For the latest stable version, please use spring-cloud-contract 4.2.0!spring-doc.cn
Common Properties
Common Properties for JUnit and Spring
You can set repetitive properties by using system properties or Spring configuration properties. The following table shows their names with their default values:spring-doc.cn
Property name Default value Description
stubrunner.minPortspring-doc.cn
10000spring-doc.cn
Minimum value of a port for a started WireMock with stubs.spring-doc.cn
stubrunner.maxPortspring-doc.cn
15000spring-doc.cn
Maximum value of a port for a started WireMock with stubs.spring-doc.cn
stubrunner.repositoryRootspring-doc.cn
Maven repository URL. If blank, then call the local Maven repo.spring-doc.cn
stubrunner.classifierspring-doc.cn
stubsspring-doc.cn
Default classifier for the stub artifacts.spring-doc.cn
stubrunner.stubsModespring-doc.cn
CLASSPATHspring-doc.cn
The way you want to fetch and register the stubs.spring-doc.cn
stubrunner.idsspring-doc.cn
Array of Ivy notation stubs to download.spring-doc.cn
stubrunner.usernamespring-doc.cn
Optional username to access the tool that stores the JARs with stubs.spring-doc.cn
stubrunner.passwordspring-doc.cn
Optional password to access the tool that stores the JARs with stubs.spring-doc.cn
stubrunner.stubsPerConsumerspring-doc.cn
falsespring-doc.cn
Set to true if you want to use different stubs for each consumer instead of registering all stubs for every consumer.spring-doc.cn
stubrunner.consumerNamespring-doc.cn
If you want to use a stub for each consumer and want to override the consumer name, change this value.spring-doc.cn
Stub Runner Stubs IDs
You can set the stubs to download in the stubrunner.ids system property. They use the following pattern:spring-doc.cn
groupId:artifactId:version:classifier:port
Note that version, classifier, and port are optional.spring-doc.cn
  • If you do not provide the port, a random one is picked.spring-doc.cn
  • If you do not provide the classifier, the default is used. (Note that you can pass an empty classifier this way: groupId:artifactId:version:).spring-doc.cn
  • If you do not provide the version, then + is passed, and the latest one is downloaded.spring-doc.cn
port means the port of the WireMock server.spring-doc.cn
Starting with version 1.0.4, you can provide a range of versions that you would like the Stub Runner to take into consideration. You can read more about the Aether versioning ranges here.
