For the latest stable version, please use spring-cloud-contract 4.2.1!spring-doc.cn
Working with Context Paths
Spring Cloud Contract supports context paths.spring-doc.cn
The only change needed to fully support context paths is the switch on the producer side. Also, the autogenerated tests must use explicit mode. The consumer side remains untouched. In order for the generated test to pass, you must use explicit mode. The following example shows how to set the test mode to EXPLICIT:spring-doc.cn
Maven
<plugin>
    <artifactId>spring-cloud-contract-maven-plugin</artifactId>
    <version>${spring-cloud-contract.version}</version>
    <extensions>true</extensions>
    <configuration>
        <testMode>EXPLICIT</testMode>
    </configuration>
</plugin>
Gradle
contracts {
		testMode = 'EXPLICIT'
That way, you generate a test that does not use MockMvc. It means that you generate real requests and you need to set up your generated test’s base class to work on a real socket.spring-doc.cn
Consider the following contract:spring-doc.cn
org.springframework.cloud.contract.spec.Contract.make {
	request {
		method 'GET'
		url '/my-context-path/url'
	response {
		status OK()
The following example shows how to set up a base class and RestAssured:spring-doc.cn
import io.restassured.RestAssured;
import org.junit.Before;
import org.springframework.boot.test.context.SpringBootTest;
import org.springframework.boot.test.web.server.LocalServerPort;
@SpringBootTest(classes = ContextPathTestingBaseClass.class, webEnvironment = SpringBootTest.WebEnvironment.RANDOM_PORT)
class ContextPathTestingBaseClass {
	@LocalServerPort int port;
	@Before
	public void setup() {
		RestAssured.baseURI = "http://localhost";
		RestAssured.port = this.port;
If you do it this way:spring-doc.cn
  • All of your requests in the autogenerated tests are sent to the real endpoint with your context path included (for example, /my-context-path/url).spring-doc.cn
  • Your contracts reflect that you have a context path. Your generated stubs also have that information (for example, in the stubs, you have to call /my-context-path/url).spring-doc.cn
