For the latest stable version, please use Spring Shell 3.4.0!spring-doc.cn
Command Catalog
The CommandCatalog interface defines how command registrations exist in a shell application. It is possible to dynamically register and de-register commands, which gives flexibility for use cases where possible commands come and go, depending on a shell’s state. Consider the following example:spring-doc.cn
CommandRegistration registration = CommandRegistration.builder().build();
catalog.register(registration);
Command Resolver
You can implement the CommandResolver interface and define a bean to dynamically resolve mappings from a command’s name to its CommandRegistration instances. Consider the following example:spring-doc.cn
static class CustomCommandResolver implements CommandResolver {
	List<CommandRegistration> registrations = new ArrayList<>();
	CustomCommandResolver() {
		CommandRegistration resolved = CommandRegistration.builder()
			.command("resolve command")
		registrations.add(resolved);
	public List<CommandRegistration> resolve() {
		return registrations;
A current limitation of a CommandResolver is that it is used every time commands are resolved. Thus, we advise not using it if a command resolution call takes a long time, as it would make the shell feel sluggish.
Command Catalog Customizer
You can use the CommandCatalogCustomizer interface to customize a CommandCatalog. Its main use is to modify a catalog. Also, within spring-shell auto-configuration, this interface is used to register existing CommandRegistration beans into a catalog. Consider the following example:spring-doc.cn
static class CustomCommandCatalogCustomizer implements CommandCatalogCustomizer {
	public void customize(CommandCatalog commandCatalog) {
		commandCatalog.register(registration);
You can create a CommandCatalogCustomizer as a bean, and Spring Shell handles the rest.spring-doc.cn
