This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Shell 3.4.0!spring-doc.cn
Exception Handling
Exceptions happen from a user code wether it is intentional or not. This section describes how spring-shell handles exceptions and gives instructions and best practices how to work with it.spring-doc.cn
Many command line applications when applicable return an exit code which running environment can use to differentiate if command has been executed successfully or not. In a spring-shell this mostly relates when a command is run on a non-interactive mode meaning one command is always executed once with an instance of a spring-shell. Take a note that exit code always relates to non-interactive shell.spring-doc.cn
