For the latest stable version, please use Spring Shell 3.4.0!spring-doc.cn
Command Context
The CommandContext interface gives access to a currently running context. You can use it to get access to options:spring-doc.cn
String arg = ctx.getOptionValue("arg");
If you need to print something into a shell, you can get a Terminal and use its writer to print something:spring-doc.cn
ctx.getTerminal().writer().println("hi");
