This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Shell 3.4.0!spring-doc.cn
Short Format
Short style POSIX option is usually just a synonym to long format. As shown below option --arg is equal to -a.spring-doc.cn
CommandRegistration stringWithShortOption() {
	return CommandRegistration.builder()
		.command("example")
		.withTarget()
			.function(ctx -> {
				String arg = ctx.hasMappedOption("arg") ? ctx.getOptionValue("arg") : null;
				return String.format("Hi arg='%s'", arg);
			.and()
		.withOption()
			.longNames("arg")
			.shortNames('a')
			.required()
			.and()
@Command(command = "example")
String stringWithShortOption(
		@Option(longNames = "arg", shortNames = 'a', required = true) String arg) {
	return String.format("Hi '%s'", arg);
@ShellMethod(key = "example")
		@ShellOption(value = { "--arg", "-a" }) String arg)		{
Short option with combined format is powerful if type is defined as a flag which means type is a boolean. That way you can define a presence of a flags as -abc, -abc true or -abc false.spring-doc.cn
CommandRegistration multipleBooleans() {
		.command("example")
		.withTarget()
			.function(ctx -> {
				Boolean a = ctx.hasMappedOption("a") ? ctx.getOptionValue("a") : null;
				Boolean b = ctx.hasMappedOption("b") ? ctx.getOptionValue("b") : null;
				Boolean c = ctx.hasMappedOption("c") ? ctx.getOptionValue("c") : null;
				return String.format("Hi a='%s' b='%s' c='%s'", a, b, c);
			.and()
		.withOption()
			.shortNames('a')
			.type(boolean.class)
			.defaultValue("false")
			.and()
		.withOption()
			.shortNames('b')
			.and()
		.withOption()
			.shortNames('c')
			.and()
public String multipleBooleans(
		@Option(shortNames = 'a') boolean a,
		@Option(shortNames = 'b') boolean b,
		@Option(shortNames = 'c') boolean c) {
		@ShellOption(value = "-a") boolean a,
		@ShellOption(value = "-b") boolean b,
		@ShellOption(value = "-c") boolean c)
