This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Shell 3.4.0!spring-doc.cn
Settings
Built in emulation uses terminal width 80 and height 24 on default. Changing dimensions is useful if output would span into multiple lines and you don’t want to handle those cases in a tests.spring-doc.cn
These can be changed using properties spring.shell.test.terminal-width or spring.shell.test.terminal-height.spring-doc.cn
@ShellTest(properties = {
	"spring.shell.test.terminal-width=120",
	"spring.shell.test.terminal-height=40"
class ShellSettingsSample {}
ShellTest annotation have fields terminalWidth and terminalHeight which can also be used to change dimensions.spring-doc.cn
@ShellTest(terminalWidth = 120, terminalHeight = 40)
