This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Shell 3.4.0!spring-doc.cn
Programmatic
In the programmatic model, CommandRegistration can be defined as a @Bean and it will be automatically registered.spring-doc.cn
CommandRegistration commandRegistration() {
	return CommandRegistration.builder()
		.command("mycommand")
If all your commands have something in common, an instance of a CommandRegistration.BuilderSupplier is created which can be autowired. Default implementation of this supplier returns a new builder so you don’t need to worry about its internal state.spring-doc.cn
Commands registered programmatically automatically add help options mentioned in Help Options.
If bean of this supplier type is defined then auto-configuration will back off giving you an option to redefine default functionality.spring-doc.cn
CommandRegistration commandRegistration(CommandRegistration.BuilderSupplier builder) {
	return builder.get()
CommandRegistrationCustomizer beans can be defined if you want to centrally modify builder instance given you by supplier mentioned above.spring-doc.cn
CommandRegistrationCustomizer commandRegistrationCustomizerExample() {
	return builder -> {
		// customize instance of CommandRegistration.Builder
