This version is still in development and is not considered stable yet. For the latest stable version, please use spring-cloud-stream 4.2.0!spring-doc.cn
KafkaBindingRebalanceListener
Applications may wish to seek topics/partitions to arbitrary offsets when the partitions are initially assigned, or perform other operations on the consumer. Starting with version 2.1, if you provide a single KafkaBindingRebalanceListener bean in the application context, it will be wired into all Kafka consumer bindings.spring-doc.cn
public interface KafkaBindingRebalanceListener {
	 * Invoked by the container before any pending offsets are committed.
	 * @param bindingName the name of the binding.
	 * @param consumer the consumer.
	 * @param partitions the partitions.
	default void onPartitionsRevokedBeforeCommit(String bindingName, Consumer<?, ?> consumer,
			Collection<TopicPartition> partitions) {
	 * Invoked by the container after any pending offsets are committed.
	default void onPartitionsRevokedAfterCommit(String bindingName, Consumer<?, ?> consumer, Collection<TopicPartition> partitions) {
	 * Invoked when partitions are initially assigned or after a rebalance.
	 * Applications might only want to perform seek operations on an initial assignment.
	 * @param initial true if this is the initial assignment.
	default void onPartitionsAssigned(String bindingName, Consumer<?, ?> consumer, Collection<TopicPartition> partitions,
			boolean initial) {
You cannot set the resetOffsets consumer property to true when you provide a rebalance listener.spring-doc.cn
