Basic Authentication
This section provides details on how Spring Security provides support for Basic HTTP Authentication for servlet-based applications.spring-doc.cn
This section describes how HTTP Basic Authentication works within Spring Security. First, we see the WWW-Authenticate header is sent back to an unauthenticated client:spring-doc.cn
basicauthenticationentrypoint
Figure 1. Sending WWW-Authenticate Header
The preceding figure builds off our SecurityFilterChain diagram.spring-doc.cn
number 1 First, a user makes an unauthenticated request to the resource /private for which it is not authorized.spring-doc.cn
number 2 Spring Security’s AuthorizationFilter indicates that the unauthenticated request is Denied by throwing an AccessDeniedException.spring-doc.cn
number 3 Since the user is not authenticated, ExceptionTranslationFilter initiates Start Authentication. The configured AuthenticationEntryPoint is an instance of BasicAuthenticationEntryPoint, which sends a WWW-Authenticate header. The RequestCache is typically a NullRequestCache that does not save the request since the client is capable of replaying the requests it originally requested.spring-doc.cn
When a client receives the WWW-Authenticate header, it knows it should retry with a username and password. The following image shows the flow for the username and password being processed:spring-doc.cn
basicauthenticationfilter
Figure 2. Authenticating Username and Password
number 1 When the user submits their username and password, the BasicAuthenticationFilter creates a UsernamePasswordAuthenticationToken, which is a type of Authentication by extracting the username and password from the HttpServletRequest.spring-doc.cn
number 2 Next, the UsernamePasswordAuthenticationToken is passed into the AuthenticationManager to be authenticated. The details of what AuthenticationManager looks like depend on how the user information is stored.spring-doc.cn
number 3 If authentication fails, then Failure.spring-doc.cn
  1. The SecurityContextHolder is cleared out.spring-doc.cn
  2. RememberMeServices.loginFail is invoked. If remember me is not configured, this is a no-op. See the RememberMeServices interface in the Javadoc.spring-doc.cn
  3. AuthenticationEntryPoint is invoked to trigger the WWW-Authenticate to be sent again. See the AuthenticationEntryPoint interface in the Javadoc.spring-doc.cn
number 4 If authentication is successful, then Success.spring-doc.cn
  1. The Authentication is set on the SecurityContextHolder.spring-doc.cn
  2. RememberMeServices.loginSuccess is invoked. If remember me is not configured, this is a no-op. See the RememberMeServices interface in the Javadoc.spring-doc.cn
  3. The BasicAuthenticationFilter invokes FilterChain.doFilter(request,response) to continue with the rest of the application logic. See the BasicAuthenticationFilter Class in the Javadocspring-doc.cn
By default, Spring Security’s HTTP Basic Authentication support is enabled. However, as soon as any servlet based configuration is provided, HTTP Basic must be explicitly provided.spring-doc.cn
The following example shows a minimal, explicit configuration:spring-doc.cn
Explicit HTTP Basic Configuration
public SecurityFilterChain filterChain(HttpSecurity http) {
	http
		.httpBasic(withDefaults());
	return http.build();
<http>
	<http-basic />
</http>
	http {
		httpBasic { }
	return http.build()
