对于最新的稳定版本,请使用 Spring Framework 6.2.6spring-doc.cadn.net.cn
为事务性作提供咨询
假设您要同时运行事务作和一些基本的分析建议。 在<tx:annotation-driven/>?spring-doc.cadn.net.cn
当您调用updateFoo(Foo)方法,您希望看到以下作:spring-doc.cadn.net.cn
本章不涉及对 AOP 的任何详细解释(除了它 适用于交易)。有关 AOP 的详细覆盖范围,请参阅 AOP 配置和 AOP 的 AOP 进行配置。
以下代码显示了前面讨论的简单性能分析方面:spring-doc.cadn.net.cn
package x.y;
import org.aspectj.lang.ProceedingJoinPoint;
import org.springframework.util.StopWatch;
import org.springframework.core.Ordered;
public class SimpleProfiler implements Ordered {
	private int order;
	// allows us to control the ordering of advice
	public int getOrder() {
		return this.order;
	public void setOrder(int order) {
		this.order = order;
	// this method is the around advice
	public Object profile(ProceedingJoinPoint call) throws Throwable {
		Object returnValue;
		StopWatch clock = new StopWatch(getClass().getName());
		try {
			clock.start(call.toShortString());
			returnValue = call.proceed();
		} finally {
			clock.stop();
			System.out.println(clock.prettyPrint());
		return returnValue;
package x.y
class SimpleProfiler : Ordered {
	private var order: Int = 0
	override fun getOrder(): Int {
		return this.order
	fun setOrder(order: Int) {
		this.order = order
	fun profile(call: ProceedingJoinPoint): Any {
		var returnValue: Any
		val clock = StopWatch(javaClass.name)
		try {
		} finally {
			clock.stop()
		return returnValue
通知的排序 通过Ordered接口。有关建议订购的完整详细信息,请参阅建议订购spring-doc.cadn.net.cn
以下配置会创建一个fooService具有性能分析和 按所需顺序应用于它的事务方面:spring-doc.cadn.net.cn
	xmlns:aop="http://www.springframework.org/schema/aop"
	xmlns:tx="http://www.springframework.org/schema/tx"
	xsi:schemaLocation="
		https://www.springframework.org/schema/tx/spring-tx.xsd
		https://www.springframework.org/schema/aop/spring-aop.xsd">
	<bean id="fooService" class="x.y.service.DefaultFooService"/>
	<!-- this is the aspect -->
	<bean id="profiler" class="x.y.SimpleProfiler">
		<!-- run before the transactional advice (hence the lower order number) -->
		<property name="order" value="1"/>
	</bean>
	<tx:annotation-driven transaction-manager="txManager" order="200"/>
	<aop:config>
			<!-- this advice runs around the transactional advice -->
			<aop:aspect id="profilingAspect" ref="profiler">
				<aop:pointcut id="serviceMethodWithReturnValue"
						expression="execution(!void x.y..*Service.*(..))"/>
				<aop:around method="profile" pointcut-ref="serviceMethodWithReturnValue"/>
			</aop:aspect>
	</aop:config>
	<bean id="dataSource" class="org.apache.commons.dbcp.BasicDataSource" destroy-method="close">
		<property name="driverClassName" value="oracle.jdbc.driver.OracleDriver"/>
		<property name="url" value="jdbc:oracle:thin:@rj-t42:1521:elvis"/>
		<property name="username" value="scott"/>
		<property name="password" value="tiger"/>
	</bean>
	<bean id="txManager" class="org.springframework.jdbc.datasource.DataSourceTransactionManager">
		<property name="dataSource" ref="dataSource"/>
	</bean>
</beans>
您可以配置任意数量 以类似的方式进行其他方面的攻击。spring-doc.cadn.net.cn
以下示例创建与前两个示例相同的设置,但使用纯 XML 声明式方法:spring-doc.cadn.net.cn
	<!-- the profiling advice -->
	</bean>
	<aop:config>
		<aop:pointcut id="entryPointMethod" expression="execution(* x.y..*Service.*(..))"/>
		<!-- runs after the profiling advice (cf. the order attribute) -->
		<aop:advisor advice-ref="txAdvice" pointcut-ref="entryPointMethod" order="2"/>
		<!-- order value is higher than the profiling aspect -->
		</aop:aspect>
	</aop:config>
	<tx:advice id="txAdvice" transaction-manager="txManager">
		<tx:attributes>
			<tx:method name="get*" read-only="true"/>
			<tx:method name="*"/>
		</tx:attributes>
	</tx:advice>
	<!-- other <bean/> definitions such as a DataSource and a TransactionManager here -->
</beans>
上述配置的结果是fooService具有性能分析和 交易方面按此顺序应用于它。如果需要性能分析建议 在 transaction advice 之后和 access 之前运行 交易建议 在退出的路上,您可以交换分析的值 Bean 的order属性,使其高于事务性建议的 order 值。spring-doc.cadn.net.cn
您可以以类似的方式配置其他方面。spring-doc.cadn.net.cn
