Kotlin Configuration
Spring Security Kotlin configuration has been available since Spring Security 5.3. It lets users configure Spring Security by using a native Kotlin DSL.spring-doc.cn
Spring Security provides a sample application to demonstrate the use of Spring Security Kotlin Configuration.spring-doc.cn
HttpSecurity
How does Spring Security know that we want to require all users to be authenticated? How does Spring Security know we want to support form-based authentication? There is a configuration class (called SecurityFilterChain) that is being invoked behind the scenes. It is configured with the following default implementation:spring-doc.cn
import org.springframework.security.config.annotation.web.invoke
    http {
        authorizeHttpRequests {
        formLogin { }
        httpBasic { }
    return http.build()
Make sure to import the invoke function in your class, as the IDE will not always auto-import the method, causing compilation issues.
The default configuration (shown in the preceding listing):spring-doc.cn
  • Ensures that any request to our application requires the user to be authenticatedspring-doc.cn
  • Lets users authenticate with form-based loginspring-doc.cn
  • Lets users authenticate with HTTP Basic authenticationspring-doc.cn
Note that this configuration parallels the XML namespace configuration:spring-doc.cn
<http>
	<intercept-url pattern="/**" access="authenticated"/>
	<form-login />
	<http-basic />
</http>
Multiple HttpSecurity Instances
We can configure multiple HttpSecurity instances, just as we can have multiple <http> blocks. The key is to register multiple SecurityFilterChain @Beans. The following example has a different configuration for URLs that start with /api/:spring-doc.cn
@EnableWebSecurity
class MultiHttpSecurityConfig {
    @Bean                                                            (1)
    public fun userDetailsService(): UserDetailsService {
        val users: User.UserBuilder = User.withDefaultPasswordEncoder()
        val manager = InMemoryUserDetailsManager()
        manager.createUser(users.username("user").password("password").roles("USER").build())
        manager.createUser(users.username("admin").password("password").roles("USER","ADMIN").build())
        return manager
    @Order(1)                                                        (2)
    open fun apiFilterChain(http: HttpSecurity): SecurityFilterChain {
        http {
            securityMatcher("/api/**")                               (3)
                authorize(anyRequest, hasRole("ADMIN"))
            httpBasic { }
        return http.build()
    @Bean                                                            (4)
    open fun formLoginFilterChain(http: HttpSecurity): SecurityFilterChain {
        http {
            formLogin { }
        return http.build()
1 Configure Authentication as usual.
2 Create an instance of SecurityFilterChain that contains @Order to specify which SecurityFilterChain should be considered first.
3 The http.securityMatcher states that this HttpSecurity is applicable only to URLs that start with /api/
4 Create another instance of SecurityFilterChain. If the URL does not start with /api/, this configuration is used. This configuration is considered after apiFilterChain, since it has an @Order value after 1 (no @Order defaults to last).
