For the latest stable version, please use spring-cloud-contract 4.2.0!spring-doc.cn
Publishing Stubs as JARs
The easiest approach to publishing stubs as jars is to centralize the way stubs are kept. For example, you can keep them as jars in a Maven repository.spring-doc.cn
For both Maven and Gradle, the setup comes ready to work. However, you can customize it if you want to.
Check these URL for Maven and Gradle samples.spring-doc.cn
