This version is still in development and is not considered stable yet. For the latest stable version, please use spring-cloud-stream 4.2.0!spring-doc.cn
Overview
Spring Cloud Stream includes a binder implementation designed explicitly for Apache Kafka Streams binding. With this native integration, a Spring Cloud Stream "processor" application can directly use the Apache Kafka Streams APIs in the core business logic.spring-doc.cn
Kafka Streams binder implementation builds on the foundations provided by the Spring for Apache Kafka project.spring-doc.cn
Kafka Streams binder provides binding capabilities for the three major types in Kafka Streams - KStream, KTable and GlobalKTable.spring-doc.cn
Kafka Streams applications typically follow a model in which the records are read from an inbound topic, apply business logic, and then write the transformed records to an outbound topic. Alternatively, a Processor application with no outbound destination can be defined as well.spring-doc.cn
In the following sections, we are going to look at the details of Spring Cloud Stream’s integration with Kafka Streams.spring-doc.cn
