OAuth2
Spring Security provides comprehensive OAuth 2.0 support. This section discusses how to integrate OAuth 2.0 into your servlet based application.spring-doc.cn
Overview
Spring Security’s OAuth 2.0 support consists of two primary feature sets:spring-doc.cn
OAuth2 Login is a very powerful OAuth2 Client feature that deserves its own section in the reference documentation. However, it does not exist as a standalone feature and requires OAuth2 Client in order to function.spring-doc.cn
These feature sets cover the resource server and client roles defined in the OAuth 2.0 Authorization Framework, while the authorization server role is covered by Spring Authorization Server, which is a separate project built on Spring Security.spring-doc.cn
The resource server and client roles in OAuth2 are typically represented by one or more server-side applications. Additionally, the authorization server role can be represented by one or more third parties (as is the case when centralizing identity management and/or authentication within an organization) -or- it can be represented by an application (as is the case with Spring Authorization Server).spring-doc.cn
For example, a typical OAuth2-based microservices architecture might consist of a single user-facing client application, several backend resource servers providing REST APIs and a third party authorization server for managing users and authentication concerns. It is also common to have a single application representing only one of these roles with the need to integrate with one or more third parties that are providing the other roles.spring-doc.cn
Spring Security handles these scenarios and more. The following sections cover the roles provided by Spring Security and contain examples for common scenarios.spring-doc.cn
OAuth2 Resource Server
This section contains a summary of OAuth2 Resource Server features with examples. See OAuth 2.0 Resource Server for complete reference documentation.spring-doc.cn
To get started, add the spring-security-oauth2-resource-server dependency to your project. When using Spring Boot, add the following starter:spring-doc.cn
OAuth2 Client with Spring Boot
implementation 'org.springframework.boot:spring-boot-starter-oauth2-resource-server'
<dependency>
	<artifactId>spring-boot-starter-oauth2-resource-server</artifactId>
</dependency>
See Getting Spring Security for additional options when not using Spring Boot.spring-doc.cn
Consider the following use cases for OAuth2 Resource Server:spring-doc.cn
Protect Access with an OAuth2 Access Token
It is very common to protect access to an API using OAuth2 access tokens. In most cases, Spring Security requires only minimal configuration to secure an application with OAuth2.spring-doc.cn
There are two types of Bearer tokens supported by Spring Security which each use a different component for validation:spring-doc.cn
JWT Support
The following example configures a JwtDecoder bean using Spring Boot configuration properties:spring-doc.cn
spring:
  security:
    oauth2:
      resourceserver:
        jwt:
          issuer-uri: https://my-auth-server.com
When using Spring Boot, this is all that is required. The default arrangement provided by Spring Boot is equivalent to the following:spring-doc.cn
Configure Resource Server with JWTs
@EnableWebSecurity
public class SecurityConfig {
	public SecurityFilterChain securityFilterChain(HttpSecurity http) throws Exception {
		http
			.authorizeHttpRequests((authorize) -> authorize
				.anyRequest().authenticated()
			.oauth2ResourceServer((oauth2) -> oauth2
				.jwt(Customizer.withDefaults())
		return http.build();
	public JwtDecoder jwtDecoder() {
		return JwtDecoders.fromIssuerLocation("https://my-auth-server.com");
import org.springframework.security.config.annotation.web.invoke
@EnableWebSecurity
	fun securityFilterChain(http: HttpSecurity): SecurityFilterChain {
		http {
			authorizeHttpRequests {
			oauth2ResourceServer {
				jwt { }
		return http.build()
	fun jwtDecoder(): JwtDecoder {
Opaque Token Support
The following example configures an OpaqueTokenIntrospector bean using Spring Boot configuration properties:spring-doc.cn
spring:
  security:
    oauth2:
      resourceserver:
        opaquetoken:
          introspection-uri: https://my-auth-server.com/oauth2/introspect
          client-id: my-client-id
          client-secret: my-client-secret
Configure Resource Server with Opaque Tokens
@EnableWebSecurity
		http
				.opaqueToken(Customizer.withDefaults())
	public OpaqueTokenIntrospector opaqueTokenIntrospector() {
		return new SpringOpaqueTokenIntrospector(
			"https://my-auth-server.com/oauth2/introspect", "my-client-id", "my-client-secret");
@EnableWebSecurity
		http {
				opaqueToken { }
		return http.build()
	fun opaqueTokenIntrospector(): OpaqueTokenIntrospector {
		return SpringOpaqueTokenIntrospector(
Protect Access with a custom JWT
It is a fairly common goal to protect access to an API using JWTs, particularly when the frontend is developed as a single-page application. The OAuth2 Resource Server support in Spring Security can be used for any type of Bearer token, including a custom JWT.spring-doc.cn
All that is required to protect an API using JWTs is a JwtDecoder bean, which is used to validate signatures and decode tokens. Spring Security will automatically use the provided bean to configure protection within the SecurityFilterChain.spring-doc.cn
spring:
  security:
    oauth2:
      resourceserver:
        jwt:
          public-key-location: classpath:my-public-key.pub
You can provide the public key as a classpath resource (called my-public-key.pub in this example).spring-doc.cn
Configure Resource Server with Custom JWTs
@EnableWebSecurity
		http
		return NimbusJwtDecoder.withPublicKey(publicKey()).build();
	private RSAPublicKey publicKey() {
@EnableWebSecurity
		http {
				jwt { }
		return http.build()
	private fun publicKey(): RSAPublicKey {
Spring Security does not provide an endpoint for minting tokens. However, Spring Security does provide the JwtEncoder interface along with one implementation, which is NimbusJwtEncoder.spring-doc.cn
OAuth2 Client
This section contains a summary of OAuth2 Client features with examples. See OAuth 2.0 Client and OAuth 2.0 Login for complete reference documentation.spring-doc.cn
To get started, add the spring-security-oauth2-client dependency to your project. When using Spring Boot, add the following starter:spring-doc.cn
implementation 'org.springframework.boot:spring-boot-starter-oauth2-client'
<dependency>
	<artifactId>spring-boot-starter-oauth2-client</artifactId>
</dependency>
Consider the following use cases for OAuth2 Client:spring-doc.cn
Log Users In with OAuth2
It is very common to require users to log in via OAuth2. OpenID Connect 1.0 provides a special token called the id_token which is designed to provide an OAuth2 Client with the ability to perform user identity verification and log users in. In certain cases, OAuth2 can be used directly to log users in (as is the case with popular social login providers that do not implement OpenID Connect such as GitHub and Facebook).spring-doc.cn
The following example configures the application to act as an OAuth2 Client capable of logging users in with OAuth2 or OpenID Connect:spring-doc.cn
Configure OAuth2 Login
@EnableWebSecurity
		http
			.oauth2Login(Customizer.withDefaults());
@EnableWebSecurity
		http {
			oauth2Login { }
		return http.build()
In addition to the above configuration, the application requires at least one ClientRegistration to be configured through the use of a ClientRegistrationRepository bean. The following example configures an InMemoryClientRegistrationRepository bean using Spring Boot configuration properties:spring-doc.cn
spring:
  security:
    oauth2:
      client:
        registration:
          my-oidc-client:
            provider: my-oidc-provider
            authorization-grant-type: authorization_code
            scope: openid,profile
        provider:
          my-oidc-provider:
            issuer-uri: https://my-oidc-provider.com
With the above configuration, the application now supports two additional endpoints:spring-doc.cn
  1. The login endpoint (e.g. /oauth2/authorization/my-oidc-client) is used to initiate login and perform a redirect to the third party authorization server.spring-doc.cn
  2. The redirection endpoint (e.g. /login/oauth2/code/my-oidc-client) is used by the authorization server to redirect back to the client application, and will contain a code parameter used to obtain an id_token and/or access_token via the access token request.spring-doc.cn
The presence of the openid scope in the above configuration indicates that OpenID Connect 1.0 should be used. This instructs Spring Security to use OIDC-specific components (such as OidcUserService) during request processing. Without this scope, Spring Security will use OAuth2-specific components (such as OAuth2UserService) instead.spring-doc.cn
Access Protected Resources
Making requests to a third party API that is protected by OAuth2 is a core use case of OAuth2 Client. This is accomplished by authorizing a client (represented by the OAuth2AuthorizedClient class in Spring Security) and accessing protected resources by placing a Bearer token in the Authorization header of an outbound request.spring-doc.cn
The following example configures the application to act as an OAuth2 Client capable of requesting protected resources from a third party API:spring-doc.cn
Configure OAuth2 Client
@EnableWebSecurity
		http
			.oauth2Client(Customizer.withDefaults());
@EnableWebSecurity
		http {
			oauth2Client { }
		return http.build()
The above example does not provide a way to log users in. You can use any other login mechanism (such as formLogin()). See the next section for an example combining oauth2Client() with oauth2Login().spring-doc.cn
spring:
  security:
    oauth2:
      client:
        registration:
          my-oauth2-client:
            provider: my-auth-server
            scope: message.read,message.write
        provider:
          my-auth-server:
In addition to configuring Spring Security to support OAuth2 Client features, you will also need to decide how you will be accessing protected resources and configure your application accordingly. Spring Security provides implementations of OAuth2AuthorizedClientManager for obtaining access tokens that can be used to access protected resources.spring-doc.cn
Spring Security registers a default OAuth2AuthorizedClientManager bean for you when one does not exist.spring-doc.cn
The easiest way to use an OAuth2AuthorizedClientManager is via an ExchangeFilterFunction that intercepts requests through a WebClient. To use WebClient, you will need to add the spring-webflux dependency along with a reactive client implementation:spring-doc.cn
Add Spring WebFlux Dependency
implementation 'org.springframework:spring-webflux'
implementation 'io.projectreactor.netty:reactor-netty'
<dependency>
	<groupId>org.springframework</groupId>
	<artifactId>spring-webflux</artifactId>
</dependency>
<dependency>
	<groupId>io.projectreactor.netty</groupId>
	<artifactId>reactor-netty</artifactId>
</dependency>
The following example uses the default OAuth2AuthorizedClientManager to configure a WebClient capable of accessing protected resources by placing Bearer tokens in the Authorization header of each request:spring-doc.cn
Configure WebClient with ExchangeFilterFunction
public class WebClientConfig {
	public WebClient webClient(OAuth2AuthorizedClientManager authorizedClientManager) {
		ServletOAuth2AuthorizedClientExchangeFilterFunction filter =
				new ServletOAuth2AuthorizedClientExchangeFilterFunction(authorizedClientManager);
		return WebClient.builder()
				.apply(filter.oauth2Configuration())
	fun webClient(authorizedClientManager: OAuth2AuthorizedClientManager): WebClient {
		val filter = ServletOAuth2AuthorizedClientExchangeFilterFunction(authorizedClientManager)
			.build()
This configured WebClient can be used as in the following example:spring-doc.cn
Use WebClient to Access Protected Resources
import static org.springframework.security.oauth2.client.web.reactive.function.client.ServletOAuth2AuthorizedClientExchangeFilterFunction.clientRegistrationId;
@RestController
public class MessagesController {
	private final WebClient webClient;
	public MessagesController(WebClient webClient) {
		this.webClient = webClient;
	@GetMapping("/messages")
	public ResponseEntity<List<Message>> messages() {
		return this.webClient.get()
				.uri("http://localhost:8090/messages")
				.attributes(clientRegistrationId("my-oauth2-client"))
				.retrieve()
				.toEntityList(Message.class)
				.block();
	public record Message(String message) {
import org.springframework.security.oauth2.client.web.reactive.function.client.ServletOAuth2AuthorizedClientExchangeFilterFunction.clientRegistrationId
@RestController
class MessagesController(private val webClient: WebClient) {
	fun messages(): ResponseEntity<List<Message>> {
		return webClient.get()
			.retrieve()
			.toEntityList(Message::class.java)
			.block()!!
	data class Message(val message: String)
Access Protected Resources for the Current User
When a user is logged in via OAuth2 or OpenID Connect, the authorization server may provide an access token that can be used directly to access protected resources. This is convenient because it only requires a single ClientRegistration to be configured for both use cases simultaneously.spring-doc.cn
This section combines Log Users In with OAuth2 and Access Protected Resources into a single configuration. Other advanced scenarios exist, such as configuring one ClientRegistration for login and another for accessing protected resources. All such scenarios would use the same basic configuration.spring-doc.cn
The following example configures the application to act as an OAuth2 Client capable of logging the user in and requesting protected resources from a third party API:spring-doc.cn
Configure OAuth2 Login and OAuth2 Client
@EnableWebSecurity
		http
@EnableWebSecurity
		http {
			oauth2Login { }
			oauth2Client { }
		return http.build()
spring:
  security:
    oauth2:
      client:
        registration:
          my-combined-client:
            scope: openid,profile,message.read,message.write
        provider:
          my-auth-server:
The main difference between the previous examples (Log Users In with OAuth2, Access Protected Resources) and this one is what is configured via the scope property, which combines the standard scopes openid and profile with the custom scopes message.read and message.write.spring-doc.cn
<dependency>
</dependency>
<dependency>
</dependency>
			.build()
Use WebClient to Access Protected Resources (Current User)
@RestController
				.retrieve()
				.block();
@RestController
			.retrieve()
			.block()!!
Unlike the previous example, notice that we do not need to tell Spring Security about the clientRegistrationId we’d like to use. This is because it can be derived from the currently logged in user.spring-doc.cn
Enable an Extension Grant Type
A common use case involves enabling and/or configuring an extension grant type. For example, Spring Security provides support for the jwt-bearer grant type, but does not enable it by default because it is not part of the core OAuth 2.0 specification.spring-doc.cn
With Spring Security 6.2 and later, we can simply publish a bean for one or more OAuth2AuthorizedClientProvider and they will be picked up automatically. The following example simply enables the jwt-bearer grant type:spring-doc.cn
Enable jwt-bearer Grant Type
	public OAuth2AuthorizedClientProvider jwtBearer() {
		return new JwtBearerOAuth2AuthorizedClientProvider();
	fun jwtBearer(): OAuth2AuthorizedClientProvider {
		return JwtBearerOAuth2AuthorizedClientProvider()
A default OAuth2AuthorizedClientManager will be published automatically by Spring Security when one is not already provided.spring-doc.cn
Any custom OAuth2AuthorizedClientProvider bean will also be picked up and applied to the provided OAuth2AuthorizedClientManager after the default grant types.spring-doc.cn
In order to achieve the above configuration prior to Spring Security 6.2, we had to publish this bean ourselves and ensure we re-enabled default grant types as well. To understand what is being configured behind the scenes, here’s what the configuration might have looked like:spring-doc.cn
Enable jwt-bearer Grant Type (prior to 6.2)
	public OAuth2AuthorizedClientManager authorizedClientManager(
			ClientRegistrationRepository clientRegistrationRepository,
			OAuth2AuthorizedClientRepository authorizedClientRepository) {
		OAuth2AuthorizedClientProvider authorizedClientProvider =
			OAuth2AuthorizedClientProviderBuilder.builder()
				.authorizationCode()
				.refreshToken()
				.clientCredentials()
				.password()
				.provider(new JwtBearerOAuth2AuthorizedClientProvider())
		DefaultOAuth2AuthorizedClientManager authorizedClientManager =
			new DefaultOAuth2AuthorizedClientManager(
				clientRegistrationRepository, authorizedClientRepository);
		authorizedClientManager.setAuthorizedClientProvider(authorizedClientProvider);
		return authorizedClientManager;
	fun authorizedClientManager(
		clientRegistrationRepository: ClientRegistrationRepository,
		authorizedClientRepository: OAuth2AuthorizedClientRepository
	): OAuth2AuthorizedClientManager {
		val authorizedClientProvider = OAuth2AuthorizedClientProviderBuilder.builder()
			.refreshToken()
			.password()
			.provider(JwtBearerOAuth2AuthorizedClientProvider())
			.build()
		val authorizedClientManager = DefaultOAuth2AuthorizedClientManager(
Customize an Existing Grant Type
The ability to enable extension grant types by publishing a bean also provides the opportunity for customizing an existing grant type without the need to re-define the defaults. For example, if we want to customize the clock skew of the OAuth2AuthorizedClientProvider for the client_credentials grant, we can simply publish a bean like so:spring-doc.cn
Customize Client Credentials Grant Type
	public OAuth2AuthorizedClientProvider clientCredentials() {
		ClientCredentialsOAuth2AuthorizedClientProvider authorizedClientProvider =
				new ClientCredentialsOAuth2AuthorizedClientProvider();
		authorizedClientProvider.setClockSkew(Duration.ofMinutes(5));
		return authorizedClientProvider;
	fun clientCredentials(): OAuth2AuthorizedClientProvider {
		val authorizedClientProvider = ClientCredentialsOAuth2AuthorizedClientProvider()
Customize Token Request Parameters
The need to customize request parameters when obtaining an access token is fairly common. For example, let’s say we want to add a custom audience parameter to the token request because the provider requires this parameter for the authorization_code grant.spring-doc.cn
With Spring Security 6.2 and later, we can simply publish a bean of type OAuth2AccessTokenResponseClient with the generic type OAuth2AuthorizationCodeGrantRequest and it will be used by Spring Security to configure OAuth2 Client components.spring-doc.cn
The following example customizes token request parameters for the authorization_code grant without the DSL:spring-doc.cn
Customize Token Request Parameters for Authorization Code Grant
	public OAuth2AccessTokenResponseClient<OAuth2AuthorizationCodeGrantRequest> authorizationCodeAccessTokenResponseClient() {
		OAuth2AuthorizationCodeGrantRequestEntityConverter requestEntityConverter =
			new OAuth2AuthorizationCodeGrantRequestEntityConverter();
		requestEntityConverter.addParametersConverter(parametersConverter());
		DefaultAuthorizationCodeTokenResponseClient accessTokenResponseClient =
			new DefaultAuthorizationCodeTokenResponseClient();
		accessTokenResponseClient.setRequestEntityConverter(requestEntityConverter);
		return accessTokenResponseClient;
	private static Converter<OAuth2AuthorizationCodeGrantRequest, MultiValueMap<String, String>> parametersConverter() {
		return (grantRequest) -> {
			MultiValueMap<String, String> parameters = new LinkedMultiValueMap<>();
			parameters.set("audience", "xyz_value");
			return parameters;
	fun authorizationCodeAccessTokenResponseClient(): OAuth2AccessTokenResponseClient<OAuth2AuthorizationCodeGrantRequest> {
		val requestEntityConverter = OAuth2AuthorizationCodeGrantRequestEntityConverter()
		val accessTokenResponseClient = DefaultAuthorizationCodeTokenResponseClient()
	private fun parametersConverter(): Converter<OAuth2AuthorizationCodeGrantRequest, MultiValueMap<String, String>> {
		return Converter<OAuth2AuthorizationCodeGrantRequest, MultiValueMap<String, String>> { grantRequest ->
			LinkedMultiValueMap<String, String>().also { parameters ->
				parameters["audience"] = "xyz_value"
Notice that we don’t need to customize the SecurityFilterChain bean in this case, and can stick with the defaults. If using Spring Boot with no additional customizations, we can actually omit the SecurityFilterChain bean entirely.spring-doc.cn
Prior to Spring Security 6.2, we had to ensure that this customization was applied for both OAuth2 Login (if we are using this feature) and OAuth2 Client components using the Spring Security DSL. To understand what is being configured behind the scenes, here’s what the configuration might have looked like:spring-doc.cn
Customize Token Request Parameters for Authorization Code Grant (prior to 6.2)
@EnableWebSecurity
		http
			.oauth2Login((oauth2Login) -> oauth2Login
				.tokenEndpoint((tokenEndpoint) -> tokenEndpoint
					.accessTokenResponseClient(accessTokenResponseClient)
			.oauth2Client((oauth2Client) -> oauth2Client
				.authorizationCodeGrant((authorizationCode) -> authorizationCode
@EnableWebSecurity
		val tokenResponseClient = DefaultAuthorizationCodeTokenResponseClient()
		tokenResponseClient.setRequestEntityConverter(requestEntityConverter)
		http {
			oauth2Login {
				tokenEndpoint {
					accessTokenResponseClient = tokenResponseClient
			oauth2Client {
				authorizationCodeGrant {
		return http.build()
For other grant types we can publish additional OAuth2AccessTokenResponseClient beans to override the defaults. For example, to customize token requests for the client_credentials grant we can publish the following bean:spring-doc.cn
Customize Token Request Parameters for Client Credentials Grant
	public OAuth2AccessTokenResponseClient<OAuth2ClientCredentialsGrantRequest> clientCredentialsAccessTokenResponseClient() {
		OAuth2ClientCredentialsGrantRequestEntityConverter requestEntityConverter =
			new OAuth2ClientCredentialsGrantRequestEntityConverter();
		DefaultClientCredentialsTokenResponseClient accessTokenResponseClient =
				new DefaultClientCredentialsTokenResponseClient();
	private static Converter<OAuth2ClientCredentialsGrantRequest, MultiValueMap<String, String>> parametersConverter() {
	fun clientCredentialsAccessTokenResponseClient(): OAuth2AccessTokenResponseClient<OAuth2ClientCredentialsGrantRequest> {
		val requestEntityConverter = OAuth2ClientCredentialsGrantRequestEntityConverter()
		val accessTokenResponseClient = DefaultClientCredentialsTokenResponseClient()
	private fun parametersConverter(): Converter<OAuth2ClientCredentialsGrantRequest, MultiValueMap<String, String>> {
Spring Security automatically resolves the following generic types of OAuth2AccessTokenResponseClient beans:spring-doc.cn
  • OAuth2AuthorizationCodeGrantRequest (see DefaultAuthorizationCodeTokenResponseClient)spring-doc.cn
  • OAuth2RefreshTokenGrantRequest (see DefaultRefreshTokenTokenResponseClient)spring-doc.cn
  • OAuth2ClientCredentialsGrantRequest (see DefaultClientCredentialsTokenResponseClient)spring-doc.cn
  • OAuth2PasswordGrantRequest (see DefaultPasswordTokenResponseClient)spring-doc.cn
  • JwtBearerGrantRequest (see DefaultJwtBearerTokenResponseClient)spring-doc.cn
Publishing a bean of type OAuth2AccessTokenResponseClient<JwtBearerGrantRequest> will automatically enable the jwt-bearer grant type without the need to configure it separately.spring-doc.cn
Customize the RestOperations used by OAuth2 Client Components
Another common use case is the need to customize the RestOperations used when obtaining an access token. We might need to do this to customize processing of the response (via a custom HttpMessageConverter) or to apply proxy settings for a corporate network (via a customized ClientHttpRequestFactory).spring-doc.cn
With Spring Security 6.2 and later, we can simply publish beans of type OAuth2AccessTokenResponseClient and Spring Security will configure and publish an OAuth2AuthorizedClientManager bean for us.spring-doc.cn
The following example customizes the RestOperations for all of the supported grant types:spring-doc.cn
Customize RestOperations for OAuth2 Client
		accessTokenResponseClient.setRestOperations(restTemplate());
	public OAuth2AccessTokenResponseClient<OAuth2RefreshTokenGrantRequest> refreshTokenAccessTokenResponseClient() {
		DefaultRefreshTokenTokenResponseClient accessTokenResponseClient =
			new DefaultRefreshTokenTokenResponseClient();
	public OAuth2AccessTokenResponseClient<OAuth2PasswordGrantRequest> passwordAccessTokenResponseClient() {
		DefaultPasswordTokenResponseClient accessTokenResponseClient =
			new DefaultPasswordTokenResponseClient();
	public OAuth2AccessTokenResponseClient<JwtBearerGrantRequest> jwtBearerAccessTokenResponseClient() {
		DefaultJwtBearerTokenResponseClient accessTokenResponseClient =
			new DefaultJwtBearerTokenResponseClient();
	public RestTemplate restTemplate() {
	fun refreshTokenAccessTokenResponseClient(): OAuth2AccessTokenResponseClient<OAuth2RefreshTokenGrantRequest> {
		val accessTokenResponseClient = DefaultRefreshTokenTokenResponseClient()
	fun passwordAccessTokenResponseClient(): OAuth2AccessTokenResponseClient<OAuth2PasswordGrantRequest> {
		val accessTokenResponseClient = DefaultPasswordTokenResponseClient()
	fun jwtBearerAccessTokenResponseClient(): OAuth2AccessTokenResponseClient<JwtBearerGrantRequest> {
		val accessTokenResponseClient = DefaultJwtBearerTokenResponseClient()
	fun restTemplate(): RestTemplate {
Prior to Spring Security 6.2, we had to ensure this customization was applied to both OAuth2 Login (if we are using this feature) and OAuth2 Client components. We had to use both the Spring Security DSL (for the authorization_code grant) and publish a bean of type OAuth2AuthorizedClientManager for other grant types. To understand what is being configured behind the scenes, here’s what the configuration might have looked like:spring-doc.cn
Customize RestOperations for OAuth2 Client (prior to 6.2)
@EnableWebSecurity
		http
		DefaultRefreshTokenTokenResponseClient refreshTokenAccessTokenResponseClient =
		refreshTokenAccessTokenResponseClient.setRestOperations(restTemplate());
		DefaultClientCredentialsTokenResponseClient clientCredentialsAccessTokenResponseClient =
		clientCredentialsAccessTokenResponseClient.setRestOperations(restTemplate());
		DefaultPasswordTokenResponseClient passwordAccessTokenResponseClient =
		passwordAccessTokenResponseClient.setRestOperations(restTemplate());
		DefaultJwtBearerTokenResponseClient jwtBearerAccessTokenResponseClient =
		jwtBearerAccessTokenResponseClient.setRestOperations(restTemplate());
		JwtBearerOAuth2AuthorizedClientProvider jwtBearerAuthorizedClientProvider =
		jwtBearerAuthorizedClientProvider.setAccessTokenResponseClient(jwtBearerAccessTokenResponseClient);
				.refreshToken((refreshToken) -> refreshToken
					.accessTokenResponseClient(refreshTokenAccessTokenResponseClient)
				.clientCredentials((clientCredentials) -> clientCredentials
					.accessTokenResponseClient(clientCredentialsAccessTokenResponseClient)
				.password((password) -> password
					.accessTokenResponseClient(passwordAccessTokenResponseClient)
				.provider(jwtBearerAuthorizedClientProvider)
@EnableWebSecurity
		tokenResponseClient.setRestOperations(restTemplate())
		http {
			oauth2Login {
				tokenEndpoint {
			oauth2Client {
		return http.build()
		clientRegistrationRepository: ClientRegistrationRepository?,
		authorizedClientRepository: OAuth2AuthorizedClientRepository?
		val refreshTokenAccessTokenResponseClient = DefaultRefreshTokenTokenResponseClient()
		val clientCredentialsAccessTokenResponseClient = DefaultClientCredentialsTokenResponseClient()
		val passwordAccessTokenResponseClient = DefaultPasswordTokenResponseClient()
		val jwtBearerAccessTokenResponseClient = DefaultJwtBearerTokenResponseClient()
		val jwtBearerAuthorizedClientProvider = JwtBearerOAuth2AuthorizedClientProvider()
			.refreshToken { refreshToken ->
				refreshToken.accessTokenResponseClient(refreshTokenAccessTokenResponseClient)
			.clientCredentials { clientCredentials ->
				clientCredentials.accessTokenResponseClient(clientCredentialsAccessTokenResponseClient)
			.password { password ->
				password.accessTokenResponseClient(passwordAccessTokenResponseClient)
			.build()
Further Reading
This preceding sections introduced Spring Security’s support for OAuth2 with examples for common scenarios. You can read more about OAuth2 Client and Resource Server in the following sections of the reference documentation:spring-doc.cn
