For the latest stable version, please use Spring Shell 3.4.0!spring-doc.cn
Legacy Annotation
Having a target method with argument is automatically registered with a matching argument name.spring-doc.cn
@ShellMethod
public String example(String arg1) {
	return "Hello " + arg1;
@ShellOption annotation can be used to define an option name if you don’t want it to be same as argument name.spring-doc.cn
@ShellMethod
public String example(@ShellOption(value = { "--arg" }) String arg1) {
If option name is defined without prefix, either - or --, it is discovered from ShellMethod#prefix.spring-doc.cn
@ShellMethod
public String example(@ShellOption(value = { "arg" }) String arg1) {
