This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Shell 3.4.0!spring-doc.cn
Command Not Found
On default a missing command is handled via CommandNotFoundResultHandler and outputs a simple message:spring-doc.cn
shell:>missing
No command found for 'missing'
Internally CommandNotFoundResultHandler is using CommandNotFoundMessageProvider which is a simple function taking a ProviderContext and returning a text message. Below is an example what a custom message provider might look like.spring-doc.cn
class CustomProvider implements CommandNotFoundMessageProvider {
	public String apply(ProviderContext context) {
		// parsed commands without options
		List<String> commands = context.commands();
		// actual error, usually CommandNotFound exception
		Throwable error = context.error();
		// access to registrations at this time
		Map<String, CommandRegistration> registrations = context.registrations();
		// raw text input from a user
		String text = context.text();
		return "My custom message";
It’s possible to change this implementation by defining it as a bean.spring-doc.cn
CommandNotFoundMessageProvider provider1() {
	return new CustomProvider();
CommandNotFoundResultHandler is a functional interface so it can be writter as a lambda.spring-doc.cn
CommandNotFoundMessageProvider provider2() {
	return ctx -> "My custom message";
