For the latest stable version, please use Spring Shell 3.4.0!
ListView
ListView is a base implementation providing functionality to draw a list of items. Inherits BoxView.
ListView<T> is typed as its item and can take any object. Further item processing happens in a CellFactory. For conveniance there is a support for generic higher level list feature showing checked states as normal check and radio types. Essentially what you can have is a list of items which are shown as is, shown where any items can have a checked state or only one item can have a checked state.
ListView<String> view = new ListView<>();
view.setItems(List.of("item1", "item2"));
Default item style is nocheck but can be changed.
Supports NOCHECK, `CHECK and `RADIO`
ListView<String> view = new ListView<>(ItemStyle.CHECKED);
Customisation
How individual cells are shown depends on a CellFactory. Default implementation simply shows item using its toString() method.
It can be customised by modifying a used CellFactory.
record ExampleData(String name) {
static class ExampleListCell extends AbstractListCell<ExampleData> {
	public ExampleListCell(ExampleData item) {
		super(item);
	public void draw(Screen screen) {
		Rectangle rect = getRect();
		Writer writer = screen.writerBuilder().style(getStyle()).build();
		writer.text(getItem().name(), rect.x(), rect.y());
		writer.background(rect, getBackgroundColor());
And set it as a factory:
ListView<ExampleData> view = new ListView<>();
view.setCellFactory((list, item) -> new ExampleListCell(item));
Default Bindings
Default view commands are:
Table 1. ViewCommands
Command Description
LINE_UP
Selection moves up.
LINE_DOWN
Selection moves down.
Default key bindigs are:
Table 2. Key
Command Description
CursorUp
Bound ViewCommand LINE_UP
CursorDown
Bound ViewCommand LINE_DOWN
Enter
Choose active item.
Space
Change active item selection state.
Default mouse bindigs are:
Table 3. Mouse
Command Description
Wheel | WheelUp
Wheel | WheelDown
Released | Button1
Choose item
Events
Events are sent depending on a used list type.
Table 4. ListView Events
Event Description
ListViewOpenSelectedItemEvent
Active item is requested to get opened.
ListViewSelectedItemChangedEvent
Active item is changed.
APP信息
