12. Http timeouts configuration
Http timeouts (response and connect) can be configured for all routes and overridden for each specific route.
12.1. Global timeouts
To configure Global http timeouts:
connect-timeout
must be specified in milliseconds.
response-timeout
must be specified as a java.time.Duration
global http timeouts example
spring:
cloud:
gateway:
httpclient:
connect-timeout: 1000
response-timeout: 5s
12.2. Per-route timeouts
To configure per-route timeouts:
connect-timeout
response-timeout
per-route http timeouts configuration via configuration
- id: per_route_timeouts
uri: https://example.org
predicates:
- name: Path
args:
pattern: /delay/{timeout}
metadata:
response-timeout: 200
connect-timeout: 200
per-route timeouts configuration using Java DSL
import static org.springframework.cloud.gateway.support.RouteMetadataUtils.CONNECT_TIMEOUT_ATTR;
import static org.springframework.cloud.gateway.support.RouteMetadataUtils.RESPONSE_TIMEOUT_ATTR;
public RouteLocator customRouteLocator(RouteLocatorBuilder routeBuilder){
return routeBuilder.routes()
.route("test1", r -> {
return r.host("*.somehost.org").and().path("/somepath")
.filters(f -> f.addRequestHeader("header1", "header-value-1"))
.uri("http://someuri")
.metadata(RESPONSE_TIMEOUT_ATTR, 200)
.metadata(CONNECT_TIMEOUT_ATTR, 200);
A per-route response-timeout
with a negative value will disable the global response-timeout
value.
- id: per_route_timeouts uri: https://example.org predicates: - name: Path args: pattern: /delay/{timeout} metadata: response-timeout: -1
