This version is still in development and is not considered stable yet. For the latest stable version, please use spring-cloud-stream 4.2.0! |
Multiple Binders on the Classpath
When multiple binders are present on the classpath, the application must indicate which binder is to be used for each destination binding.
Each binder configuration contains a META-INF/spring.binders
file, which is a simple properties file, as shown in the following example:
rabbit:\
org.springframework.cloud.stream.binder.rabbit.config.RabbitServiceAutoConfiguration
Similar files exist for the other provided binder implementations (such as Kafka), and custom binder implementations are expected to provide them as well.
The key represents an identifying name for the binder implementation, whereas the value is a comma-separated list of configuration classes that each contain one and only one bean definition of type org.springframework.cloud.stream.binder.Binder
Binder selection can either be performed globally, using the spring.cloud.stream.defaultBinder
property (for example, spring.cloud.stream.defaultBinder=rabbit
) or individually, by configuring the binder on each binding.
For instance, a processor application (that has bindings named input
and output
for read and write respectively) that reads from Kafka and writes to RabbitMQ can specify the following configuration:
spring.cloud.stream.bindings.input.binder=kafka
spring.cloud.stream.bindings.output.binder=rabbit
