux are available to gateway handler methods. As a result, you can inject request headers and query parameters, for instance, and you can constrain the incoming requests with declarations in the mapping annotation. See the documentation for @RequestMapping in Spring MVC for more details of those features.
You can add headers to the downstream response by using the header() methods on ProxyExchange.
You can also manipulate response headers (and anything else you like in the response) by adding a mapper to the get() method (and other methods). The mapper is a Function that takes the incoming ResponseEntity and converts it to an outgoing one.
First-class support is provided for “sensitive” headers (by default, cookie and authorization), which are not passed downstream, and for “proxy” (x-forwarded-*) headers.
APP信息
