For the latest stable version, please use Spring Shell 3.4.0!spring-doc.cn
Reading Docs
Throughout this documentation, we make references to configuring something by using annotations or programmatic examples.spring-doc.cn
There are two annotation models, annotations referred to new annotation model, legacy annotations referred to old legacy annotation model.
Old legacy annotation model mostly relates to use of @ShellMethod and @ShellOption and new annotation model relates to use of @Command.spring-doc.cn
The programmatic model is how things are actually registered, even if you use annotations.spring-doc.cn
The documentation structure is getting revised to clarify how to provide configurations in separate ways. Thank you for understanding while that work is still in progress.
