17. 开发人员指南
这些是编写网关的一些自定义组件的基本指南。spring-doc.cadn.net.cn
17.1. 编写自定义路由谓词工厂
为了编写路由谓词,您需要实现RoutePredicateFactory.有一个名为AbstractRoutePredicateFactory您可以扩展。spring-doc.cadn.net.cn
MyRoutePredicateFactory.java
public class MyRoutePredicateFactory extends AbstractRoutePredicateFactory<HeaderRoutePredicateFactory.Config> {
    public MyRoutePredicateFactory() {
        super(Config.class);
    public Predicate<ServerWebExchange> apply(Config config) {
        // grab configuration from Config object
        return exchange -> {
            //grab the request
            ServerHttpRequest request = exchange.getRequest();
            //take information from the request to see if it
            //matches configuration.
            return matches(config, request);
    public static class Config {
        //Put the configuration properties for your filter here
17.2. 编写自定义 GatewayFilter 工厂
要编写GatewayFilter中,您必须实现GatewayFilterFactory. 您可以扩展一个名为AbstractGatewayFilterFactory. 以下示例说明如何执行此作:spring-doc.cadn.net.cn
例 72.PreGatewayFilterFactory.java
public class PreGatewayFilterFactory extends AbstractGatewayFilterFactory<PreGatewayFilterFactory.Config> {
    public PreGatewayFilterFactory() {
    public GatewayFilter apply(Config config) {
        return (exchange, chain) -> {
            //If you want to build a "pre" filter you need to manipulate the
            //request before calling chain.filter
            ServerHttpRequest.Builder builder = exchange.getRequest().mutate();
            //use builder to manipulate the request
            return chain.filter(exchange.mutate().request(builder.build()).build());
PostGatewayFilterFactory.java
public class PostGatewayFilterFactory extends AbstractGatewayFilterFactory<PostGatewayFilterFactory.Config> {
    public PostGatewayFilterFactory() {
            return chain.filter(exchange).then(Mono.fromRunnable(() -> {
                ServerHttpResponse response = exchange.getResponse();
                //Manipulate the response in some way
17.2.1. 在配置中命名自定义过滤器和引用
自定义过滤器类名称应以GatewayFilterFactory.spring-doc.cadn.net.cn
例如,要引用名为Something在配置文件中,过滤器 必须位于名为SomethingGatewayFilterFactory.spring-doc.cadn.net.cn
可以创建一个网关过滤器,名称不带GatewayFilterFactory后缀,例如class AnotherThing.此筛选器可以是 引用为AnotherThing在配置文件中。这不是受支持的命名 约定,并且此语法可能会在将来的发行版中删除。请更新过滤器 name 来合规。
17.3. 编写自定义全局过滤器
要编写自定义全局过滤器,您必须实现GlobalFilter接口。 这会将筛选条件应用于所有请求。spring-doc.cadn.net.cn
以下示例分别说明如何设置全局 pre 和 post 过滤器:spring-doc.cadn.net.cn
public GlobalFilter customGlobalFilter() {
    return (exchange, chain) -> exchange.getPrincipal()
        .map(Principal::getName)
        .defaultIfEmpty("Default User")
        .map(userName -> {
          //adds header to proxied request
          exchange.getRequest().mutate().header("CUSTOM-REQUEST-HEADER", userName).build();
          return exchange;
        .flatMap(chain::filter);
public GlobalFilter customGlobalPostFilter() {
    return (exchange, chain) -> chain.filter(exchange)
        .then(Mono.just(exchange))
        .map(serverWebExchange -> {
          //adds header to response
          serverWebExchange.getResponse().getHeaders().set("CUSTOM-RESPONSE-HEADER",
              HttpStatus.OK.equals(serverWebExchange.getResponse().getStatusCode()) ? "It worked": "It did not work");
          return serverWebExchange;
        .then();
