For the latest stable version, please use spring-cloud-contract 4.2.0!spring-doc.cn
WebFlux with Explicit Mode
You can also use WebFlux with the explicit mode in your generated tests to work with WebFlux. The following example shows how to configure using explicit mode:spring-doc.cn
Maven
<plugin>
    <artifactId>spring-cloud-contract-maven-plugin</artifactId>
    <version>${spring-cloud-contract.version}</version>
    <extensions>true</extensions>
    <configuration>
        <testMode>EXPLICIT</testMode>
    </configuration>
</plugin>
Gradle
contracts {
		testMode = 'EXPLICIT'
The following example shows how to set up a base class and RestAssured for Web Flux.spring-doc.cn
