For the latest stable version, please use spring-cloud-contract 4.2.1! |
A Three-second Tour
This very brief tour walks through using Spring Cloud Contract. It consists of the following topics:
You can find a somewhat longer tour here.
The following UML diagram shows the relationship of the parts within Spring Cloud Contract:
On the Producer Side
To start working with Spring Cloud Contract, you can add files with REST or messaging contracts
expressed in either Groovy DSL or YAML to the contracts directory, which is set by the
contractsDslDir
property. By default, it is $rootDir/src/test/resources/contracts
Then you can add the Spring Cloud Contract Verifier dependency and plugin to your build file, as the following example shows:
The following listing shows how to add the plugin, which should go in the build/plugins portion of the file:
<plugin>
<artifactId>spring-cloud-contract-maven-plugin</artifactId>
<version>${spring-cloud-contract.version}</version>
<extensions>true</extensions>
</plugin>
Running ./mvnw clean install
automatically generates tests that verify the application
compliance with the added contracts. By default, the tests get generated under
org.springframework.cloud.contract.verifier.tests.
As the implementation of the functionalities described by the contracts is not yet present, the tests fail.
To make them pass, you must add the correct implementation of either handling HTTP
requests or messages. Also, you must add a base test class for auto-generated
tests to the project. This class is extended by all the auto-generated tests, and it
should contain all the setup information necessary to run them (for example RestAssuredMockMvc
controller setup or messaging test setup).
The following example, from pom.xml
, shows how to specify the base test class:
<build>
<plugins>
<plugin>
<version>2.1.2.RELEASE</version>
<configuration>
<baseClassForTests>com.example.contractTest.BaseTestClass</baseClassForTests> (1)
</configuration>
</plugin>
<plugin>
</plugin>
</plugins>
</build>
1 | The baseClassForTests element lets you specify your base test class. It must be a child
of a configuration element within spring-cloud-contract-maven-plugin . |
Once the implementation and the test base class are in place, the tests pass, and both the application and the stub artifacts are built and installed in the local Maven repository. You can now merge the changes, and you can publish both the application and the stub artifacts in an online repository.
On the Consumer Side
You can use Spring Cloud Contract Stub Runner
in the integration tests to get a running
WireMock instance or messaging route that simulates the actual service.
To do so, add the dependency to Spring Cloud Contract Stub Runner
, as the
You can get the Producer-side stubs installed in your Maven repository in either of two ways:
By checking out the Producer side repository and adding contracts and generating the stubs by running the following commands:
$ cd local-http-server-repo $ ./mvnw clean install -DskipTests
The tests are being skipped because the producer-side contract implementation is not in place yet, so the automatically-generated contract tests fail. |
By getting already-existing producer service stubs from a remote repository. To do so, pass the stub artifact IDs and artifact repository URL as
properties, as the following example shows:
Now you can annotate your test class with @AutoConfigureStubRunner
. In the annotation,
provide the group-id
and artifact-id
values for Spring Cloud Contract Stub Runner
to
run the collaborators' stubs for you, as the following example shows:
@RunWith(SpringRunner.class)
@SpringBootTest(webEnvironment=WebEnvironment.NONE)
@AutoConfigureStubRunner(ids = {"com.example:http-server-dsl:+:stubs:6565"},
stubsMode = StubRunnerProperties.StubsMode.LOCAL)
public class LoanApplicationServiceTests {
Use the REMOTE stubsMode when downloading stubs from an online repository and
LOCAL for offline work.
Now, in your integration test, you can receive stubbed versions of HTTP responses or messages that are expected to be emitted by the collaborator service.
