This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Shell 3.4.0!spring-doc.cn
Validation
Spring Shell integrates with the Bean Validation API to support automatic and self-documenting constraints on command parameters.spring-doc.cn
Annotations found on command parameters and annotations at the method level are honored and trigger validation prior to the command executing. Consider the following command:spring-doc.cn
	@ShellMethod("Change password.")
	public String changePassword(@Size(min = 8, max = 40) String password) {
		return "Password successfully set to " + password;
From the preceding example, you get the following behavior for free:spring-doc.cn
shell:>change-password hello
The following constraints were not met:
	--password string : size must be between 8 and 40 (You passed 'hello')
