This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Shell 3.4.0!spring-doc.cn
Confirmation
The confirmation component asks a user for a simple confirmation. It is essentially a yes-or-no question.spring-doc.cn
@ShellComponent
public class ComponentCommands extends AbstractShellComponent {
	@ShellMethod(key = "component confirmation", value = "Confirmation input", group = "Components")
	public String confirmationInput(boolean no) {
		ConfirmationInput component = new ConfirmationInput(getTerminal(), "Enter value", !no);
		component.setResourceLoader(getResourceLoader());
		component.setTemplateExecutor(getTemplateExecutor());
		ConfirmationInputContext context = component.run(ConfirmationInputContext.empty());
		return "Got value " + context.getResultValue();
The following screencast shows the typical output from a confirmation component:spring-doc.cn
The context object is ConfirmationInputContext. The following table describes its context variables:spring-doc.cn
Table 1. ConfirmationInputContext Template Variables
Key Description
defaultValuespring-doc.cn
The default value — either true or false.spring-doc.cn
modelspring-doc.cn
The parent context variables (see TextComponentContext Template Variables).spring-doc.cn
