For the latest stable version, please use spring-cloud-contract 4.2.0!spring-doc.cn
How Can I Make The Build Pass if There Are No Contracts or Stubs
If you want Stub Runner not to fail if no stubs were found, switch the generateStubs property in the @AutoConfigureStubRunner annotation or call the withFailOnNoStubs(false) method on the JUnit Rule or Extension. You can read more about this in this section of the documentation.spring-doc.cn
If you want the plugins not to fail the build when no contracts were found, you can set the failOnNoStubs flag in Maven or call the contractRepository { failOnNoStubs(false) } closure in Gradle.spring-doc.cn
