For the latest stable version, please use Spring Security 6.4.1! |
Authorized Client Features
This section covers additional features provided by Spring Security for the OAuth2 client.
Resolving an Authorized Client
The @RegisteredOAuth2AuthorizedClient
annotation provides the ability to resolve a method parameter to an argument value of type OAuth2AuthorizedClient
This is a convenient alternative compared to accessing the OAuth2AuthorizedClient
by using the OAuth2AuthorizedClientManager
or OAuth2AuthorizedClientService
The following example shows how to use @RegisteredOAuth2AuthorizedClient
Java
Kotlin
@Controller
@GetMapping("/")
public String index(@RegisteredOAuth2AuthorizedClient("okta") OAuth2AuthorizedClient authorizedClient) {
OAuth2AccessToken accessToken = authorizedClient.getAccessToken();
return "index";
@Controller
@GetMapping("/")
fun index(@RegisteredOAuth2AuthorizedClient("okta") authorizedClient: OAuth2AuthorizedClient): String {
val accessToken = authorizedClient.accessToken
return "index"
annotation is handled by OAuth2AuthorizedClientArgumentResolver
, which directly uses an OAuth2AuthorizedClientManager
and, therefore, inherits its capabilities.
WebClient Integration for Servlet Environments
The OAuth 2.0 Client support integrates with WebClient
by using an ExchangeFilterFunction
The ServletOAuth2AuthorizedClientExchangeFilterFunction
provides a mechanism for requesting protected resources by using an OAuth2AuthorizedClient
and including the associated OAuth2AccessToken
as a Bearer Token.
It directly uses an OAuth2AuthorizedClientManager
and, therefore, inherits the following capabilities:
An
OAuth2AccessToken
is requested if the client has not yet been authorized.-
authorization_code
: Triggers the Authorization Request redirect to initiate the flow. -
client_credentials
: The access token is obtained directly from the Token Endpoint. -
password
If the
OAuth2AccessToken
is expired, it is refreshed (or renewed) if anOAuth2AuthorizedClientProvider
is available to perform the authorization
The following code shows an example of how to configure WebClient
with OAuth 2.0 Client support:
Java
Kotlin
WebClient webClient(OAuth2AuthorizedClientManager authorizedClientManager) {
ServletOAuth2AuthorizedClientExchangeFilterFunction oauth2Client =
new ServletOAuth2AuthorizedClientExchangeFilterFunction(authorizedClientManager);
return WebClient.builder()
.apply(oauth2Client.oauth2Configuration())
fun webClient(authorizedClientManager: OAuth2AuthorizedClientManager?): WebClient {
val oauth2Client = ServletOAuth2AuthorizedClientExchangeFilterFunction(authorizedClientManager)
.build()
Providing the Authorized Client
determines the client to use (for a request) by resolving the OAuth2AuthorizedClient
from the ClientRequest.attributes()
(request attributes).
The following code shows how to set an OAuth2AuthorizedClient
as a request attribute:
Java
Kotlin
@GetMapping("/")
String resourceUri = ...
String body = webClient
.get()
.uri(resourceUri)
.attributes(oauth2AuthorizedClient(authorizedClient)) (1)
.retrieve()
.bodyToMono(String.class)
.block();
return "index";
@GetMapping("/")
val resourceUri: String = ...
val body: String = webClient
.get()
.uri(resourceUri)
.retrieve()
.bodyToMono()
.block()
return "index"
1 | oauth2AuthorizedClient() is a static method in ServletOAuth2AuthorizedClientExchangeFilterFunction . |
The following code shows how to set the ClientRegistration.getRegistrationId()
Java
Kotlin
@GetMapping("/")
public String index() {
.get()
.uri(resourceUri)
.attributes(clientRegistrationId("okta")) (1)
.retrieve()
.block();
return "index";
@GetMapping("/")
fun index(): String {
.get()
.uri(resourceUri)
.retrieve()
.bodyToMono()
.block()
return "index"
1 | clientRegistrationId() is a static method in ServletOAuth2AuthorizedClientExchangeFilterFunction . |
The following code shows how to set an Authentication
Java
Kotlin
@GetMapping("/")
Authentication anonymousAuthentication = new AnonymousAuthenticationToken(
"anonymous", "anonymousUser", AuthorityUtils.createAuthorityList("ROLE_ANONYMOUS"));
.get()
.uri(resourceUri)
.attributes(authentication(anonymousAuthentication)) (1)
.retrieve()
.block();
return "index";
@GetMapping("/")
val anonymousAuthentication: Authentication = AnonymousAuthenticationToken(
.get()
.uri(resourceUri)
.retrieve()
.bodyToMono()
.block()
return "index"
1 | authentication() is a static method in ServletOAuth2AuthorizedClientExchangeFilterFunction . |
It is recommended to be cautious with this feature since all HTTP requests will receive an access token bound to the provided principal. |
Defaulting the Authorized Client
If neither OAuth2AuthorizedClient
or ClientRegistration.getRegistrationId()
is provided as a request attribute, the ServletOAuth2AuthorizedClientExchangeFilterFunction
can determine the default client to use, depending on its configuration.
If setDefaultOAuth2AuthorizedClient(true)
is configured and the user has authenticated by using HttpSecurity.oauth2Login()
, the OAuth2AccessToken
associated with the current OAuth2AuthenticationToken
is used.
The following code shows the specific configuration:
Java
Kotlin
oauth2Client.setDefaultOAuth2AuthorizedClient(true);
.build()
Be cautious with this feature, since all HTTP requests receive the access token. |
Alternatively, if setDefaultClientRegistrationId("okta")
is configured with a valid ClientRegistration
associated with the OAuth2AuthorizedClient
is used.
Java
Kotlin
oauth2Client.setDefaultClientRegistrationId("okta");
.build()
