This version is still in development and is not considered stable yet. For the latest stable version, please use spring-cloud-stream 4.2.0!spring-doc.cn
Usage
To use Apache Kafka binder, you need to add spring-cloud-stream-binder-kafka as a dependency to your Spring Cloud Stream application, as shown in the following example for Maven:spring-doc.cn
<dependency>
  <artifactId>spring-cloud-stream-binder-kafka</artifactId>
</dependency>
Alternatively, you can also use the Spring Cloud Stream Kafka Starter, as shown in the following example for Maven:spring-doc.cn
<dependency>
  <artifactId>spring-cloud-starter-stream-kafka</artifactId>
</dependency>
