For the latest stable version, please use Spring Shell 3.4.0!spring-doc.cn
Completion
The completion command set lets you create script files that can be used with am OS shell implementations to provide completion. This is very useful when working with non-interactive mode.spring-doc.cn
Currently, the only implementation is for bash, which works with bash sub-command.spring-doc.cn
