Producing <saml2:AuthnRequest>s
As stated earlier, Spring Security’s SAML 2.0 support produces a <saml2:AuthnRequest> to commence authentication with the asserting party.spring-doc.cn
Spring Security achieves this in part by registering the Saml2WebSsoAuthenticationRequestFilter in the filter chain. This filter by default responds to endpoint /saml2/authenticate/{registrationId}.spring-doc.cn
For example, if you were deployed to rp.example.com and you gave your registration an ID of okta, you could navigate to:spring-doc.cn
and the result would be a redirect that included a SAMLRequest parameter containing the signed, deflated, and encoded <saml2:AuthnRequest>.spring-doc.cn
Changing How the <saml2:AuthnRequest> Gets Stored
Saml2WebSsoAuthenticationRequestFilter uses an Saml2AuthenticationRequestRepository to persist an AbstractSaml2AuthenticationRequest instance before sending the <saml2:AuthnRequest> to the asserting party.spring-doc.cn
Additionally, Saml2WebSsoAuthenticationFilter and Saml2AuthenticationTokenConverter use an Saml2AuthenticationRequestRepository to load any AbstractSaml2AuthenticationRequest as part of authenticating the <saml2:Response>.spring-doc.cn
By default, Spring Security uses an HttpSessionSaml2AuthenticationRequestRepository, which stores the AbstractSaml2AuthenticationRequest in the HttpSession.spring-doc.cn
If you have a custom implementation of Saml2AuthenticationRequestRepository, you may configure it by exposing it as a @Bean as shown in the following example:spring-doc.cn
Saml2AuthenticationRequestRepository<AbstractSaml2AuthenticationRequest> authenticationRequestRepository() {
	return new CustomSaml2AuthenticationRequestRepository();
open fun authenticationRequestRepository(): Saml2AuthenticationRequestRepository<AbstractSaml2AuthenticationRequest> {
    return CustomSaml2AuthenticationRequestRepository()
Changing How the <saml2:AuthnRequest> Gets Sent
By default, Spring Security signs each <saml2:AuthnRequest> and send it as a GET to the asserting party.spring-doc.cn
Many asserting parties don’t require a signed <saml2:AuthnRequest>. This can be configured automatically via RelyingPartyRegistrations, or you can supply it manually, like so:spring-doc.cn
Not Requiring Signed AuthnRequests
spring:
  security:
    saml2:
      relyingparty:
        okta:
          identityprovider:
            entity-id: ...
            singlesignon.sign-request: false
RelyingPartyRegistration relyingPartyRegistration = RelyingPartyRegistration.withRegistrationId("okta")
        .assertingPartyDetails(party -> party
            .wantAuthnRequestsSigned(false)
var relyingPartyRegistration: RelyingPartyRegistration =
        .assertingPartyDetails { party: AssertingPartyDetails.Builder -> party
        .build()
Otherwise, you will need to specify a private key to RelyingPartyRegistration#signingX509Credentials so that Spring Security can sign the <saml2:AuthnRequest> before sending.spring-doc.cn
By default, Spring Security will sign the <saml2:AuthnRequest> using rsa-sha256, though some asserting parties will require a different algorithm, as indicated in their metadata.spring-doc.cn
You can configure the algorithm based on the asserting party’s metadata using RelyingPartyRegistrations.spring-doc.cn
Or, you can provide it manually:spring-doc.cn
String metadataLocation = "classpath:asserting-party-metadata.xml";
RelyingPartyRegistration relyingPartyRegistration = RelyingPartyRegistrations.fromMetadataLocation(metadataLocation)
        .assertingPartyDetails((party) -> party
            .signingAlgorithms((sign) -> sign.add(SignatureConstants.ALGO_ID_SIGNATURE_RSA_SHA512))
var metadataLocation = "classpath:asserting-party-metadata.xml"
                .signingAlgorithms { sign: MutableList<String?> ->
                    sign.add(
        .build()
The snippet above uses the OpenSAML SignatureConstants class to supply the algorithm name. But, that’s just for convenience. Since the datatype is String, you can supply the name of the algorithm directly.
Some asserting parties require that the <saml2:AuthnRequest> be POSTed. This can be configured automatically via RelyingPartyRegistrations, or you can supply it manually, like so:spring-doc.cn
            .singleSignOnServiceBinding(Saml2MessageBinding.POST)
var relyingPartyRegistration: RelyingPartyRegistration? =
        .build()
Customizing OpenSAML’s AuthnRequest Instance
There are a number of reasons that you may want to adjust an AuthnRequest. For example, you may want ForceAuthN to be set to true, which Spring Security sets to false by default.spring-doc.cn
You can customize elements of OpenSAML’s AuthnRequest by publishing an OpenSaml4AuthenticationRequestResolver as a @Bean, like so:spring-doc.cn
Saml2AuthenticationRequestResolver authenticationRequestResolver(RelyingPartyRegistrationRepository registrations) {
    RelyingPartyRegistrationResolver registrationResolver =
            new DefaultRelyingPartyRegistrationResolver(registrations);
    OpenSaml4AuthenticationRequestResolver authenticationRequestResolver =
            new OpenSaml4AuthenticationRequestResolver(registrationResolver);
    authenticationRequestResolver.setAuthnRequestCustomizer((context) -> context
            .getAuthnRequest().setForceAuthn(true));
    return authenticationRequestResolver;
fun authenticationRequestResolver(registrations : RelyingPartyRegistrationRepository) : Saml2AuthenticationRequestResolver {
    val registrationResolver : RelyingPartyRegistrationResolver =
    val authenticationRequestResolver : OpenSaml4AuthenticationRequestResolver =
