This version is still in development and is not considered stable yet. For the latest stable version, please use spring-cloud-stream 4.2.0!spring-doc.cn
Putting it All Together
The following configuration creates an exchange myDestination with queue myDestination.consumerGroup bound to a topic exchange with a wildcard routing key #:spring-doc.cn
spring.cloud.stream.bindings.input.destination=myDestination
spring.cloud.stream.bindings.input.group=consumerGroup
#disable binder retries
spring.cloud.stream.bindings.input.consumer.max-attempts=1
#dlx/dlq setup
spring.cloud.stream.rabbit.bindings.input.consumer.auto-bind-dlq=true
spring.cloud.stream.rabbit.bindings.input.consumer.dlq-ttl=5000
spring.cloud.stream.rabbit.bindings.input.consumer.dlq-dead-letter-exchange=
This configuration creates a DLQ bound to a direct exchange (DLX) with a routing key of myDestination.consumerGroup. When messages are rejected, they are routed to the DLQ. After 5 seconds, the message expires and is routed to the original queue by using the queue name as the routing key, as shown in the following example:spring-doc.cn
Spring Boot application
@SpringBootApplication
public class XDeathApplication {
        SpringApplication.run(XDeathApplication.class, args);
    public Consumer<Message<String>> listen() {
        return message -> {
            Map<?,?> death = message.getHeaders().get("x-death");
            if (death != null && death.get("count").equals(3L)) {
                // giving up - don't send to DLX
                throw new ImmediateAcknowledgeAmqpException("Failed after 4 attempts");
            throw new AmqpRejectAndDontRequeueException("failed");
Notice that the count property in the x-death header is a Long.spring-doc.cn
