SAML 2.0 Login Overview
We start by examining how SAML 2.0 Relying Party Authentication works within Spring Security. First, we see that, like OAuth 2.0 Login, Spring Security takes the user to a third party for performing authentication. It does this through a series of redirects:spring-doc.cn
saml2webssoauthenticationrequestfilter
Figure 1. Redirecting to Asserting Party Authentication
The figure above builds off our SecurityFilterChain and AbstractAuthenticationProcessingFilter diagrams:spring-doc.cn
number 1 First, a user makes an unauthenticated request to the /private resource, for which it is not authorized.spring-doc.cn
number 2 Spring Security’s AuthorizationFilter indicates that the unauthenticated request is Denied by throwing an AccessDeniedException.spring-doc.cn
number 3 Since the user lacks authorization, the ExceptionTranslationFilter initiates Start Authentication. The configured AuthenticationEntryPoint is an instance of LoginUrlAuthenticationEntryPoint, which redirects to the <saml2:AuthnRequest> generating endpoint, Saml2WebSsoAuthenticationRequestFilter. Alternatively, if you have configured more than one asserting party, it first redirects to a picker page.spring-doc.cn
number 4 Next, the Saml2WebSsoAuthenticationRequestFilter creates, signs, serializes, and encodes a <saml2:AuthnRequest> using its configured Saml2AuthenticationRequestFactory.spring-doc.cn
number 5 Then the browser takes this <saml2:AuthnRequest> and presents it to the asserting party. The asserting party tries to authentication the user. If successful, it returns a <saml2:Response> back to the browser.spring-doc.cn
number 6 The browser then POSTs the <saml2:Response> to the assertion consumer service endpoint.spring-doc.cn
The following image shows how Spring Security authenticates a <saml2:Response>.spring-doc.cn
saml2webssoauthenticationfilter
Figure 2. Authenticating a <saml2:Response>
The figure builds off our SecurityFilterChain diagram.spring-doc.cn
number 1 When the browser submits a <saml2:Response> to the application, it delegates to Saml2WebSsoAuthenticationFilter. This filter calls its configured AuthenticationConverter to create a Saml2AuthenticationToken by extracting the response from the HttpServletRequest. This converter additionally resolves the RelyingPartyRegistration and supplies it to Saml2AuthenticationToken.spring-doc.cn
number 2 Next, the filter passes the token to its configured AuthenticationManager. By default, it uses the OpenSamlAuthenticationProvider.spring-doc.cn
number 3 If authentication fails, then Failure.spring-doc.cn
number 4 If authentication is successful, then Success.spring-doc.cn
Minimal Dependencies
SAML 2.0 service provider support resides in spring-security-saml2-service-provider. It builds off of the OpenSAML library, and, for that reason, you must also include the Shibboleth Maven repository in your build configuration. Check this link for more details about why a separate repository is needed.spring-doc.cn
<repositories>
    <repository>
        <id>shibboleth-releases</id>
        <url>https://build.shibboleth.net/nexus/content/repositories/releases/</url>
    </repository>
</repositories>
<dependency>
    <groupId>org.springframework.security</groupId>
    <artifactId>spring-security-saml2-service-provider</artifactId>
</dependency>
repositories {
    maven { url "https://build.shibboleth.net/nexus/content/repositories/releases/" }
dependencies {
    implementation 'org.springframework.security:spring-security-saml2-service-provider'
Minimal Configuration
When using Spring Boot, configuring an application as a service provider consists of two basic steps: . Include the needed dependencies. . Indicate the necessary asserting party metadata.spring-doc.cn
Also, this configuration presupposes that you have already registered the relying party with your asserting party.
Specifying Identity Provider Metadata
In a Spring Boot application, to specify an identity provider’s metadata, create configuration similar to the following:spring-doc.cn
spring:
  security:
    saml2:
      relyingparty:
        registration:
          adfs:
            identityprovider:
              entity-id: https://idp.example.com/issuer
              verification.credentials:
                - certificate-location: "classpath:idp.crt"
              singlesignon.url: https://idp.example.com/issuer/sso
              singlesignon.sign-request: false
And that’s it!spring-doc.cn
Identity Provider and Asserting Party are synonymous, as are Service Provider and Relying Party. These are frequently abbreviated as AP and RP, respectively.spring-doc.cn
Runtime Expectations
As configured earlier, the application processes any POST /login/saml2/sso/{registrationId} request containing a SAMLResponse parameter:spring-doc.cn
POST /login/saml2/sso/adfs HTTP/1.1
SAMLResponse=PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZ...
There are two ways to induce your asserting party to generate a SAMLResponse:spring-doc.cn
  • You can navigate to your asserting party. It likely has some kind of link or button for each registered relying party that you can click to send the SAMLResponse.spring-doc.cn
  • You can navigate to a protected page in your application — for example, localhost:8080. Your application then redirects to the configured asserting party, which then sends the SAMLResponse.spring-doc.cn
From here, consider jumping to:spring-doc.cn
How SAML 2.0 Login Integrates with OpenSAML
Spring Security’s SAML 2.0 support has a couple of design goals:spring-doc.cn
  • Rely on a library for SAML 2.0 operations and domain objects. To achieve this, Spring Security uses OpenSAML.spring-doc.cn
  • Ensure that this library is not required when using Spring Security’s SAML support. To achieve this, any interfaces or classes where Spring Security uses OpenSAML in the contract remain encapsulated. This makes it possible for you to switch out OpenSAML for some other library or an unsupported version of OpenSAML.spring-doc.cn
As a natural outcome of these two goals, Spring Security’s SAML API is quite small relative to other modules. Instead, such classes as OpenSamlAuthenticationRequestFactory and OpenSamlAuthenticationProvider expose Converter implementations that customize various steps in the authentication process.spring-doc.cn
For example, once your application receives a SAMLResponse and delegates to Saml2WebSsoAuthenticationFilter, the filter delegates to OpenSamlAuthenticationProvider:spring-doc.cn
Authenticating an OpenSAML Response
opensamlauthenticationproviderspring-doc.cn
number 1 The Saml2WebSsoAuthenticationFilter formulates the Saml2AuthenticationToken and invokes the AuthenticationManager.spring-doc.cn
number 2 The AuthenticationManager invokes the OpenSAML authentication provider.spring-doc.cn
number 3 The authentication provider deserializes the response into an OpenSAML Response and checks its signature. If the signature is invalid, authentication fails.spring-doc.cn
number 4 Then the provider decrypts any EncryptedAssertion elements. If any decryptions fail, authentication fails.spring-doc.cn
number 5 Next, the provider validates the response’s Issuer and Destination values. If they do not match what’s in the RelyingPartyRegistration, authentication fails.spring-doc.cn
number 6 After that, the provider verifies the signature of each Assertion. If any signature is invalid, authentication fails. Also, if neither the response nor the assertions have signatures, authentication fails. Either the response or all the assertions must have signatures.spring-doc.cn
number 7 Then, the provider ,decrypts any EncryptedID or EncryptedAttribute elements]. If any decryptions fail, authentication fails.spring-doc.cn
number 8 Next, the provider validates each assertion’s ExpiresAt and NotBefore timestamps, the <Subject> and any <AudienceRestriction> conditions. If any validations fail, authentication fails.spring-doc.cn
number 9 Following that, the provider takes the first assertion’s AttributeStatement and maps it to a Map<String, List<Object>>. It also grants the ROLE_USER granted authority.spring-doc.cn
number 10 And finally, it takes the NameID from the first assertion, the Map of attributes, and the GrantedAuthority and constructs a Saml2AuthenticatedPrincipal. Then, it places that principal and the authorities into a Saml2Authentication.spring-doc.cn
The resulting Authentication#getPrincipal is a Spring Security Saml2AuthenticatedPrincipal object, and Authentication#getName maps to the first assertion’s NameID element. Saml2AuthenticatedPrincipal#getRelyingPartyRegistrationId holds the identifier to the associated RelyingPartyRegistration.spring-doc.cn
Customizing OpenSAML Configuration
Any class that uses both Spring Security and OpenSAML should statically initialize OpenSamlInitializationService at the beginning of the class:spring-doc.cn
static {
	OpenSamlInitializationService.initialize();
companion object {
    init {
This replaces OpenSAML’s InitializationService#initialize.spring-doc.cn
Occasionally, it can be valuable to customize how OpenSAML builds, marshalls, and unmarshalls SAML objects. In these circumstances, you may instead want to call OpenSamlInitializationService#requireInitialize(Consumer) that gives you access to OpenSAML’s XMLObjectProviderFactory.spring-doc.cn
For example, when sending an unsigned AuthNRequest, you may want to force reauthentication. In that case, you can register your own AuthnRequestMarshaller, like so:spring-doc.cn
static {
    OpenSamlInitializationService.requireInitialize(factory -> {
        AuthnRequestMarshaller marshaller = new AuthnRequestMarshaller() {
            public Element marshall(XMLObject object, Element element) throws MarshallingException {
                configureAuthnRequest((AuthnRequest) object);
                return super.marshall(object, element);
            public Element marshall(XMLObject object, Document document) throws MarshallingException {
                return super.marshall(object, document);
            private void configureAuthnRequest(AuthnRequest authnRequest) {
                authnRequest.setForceAuthn(true);
        factory.getMarshallerFactory().registerMarshaller(AuthnRequest.DEFAULT_ELEMENT_NAME, marshaller);
companion object {
    init {
        OpenSamlInitializationService.requireInitialize {
            val marshaller = object : AuthnRequestMarshaller() {
                override fun marshall(xmlObject: XMLObject, element: Element): Element {
                    configureAuthnRequest(xmlObject as AuthnRequest)
                    return super.marshall(xmlObject, element)
                override fun marshall(xmlObject: XMLObject, document: Document): Element {
                    return super.marshall(xmlObject, document)
                private fun configureAuthnRequest(authnRequest: AuthnRequest) {
                    authnRequest.isForceAuthn = true
            it.marshallerFactory.registerMarshaller(AuthnRequest.DEFAULT_ELEMENT_NAME, marshaller)
The requireInitialize method may be called only once per application instance.spring-doc.cn
Overriding or Replacing Boot Auto Configuration
Spring Boot generates two @Bean objects for a relying party.spring-doc.cn
The first is a SecurityFilterChain that configures the application as a relying party. When including spring-security-saml2-service-provider, the SecurityFilterChain looks like:spring-doc.cn
Default SAML 2.0 Login Configuration
    http
            .anyRequest().authenticated()
        .saml2Login(withDefaults());
    return http.build();
    http {
        authorizeRequests {
        saml2Login { }
    return http.build()
If the application does not expose a SecurityFilterChain bean, Spring Boot exposes the preceding default one.spring-doc.cn
You can replace this by exposing the bean within the application:spring-doc.cn
Custom SAML 2.0 Login Configuration
@EnableWebSecurity
public class MyCustomSecurityConfiguration {
        http
                .requestMatchers("/messages/**").hasAuthority("ROLE_USER")
@EnableWebSecurity
        http {
            authorizeRequests {
                authorize("/messages/**", hasAuthority("ROLE_USER"))
            saml2Login {
        return http.build()
The preceding example requires the role of USER for any URL that starts with /messages/.spring-doc.cn
The second @Bean Spring Boot creates is a RelyingPartyRegistrationRepository, which represents the asserting party and relying party metadata. This includes such things as the location of the SSO endpoint the relying party should use when requesting authentication from the asserting party.spring-doc.cn
You can override the default by publishing your own RelyingPartyRegistrationRepository bean. For example, you can look up the asserting party’s configuration by hitting its metadata endpoint:spring-doc.cn
Relying Party Registration Repository
@Value("${metadata.location}")
String assertingPartyMetadataLocation;
public RelyingPartyRegistrationRepository relyingPartyRegistrations() {
    RelyingPartyRegistration registration = RelyingPartyRegistrations
            .fromMetadataLocation(assertingPartyMetadataLocation)
            .registrationId("example")
    return new InMemoryRelyingPartyRegistrationRepository(registration);
@Value("\${metadata.location}")
var assertingPartyMetadataLocation: String? = null
open fun relyingPartyRegistrations(): RelyingPartyRegistrationRepository? {
    val registration = RelyingPartyRegistrations
        .build()
    return InMemoryRelyingPartyRegistrationRepository(registration)
The registrationId is an arbitrary value that you choose for differentiating between registrations.
Alternatively, you can provide each detail manually:spring-doc.cn
Relying Party Registration Repository Manual Configuration
@Value("${verification.key}")
File verificationKey;
public RelyingPartyRegistrationRepository relyingPartyRegistrations() throws Exception {
    X509Certificate certificate = X509Support.decodeCertificate(this.verificationKey);
    Saml2X509Credential credential = Saml2X509Credential.verification(certificate);
            .withRegistrationId("example")
            .assertingPartyDetails(party -> party
                .entityId("https://idp.example.com/issuer")
                .singleSignOnServiceLocation("https://idp.example.com/SSO.saml2")
                .wantAuthnRequestsSigned(false)
                .verificationX509Credentials(c -> c.add(credential))
@Value("\${verification.key}")
var verificationKey: File? = null
open fun relyingPartyRegistrations(): RelyingPartyRegistrationRepository {
    val certificate: X509Certificate? = X509Support.decodeCertificate(verificationKey!!)
    val credential: Saml2X509Credential = Saml2X509Credential.verification(certificate)
        .assertingPartyDetails { party: AssertingPartyDetails.Builder ->
            party
                .verificationX509Credentials { c: MutableCollection<Saml2X509Credential?> ->
                    c.add(
                        credential
        .build()
X509Support is an OpenSAML class, used in the preceding snippet for brevity.spring-doc.cn
Alternatively, you can directly wire up the repository by using the DSL, which also overrides the auto-configured SecurityFilterChain:spring-doc.cn
Custom Relying Party Registration DSL
@EnableWebSecurity
        http
            .saml2Login(saml2 -> saml2
                .relyingPartyRegistrationRepository(relyingPartyRegistrations())
@EnableWebSecurity
        http {
            authorizeRequests {
            saml2Login {
                relyingPartyRegistrationRepository = relyingPartyRegistrations()
        return http.build()
A relying party can be multi-tenant by registering more than one relying party in the RelyingPartyRegistrationRepository.spring-doc.cn
A RelyingPartyRegistration instance represents a link between an relying party and an asserting party’s metadata.spring-doc.cn
In a RelyingPartyRegistration, you can provide relying party metadata like its Issuer value, where it expects SAML Responses to be sent to, and any credentials that it owns for the purposes of signing or decrypting payloads.spring-doc.cn
Also, you can provide asserting party metadata like its Issuer value, where it expects AuthnRequests to be sent to, and any public credentials that it owns for the purposes of the relying party verifying or encrypting payloads.spring-doc.cn
The following RelyingPartyRegistration is the minimum required for most setups:spring-doc.cn
RelyingPartyRegistration relyingPartyRegistration = RelyingPartyRegistrations
        .fromMetadataLocation("https://ap.example.org/metadata")
        .registrationId("my-id")
val relyingPartyRegistration = RelyingPartyRegistrations
    .build()
Note that you can also create a RelyingPartyRegistration from an arbitrary InputStream source. One such example is when the metadata is stored in a database:spring-doc.cn
String xml = fromDatabase();
try (InputStream source = new ByteArrayInputStream(xml.getBytes())) {
            .fromMetadata(source)
A more sophisticated setup is also possible:spring-doc.cn
RelyingPartyRegistration relyingPartyRegistration = RelyingPartyRegistration.withRegistrationId("my-id")
        .entityId("{baseUrl}/{registrationId}")
        .decryptionX509Credentials(c -> c.add(relyingPartyDecryptingCredential()))
        .assertionConsumerServiceLocation("/my-login-endpoint/{registrationId}")
                .entityId("https://ap.example.org")
                .verificationX509Credentials(c -> c.add(assertingPartyVerifyingCredential()))
                .singleSignOnServiceLocation("https://ap.example.org/SSO.saml2")
        .decryptionX509Credentials { c: MutableCollection<Saml2X509Credential?> ->
        .assertingPartyDetails { party -> party
                .verificationX509Credentials { c -> c.add(assertingPartyVerifyingCredential()) }
        .build()
The top-level metadata methods are details about the relying party. The methods inside assertingPartyDetails are details about the asserting party.spring-doc.cn
The location where a relying party is expecting SAML Responses is the Assertion Consumer Service Location.spring-doc.cn
The default for the relying party’s entityId is {baseUrl}/saml2/service-provider-metadata/{registrationId}. This is this value needed when configuring the asserting party to know about your relying party.spring-doc.cn
The default for the assertionConsumerServiceLocation is /login/saml2/sso/{registrationId}. By default, it is mapped to Saml2WebSsoAuthenticationFilter in the filter chain.spring-doc.cn
URI Patterns
You probably noticed the {baseUrl} and {registrationId} placeholders in the preceding examples.spring-doc.cn
These are useful for generating URIs. As a result, the relying party’s entityId and assertionConsumerServiceLocation support the following placeholders:spring-doc.cn
  • baseUrl - the scheme, host, and port of a deployed applicationspring-doc.cn
  • registrationId - the registration id for this relying partyspring-doc.cn
  • baseScheme - the scheme of a deployed applicationspring-doc.cn
  • baseHost - the host of a deployed applicationspring-doc.cn
  • basePort - the port of a deployed applicationspring-doc.cn
For example, the assertionConsumerServiceLocation defined earlier was:spring-doc.cn
/my-login-endpoint/{registrationId}spring-doc.cn
In a deployed application, it translates to:spring-doc.cn
/my-login-endpoint/adfsspring-doc.cn
The entityId shown earlier was defined as:spring-doc.cn
{baseUrl}/{registrationId}spring-doc.cn
In a deployed application, that translates to:spring-doc.cn
https://rp.example.com/adfsspring-doc.cn
The prevailing URI patterns are as follows:spring-doc.cn
Since the registrationId is the primary identifier for a RelyingPartyRegistration, it is needed in the URL for unauthenticated scenarios. If you wish to remove the registrationId from the URL for any reason, you can specify a RelyingPartyRegistrationResolver to tell Spring Security how to look up the registrationId.spring-doc.cn
Credentials
In the example shown earlier, you also likely noticed the credential that was used.spring-doc.cn
Oftentimes, a relying party uses the same key to sign payloads as well as decrypt them. Alternatively, it can use the same key to verify payloads as well as encrypt them.spring-doc.cn
Because of this, Spring Security ships with Saml2X509Credential, a SAML-specific credential that simplifies configuring the same key for different use cases.spring-doc.cn
At a minimum, you need to have a certificate from the asserting party so that the asserting party’s signed responses can be verified.spring-doc.cn
To construct a Saml2X509Credential that you can use to verify assertions from the asserting party, you can load the file and use the CertificateFactory:spring-doc.cn
Resource resource = new ClassPathResource("ap.crt");
try (InputStream is = resource.getInputStream()) {
    X509Certificate certificate = (X509Certificate)
            CertificateFactory.getInstance("X.509").generateCertificate(is);
    return Saml2X509Credential.verification(certificate);
val resource = ClassPathResource("ap.crt")
resource.inputStream.use {
        CertificateFactory.getInstance("X.509").generateCertificate(it) as X509Certificate?
Suppose that the asserting party is going to also encrypt the assertion. In that case, the relying party needs a private key to decrypt the encrypted value.spring-doc.cn
In that case, you need an RSAPrivateKey as well as its corresponding X509Certificate. You can load the first by using Spring Security’s RsaKeyConverters utility class and the second as you did before:spring-doc.cn
X509Certificate certificate = relyingPartyDecryptionCertificate();
Resource resource = new ClassPathResource("rp.crt");
    RSAPrivateKey rsa = RsaKeyConverters.pkcs8().convert(is);
    return Saml2X509Credential.decryption(rsa, certificate);
val certificate: X509Certificate = relyingPartyDecryptionCertificate()
val resource = ClassPathResource("rp.crt")
    val rsa: RSAPrivateKey = RsaKeyConverters.pkcs8().convert(it)
When you specify the locations of these files as the appropriate Spring Boot properties, Spring Boot performs these conversions for you.spring-doc.cn
Duplicated Relying Party Configurations
When an application uses multiple asserting parties, some configuration is duplicated between RelyingPartyRegistration instances:spring-doc.cn
This setup may let credentials be more easily rotated for some identity providers versus others.spring-doc.cn
The duplication can be alleviated in a few different ways.spring-doc.cn
First, in YAML this can be alleviated with references:spring-doc.cn
spring:
  security:
    saml2:
      relyingparty:
        okta:
          signing.credentials: &relying-party-credentials
            - private-key-location: classpath:rp.key
              certificate-location: classpath:rp.crt
          identityprovider:
            entity-id: ...
        azure:
          signing.credentials: *relying-party-credentials
          identityprovider:
            entity-id: ...
Second, in a database, you need not replicate the model of RelyingPartyRegistration.spring-doc.cn
Third, in Java, you can create a custom configuration method:spring-doc.cn
private RelyingPartyRegistration.Builder
        addRelyingPartyDetails(RelyingPartyRegistration.Builder builder) {
    Saml2X509Credential signingCredential = ...
    builder.signingX509Credentials(c -> c.addAll(signingCredential));
    // ... other relying party configurations
    RelyingPartyRegistration okta = addRelyingPartyDetails(
                .fromMetadataLocation(oktaMetadataUrl)
                .registrationId("okta")).build();
    RelyingPartyRegistration azure = addRelyingPartyDetails(
                .registrationId("azure")).build();
    return new InMemoryRelyingPartyRegistrationRepository(okta, azure);
private fun addRelyingPartyDetails(builder: RelyingPartyRegistration.Builder): RelyingPartyRegistration.Builder {
    val signingCredential: Saml2X509Credential = ...
    builder.signingX509Credentials { c: MutableCollection<Saml2X509Credential?> ->
        c.add(
            signingCredential
    val okta = addRelyingPartyDetails(
    ).build()
    val azure = addRelyingPartyDetails(
    ).build()
    return InMemoryRelyingPartyRegistrationRepository(okta, azure)
Resolving the RelyingPartyRegistration from the Request
As seen so far, Spring Security resolves the RelyingPartyRegistration by looking for the registration id in the URI path.spring-doc.cn
Depending on the use case, a number of other strategies are also employed to derive one. For example:spring-doc.cn
  • For processing <saml2:Response>`s, the `RelyingPartyRegistration is looked up from the associated <saml2:AuthRequest> or from the <saml2:Response#Issuer> elementspring-doc.cn
  • For processing <saml2:LogoutRequest>`s, the `RelyingPartyRegistration is looked up from the currently logged in user or from the <saml2:LogoutRequest#Issuer> elementspring-doc.cn
  • For publishing metadata, the RelyingPartyRegistration`s are looked up from any repository that also implements `Iterable<RelyingPartyRegistration>spring-doc.cn
When this needs adjustment, you can turn to the specific components for each of these endpoints targeted at customizing this:spring-doc.cn
  • For SAML Responses, customize the AuthenticationConverterspring-doc.cn
  • For Logout Requests, customize the Saml2LogoutRequestValidatorParametersResolverspring-doc.cn
  • For Metadata, customize the Saml2MetadataResponseResolverspring-doc.cn
Federating Login
One common arrangement with SAML 2.0 is an identity provider that has multiple asserting parties. In this case, the identity provider’s metadata endpoint returns multiple <md:IDPSSODescriptor> elements.spring-doc.cn
These multiple asserting parties can be accessed in a single call to RelyingPartyRegistrations like so:spring-doc.cn
Collection<RelyingPartyRegistration> registrations = RelyingPartyRegistrations
        .collectionFromMetadataLocation("https://example.org/saml2/idp/metadata.xml")
        .stream().map((builder) -> builder
            .registrationId(UUID.randomUUID().toString())
            .entityId("https://example.org/saml2/sp")
            .build()
        .collect(Collectors.toList());
var registrations: Collection<RelyingPartyRegistration> = RelyingPartyRegistrations
        .stream().map { builder : RelyingPartyRegistration.Builder -> builder
            .assertionConsumerServiceLocation("{baseUrl}/login/saml2/sso")
            .build()
Note that because the registration id is set to a random value, this will change certain SAML 2.0 endpoints to be unpredictable. There are several ways to address this; let’s focus on a way that suits the specific use case of federation.spring-doc.cn
In many federation cases, all the asserting parties share service provider configuration. Given that Spring Security will by default include the registrationId in the service provider metadata, another step is to change corresponding URIs to exclude the registrationId, which you can see has already been done in the above sample where the entityId and assertionConsumerServiceLocation are configured with a static endpoint.spring-doc.cn
You can see a completed example of this in our saml-extension-federation sample.spring-doc.cn
Using Spring Security SAML Extension URIs
In the event that you are migrating from the Spring Security SAML Extension, there may be some benefit to configuring your application to use the SAML Extension URI defaults.spring-doc.cn
For more information on this, please see our custom-urls sample and our saml-extension-federation sample.spring-doc.cn
