For the latest stable version, please use spring-cloud-contract 4.2.1!spring-doc.cn
How Can I Generate Stubs at Runtime
If you want to generate stubs at runtime for contracts, switch the generateStubs property in the @AutoConfigureStubRunner annotation, or call the withGenerateStubs(true) method on the JUnit Rule or Extension. You can read more about this in this section of the documentation.spring-doc.cn
