This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Security 6.4.3! |
Architecture
This section discusses Spring Security’s high-level architecture within Servlet based applications. We build on this high-level understanding within the Authentication, Authorization, and Protection Against Exploits sections of the reference.
A Review of Filters
Spring Security’s Servlet support is based on Servlet Filters, so it is helpful to look at the role of Filters generally first. The following image shows the typical layering of the handlers for a single HTTP request.
The client sends a request to the application, and the container creates a FilterChain
, which contains the Filter
instances and Servlet
that should process the HttpServletRequest
, based on the path of the request URI.
In a Spring MVC application, the Servlet
is an instance of DispatcherServlet
At most, one Servlet
can handle a single HttpServletRequest
and HttpServletResponse
However, more than one Filter
can be used to:
Prevent downstream
Filter
instances or theServlet
from being invoked. In this case, theFilter
typically writes theHttpServletResponse
Modify the
HttpServletRequest
orHttpServletResponse
used by the downstreamFilter
instances and theServlet
The power of the Filter
comes from the FilterChain
that is passed into it.
FilterChain
Usage Example-
Java
Kotlin
public void doFilter(ServletRequest request, ServletResponse response, FilterChain chain) {
// do something before the rest of the application
chain.doFilter(request, response); // invoke the rest of the application
// do something after the rest of the application
fun doFilter(request: ServletRequest, response: ServletResponse, chain: FilterChain) {
chain.doFilter(request, response) // invoke the rest of the application
Since a Filter
impacts only downstream Filter
instances and the Servlet
, the order in which each Filter
is invoked is extremely important.
DelegatingFilterProxy
Spring provides a Filter
implementation named DelegatingFilterProxy
that allows bridging between the Servlet container’s lifecycle and Spring’s ApplicationContext
The Servlet container allows registering Filter
instances by using its own standards, but it is not aware of Spring-defined Beans.
You can register DelegatingFilterProxy
through the standard Servlet container mechanisms but delegate all the work to a Spring Bean that implements Filter
Here is a picture of how DelegatingFilterProxy
fits into the Filter
instances and the FilterChain
looks up Bean Filter0 from the ApplicationContext
and then invokes Bean Filter0.
The following listing shows pseudo code of DelegatingFilterProxy
Pseudo Code-
Java
Kotlin
Filter delegate = getFilterBean(someBeanName); (1)
delegate.doFilter(request, response); (2)
val delegate: Filter = getFilterBean(someBeanName) (1)
delegate.doFilter(request, response) (2)
1 | Lazily get Filter that was registered as a Spring Bean.
For the example in DelegatingFilterProxy delegate is an instance of Bean Filter0. |
2 | Delegate work to the Spring Bean. |
Another benefit of DelegatingFilterProxy
is that it allows delaying looking up Filter
bean instances.
This is important because the container needs to register the Filter
instances before the container can start up.
However, Spring typically uses a ContextLoaderListener
to load the Spring Beans, which is not done until after the Filter
instances need to be registered.
FilterChainProxy
Spring Security’s Servlet support is contained within FilterChainProxy
FilterChainProxy
is a special Filter
provided by Spring Security that allows delegating to many Filter
instances through SecurityFilterChain
Since FilterChainProxy
is a Bean, it is typically wrapped in a DelegatingFilterProxy.
The following image shows the role of FilterChainProxy
SecurityFilterChain
SecurityFilterChain
is used by FilterChainProxy to determine which Spring Security Filter
instances should be invoked for the current request.
The following image shows the role of SecurityFilterChain
The Security Filters in SecurityFilterChain
are typically Beans, but they are registered with FilterChainProxy
instead of DelegatingFilterProxy.
FilterChainProxy
provides a number of advantages to registering directly with the Servlet container or DelegatingFilterProxy.
First, it provides a starting point for all of Spring Security’s Servlet support.
For that reason, if you try to troubleshoot Spring Security’s Servlet support, adding a debug point in FilterChainProxy
is a great place to start.
Second, since FilterChainProxy
is central to Spring Security usage, it can perform tasks that are not viewed as optional.
For example, it clears out the SecurityContext
to avoid memory leaks.
It also applies Spring Security’s HttpFirewall
to protect applications against certain types of attacks.
In addition, it provides more flexibility in determining when a SecurityFilterChain
should be invoked.
In a Servlet container, Filter
instances are invoked based upon the URL alone.
However, FilterChainProxy
can determine invocation based upon anything in the HttpServletRequest
by using the RequestMatcher
interface.
The following image shows multiple SecurityFilterChain
instances:
In the Multiple SecurityFilterChain figure, FilterChainProxy
decides which SecurityFilterChain
should be used.
Only the first SecurityFilterChain
that matches is invoked.
If a URL of /api/messages/
is requested, it first matches on the SecurityFilterChain0
pattern of /api/**
, so only SecurityFilterChain0
is invoked, even though it also matches on SecurityFilterChainn
If a URL of /messages/
is requested, it does not match on the SecurityFilterChain0
pattern of /api/**
, so FilterChainProxy
continues trying each SecurityFilterChain
Assuming that no other SecurityFilterChain
instances match, SecurityFilterChainn
is invoked.
Notice that SecurityFilterChain0
has only three security Filter
instances configured.
However, SecurityFilterChainn
has four security Filter
It is important to note that each SecurityFilterChain
can be unique and can be configured in isolation.
In fact, a SecurityFilterChain
might have zero security Filter
instances if the application wants Spring Security to ignore certain requests.
Security Filters
The Security Filters are inserted into the FilterChainProxy with the SecurityFilterChain API.
Those filters can be used for a number of different purposes, like authentication, authorization, exploit protection, and more.
The filters are executed in a specific order to guarantee that they are invoked at the right time, for example, the Filter
that performs authentication should be invoked before the Filter
that performs authorization.
It is typically not necessary to know the ordering of Spring Security’s Filter
s.
However, there are times that it is beneficial to know the ordering, if you want to know them, you can check the FilterOrderRegistration
code.
To exemplify the above paragraph, let’s consider the following security configuration:
Java
Kotlin
@EnableWebSecurity
public class SecurityConfig {
http
.csrf(Customizer.withDefaults())
.anyRequest().authenticated()
.httpBasic(Customizer.withDefaults())
.formLogin(Customizer.withDefaults());
return http.build();
import org.springframework.security.config.web.servlet.invoke
@EnableWebSecurity
fun filterChain(http: HttpSecurity): SecurityFilterChain {
http {
csrf { }
authorizeHttpRequests {
httpBasic { }
formLogin { }
return http.build()
The above configuration will result in the following Filter
ordering:
Filter | Added by |
First, the
CsrfFilter
is invoked to protect against CSRF attacks. -
Second, the authentication filters are invoked to authenticate the request.
Third, the
AuthorizationFilter
is invoked to authorize the request.
There might be other |
Printing the Security Filters
Often times, it is useful to see the list of security Filter
s that are invoked for a particular request.
For example, you want to make sure that the filter you have added is in the list of the security filters.
The list of filters is printed at INFO level on the application startup, so you can see something like the following on the console output for example:
2023-06-14T08:55:22.321-03:00 INFO 76975 --- [ main] o.s.s.web.DefaultSecurityFilterChain : Will secure any request with [
org.springframework.security.web.session.DisableEncodeUrlFilter@404db674,
org.springframework.security.web.context.request.async.WebAsyncManagerIntegrationFilter@50f097b5,
org.springframework.security.web.context.SecurityContextHolderFilter@6fc6deb7,
org.springframework.security.web.header.HeaderWriterFilter@6f76c2cc,
org.springframework.security.web.csrf.CsrfFilter@c29fe36,
org.springframework.security.web.authentication.logout.LogoutFilter@ef60710,
org.springframework.security.web.authentication.UsernamePasswordAuthenticationFilter@7c2dfa2,
org.springframework.security.web.authentication.ui.DefaultLoginPageGeneratingFilter@4397a639,
org.springframework.security.web.authentication.ui.DefaultLogoutPageGeneratingFilter@7add838c,
org.springframework.security.web.authentication.www.BasicAuthenticationFilter@5cc9d3d0,
org.springframework.security.web.savedrequest.RequestCacheAwareFilter@7da39774,
org.springframework.security.web.servletapi.SecurityContextHolderAwareRequestFilter@32b0876c,
org.springframework.security.web.authentication.AnonymousAuthenticationFilter@3662bdff,
org.springframework.security.web.access.ExceptionTranslationFilter@77681ce4,
org.springframework.security.web.access.intercept.AuthorizationFilter@169268a7]
And that will give a pretty good idea of the security filters that are configured for each filter chain.
But that is not all, you can also configure your application to print the invocation of each individual filter for each request. That is helpful to see if the filter you have added is invoked for a particular request or to check where an exception is coming from. To do that, you can configure your application to log the security events.
Adding a Custom Filter to the Filter Chain
Most of the time, the default security filters are enough to provide security to your application.
However, there might be times that you want to add a custom Filter
to the security filter chain.
For example, let’s say that you want to add a Filter
that gets a tenant id header and check if the current user has access to that tenant.
The previous description already gives us a clue on where to add the filter, since we need to know the current user, we need to add it after the authentication filters.
First, let’s create the Filter
import java.io.IOException;
import jakarta.servlet.Filter;
import jakarta.servlet.FilterChain;
import jakarta.servlet.ServletException;
import jakarta.servlet.ServletRequest;
import jakarta.servlet.ServletResponse;
import jakarta.servlet.http.HttpServletRequest;
import jakarta.servlet.http.HttpServletResponse;
import org.springframework.security.access.AccessDeniedException;
public class TenantFilter implements Filter {
public void doFilter(ServletRequest servletRequest, ServletResponse servletResponse, FilterChain filterChain) throws IOException, ServletException {
HttpServletRequest request = (HttpServletRequest) servletRequest;
HttpServletResponse response = (HttpServletResponse) servletResponse;
String tenantId = request.getHeader("X-Tenant-Id"); (1)
boolean hasAccess = isUserAllowed(tenantId); (2)
if (hasAccess) {
filterChain.doFilter(request, response); (3)
return;
throw new AccessDeniedException("Access denied"); (4)
The sample code above does the following:
1 | Get the tenant id from the request header. |
2 | Check if the current user has access to the tenant id. |
3 | If the user has access, then invoke the rest of the filters in the chain. |
4 | If the user does not have access, then throw an AccessDeniedException . |
Instead of implementing |
Now, we need to add the filter to the security filter chain.
Java
Kotlin
http
.addFilterBefore(new TenantFilter(), AuthorizationFilter.class); (1)
http
.addFilterBefore(TenantFilter(), AuthorizationFilter::class.java) (1)
return http.build()
1 | Use HttpSecurity#addFilterBefore to add the TenantFilter before the AuthorizationFilter . |
By adding the filter before the AuthorizationFilter
we are making sure that the TenantFilter
is invoked after the authentication filters.
You can also use HttpSecurity#addFilterAfter
to add the filter after a particular filter or HttpSecurity#addFilterAt
to add the filter at a particular filter position in the filter chain.
And that’s it, now the TenantFilter
will be invoked in the filter chain and will check if the current user has access to the tenant id.
Be careful when you declare your filter as a Spring bean, either by annotating it with @Component
or by declaring it as a bean in your configuration, because Spring Boot will automatically register it with the embedded container.
That may cause the filter to be invoked twice, once by the container and once by Spring Security and in a different order.
If you still want to declare your filter as a Spring bean to take advantage of dependency injection for example, and avoid the duplicate invocation, you can tell Spring Boot to not register it with the container by declaring a FilterRegistrationBean
bean and setting its enabled
property to false
public FilterRegistrationBean<TenantFilter> tenantFilterRegistration(TenantFilter filter) {
FilterRegistrationBean<TenantFilter> registration = new FilterRegistrationBean<>(filter);
registration.setEnabled(false);
return registration;
Handling Security Exceptions
The ExceptionTranslationFilter
allows translation of AccessDeniedException
and AuthenticationException
into HTTP responses.
is inserted into the FilterChainProxy as one of the Security Filters.
The following image shows the relationship of ExceptionTranslationFilter
to other components:
First, the
invokesFilterChain.doFilter(request, response)
to invoke the rest of the application. -
If the user is not authenticated or it is an
, then Start Authentication.-
The SecurityContextHolder is cleared out.
The
HttpServletRequest
is saved so that it can be used to replay the original request once authentication is successful. -
The
AuthenticationEntryPoint
is used to request credentials from the client. For example, it might redirect to a log in page or send aWWW-Authenticate
header.
Otherwise, if it is an
, then Access Denied. TheAccessDeniedHandler
is invoked to handle access denied.
If the application does not throw an |
The pseudocode for ExceptionTranslationFilter
looks something like this:
try {
filterChain.doFilter(request, response); (1)
} catch (AccessDeniedException | AuthenticationException ex) {
if (!authenticated || ex instanceof AuthenticationException) {
startAuthentication(); (2)
} else {
accessDenied(); (3)
1 | As described in A Review of Filters, invoking FilterChain.doFilter(request, response) is the equivalent of invoking the rest of the application.
This means that if another part of the application, (FilterSecurityInterceptor or method security) throws an AuthenticationException or AccessDeniedException it is caught and handled here. |
2 | If the user is not authenticated or it is an AuthenticationException , Start Authentication. |
3 | Otherwise, Access Denied |
Saving Requests Between Authentication
As illustrated in Handling Security Exceptions, when a request has no authentication and is for a resource that requires authentication, there is a need to save the request for the authenticated resource to re-request after authentication is successful.
In Spring Security this is done by saving the HttpServletRequest
using a RequestCache
implementation.
RequestCache
The HttpServletRequest
is saved in the RequestCache
When the user successfully authenticates, the RequestCache
is used to replay the original request.
The RequestCacheAwareFilter
uses the RequestCache
to get the saved HttpServletRequest
after the user authenticates, while the ExceptionTranslationFilter
to save the HttpServletRequest
after it detects AuthenticationException
, before redirecting the user to the login endpoint.
By default, an HttpSessionRequestCache
is used.
The code below demonstrates how to customize the RequestCache
implementation that is used to check the HttpSession
for a saved request if the parameter named continue
is present.
RequestCache
Only Checks for Saved Requests if continue
Parameter Present-
Java
Kotlin
XML
DefaultSecurityFilterChain springSecurity(HttpSecurity http) throws Exception {
HttpSessionRequestCache requestCache = new HttpSessionRequestCache();
requestCache.setMatchingRequestParameterName("continue");
http
.requestCache((cache) -> cache
.requestCache(requestCache)
open fun springSecurity(http: HttpSecurity): SecurityFilterChain {
val httpRequestCache = HttpSessionRequestCache()
httpRequestCache.setMatchingRequestParameterName("continue")
http {
requestCache {
requestCache = httpRequestCache
return http.build()
<http auto-config="true">
<request-cache ref="requestCache"/>
</http>
<b:bean id="requestCache" class="org.springframework.security.web.savedrequest.HttpSessionRequestCache"
p:matchingRequestParameterName="continue"/>
Prevent the Request From Being Saved
There are a number of reasons you may want to not store the user’s unauthenticated request in the session. You may want to offload that storage onto the user’s browser or store it in a database. Or you may want to shut off this feature since you always want to redirect the user to the home page instead of the page they tried to visit before login.
To do that, you can use the NullRequestCache
implementation.
Java
Kotlin
XML
RequestCache nullRequestCache = new NullRequestCache();
http
.requestCache(nullRequestCache)
val nullRequestCache = NullRequestCache()
http {
requestCache {
requestCache = nullRequestCache
return http.build()
<request-cache ref="nullRequestCache"/>
</http>
<b:bean id="nullRequestCache" class="org.springframework.security.web.savedrequest.NullRequestCache"/>
Logging
Spring Security provides comprehensive logging of all security related events at the DEBUG and TRACE level. This can be very useful when debugging your application because for security measures Spring Security does not add any detail of why a request has been rejected to the response body. If you come across a 401 or 403 error, it is very likely that you will find a log message that will help you understand what is going on.
Let’s consider an example where a user tries to make a POST
request to a resource that has CSRF protection enabled without the CSRF token.
With no logs, the user will see a 403 error with no explanation of why the request was rejected.
However, if you enable logging for Spring Security, you will see a log message like this:
2023-06-14T09:44:25.797-03:00 DEBUG 76975 --- [nio-8080-exec-1] o.s.security.web.FilterChainProxy : Securing POST /hello
2023-06-14T09:44:25.797-03:00 TRACE 76975 --- [nio-8080-exec-1] o.s.security.web.FilterChainProxy : Invoking DisableEncodeUrlFilter (1/15)
2023-06-14T09:44:25.798-03:00 TRACE 76975 --- [nio-8080-exec-1] o.s.security.web.FilterChainProxy : Invoking WebAsyncManagerIntegrationFilter (2/15)
2023-06-14T09:44:25.800-03:00 TRACE 76975 --- [nio-8080-exec-1] o.s.security.web.FilterChainProxy : Invoking SecurityContextHolderFilter (3/15)
2023-06-14T09:44:25.801-03:00 TRACE 76975 --- [nio-8080-exec-1] o.s.security.web.FilterChainProxy : Invoking HeaderWriterFilter (4/15)
2023-06-14T09:44:25.802-03:00 TRACE 76975 --- [nio-8080-exec-1] o.s.security.web.FilterChainProxy : Invoking CsrfFilter (5/15)
2023-06-14T09:44:25.814-03:00 DEBUG 76975 --- [nio-8080-exec-1] o.s.security.web.csrf.CsrfFilter : Invalid CSRF token found for http://localhost:8080/hello
2023-06-14T09:44:25.814-03:00 DEBUG 76975 --- [nio-8080-exec-1] o.s.s.w.access.AccessDeniedHandlerImpl : Responding with 403 status code
2023-06-14T09:44:25.814-03:00 TRACE 76975 --- [nio-8080-exec-1] o.s.s.w.header.writers.HstsHeaderWriter : Not injecting HSTS header since it did not match request to [Is Secure]
It becomes clear that the CSRF token is missing and that is why the request is being denied.
To configure your application to log all the security events, you can add the following to your application:
logging.level.org.springframework.security=TRACE
<configuration>
<appender name="STDOUT" class="ch.qos.logback.core.ConsoleAppender">
</appender>
<logger name="org.springframework.security" level="trace" additivity="false">
<appender-ref ref="Console" />
</logger>
</configuration>
