For the latest stable version, please use Spring Security 6.4.1! |
Concurrent Sessions Control
Similar to Servlet’s Concurrent Sessions Control, Spring Security also provides support to limit the number of concurrent sessions a user can have in a Reactive application.
When you set up Concurrent Sessions Control in Spring Security, it monitors authentications carried out through Form Login, OAuth 2.0 Login, and HTTP Basic authentication by hooking into the way those authentication mechanisms handle authentication success.
More specifically, the session management DSL will add the ConcurrentSessionControlServerAuthenticationSuccessHandler and the RegisterSessionServerAuthenticationSuccessHandler to the list of ServerAuthenticationSuccessHandler
used by the authentication filter.
The following sections contains examples of how to configure Concurrent Sessions Control.
Limiting Concurrent Sessions
By default, Spring Security will allow any number of concurrent sessions for a user.
To limit the number of concurrent sessions, you can use the maximumSessions
DSL method:
Java
Kotlin
SecurityWebFilterChain filterChain(ServerHttpSecurity http) {
http
.sessionManagement((sessions) -> sessions
.concurrentSessions((concurrency) -> concurrency
.maximumSessions(SessionLimit.of(1))
return http.build();
ReactiveSessionRegistry reactiveSessionRegistry() {
return new InMemoryReactiveSessionRegistry();
open fun springSecurity(http: ServerHttpSecurity): SecurityWebFilterChain {
return http {
sessionManagement {
sessionConcurrency {
maximumSessions = SessionLimit.of(1)
open fun reactiveSessionRegistry(): ReactiveSessionRegistry {
return InMemoryReactiveSessionRegistry()
The above configuration allows one session for any user.
Similarly, you can also allow unlimited sessions by using the SessionLimit#UNLIMITED
constant:
Java
Kotlin
http
.maximumSessions(SessionLimit.UNLIMITED))
return http {
sessionManagement {
maximumSessions = SessionLimit.UNLIMITED
open fun reactiveSessionRegistry(webSessionManager: WebSessionManager): ReactiveSessionRegistry {
Since the maximumSessions
method accepts a SessionLimit
interface, which in turn extends Function<Authentication, Mono<Integer>>
, you can have a more complex logic to determine the maximum number of sessions based on the user’s authentication:
Authentication
Java
Kotlin
http
.maximumSessions(maxSessions()))
private SessionLimit maxSessions() {
return (authentication) -> {
if (authentication.getAuthorities().contains(new SimpleGrantedAuthority("ROLE_UNLIMITED_SESSIONS"))) {
return Mono.empty(); // allow unlimited sessions for users with ROLE_UNLIMITED_SESSIONS
if (authentication.getAuthorities().contains(new SimpleGrantedAuthority("ROLE_ADMIN"))) {
return Mono.just(2); // allow two sessions for admins
return Mono.just(1); // allow one session for every other user
return http {
sessionManagement {
maximumSessions = maxSessions()
fun maxSessions(): SessionLimit {
return { authentication ->
if (authentication.authorities.contains(SimpleGrantedAuthority("ROLE_UNLIMITED_SESSIONS"))) Mono.empty
if (authentication.authorities.contains(SimpleGrantedAuthority("ROLE_ADMIN"))) Mono.just(2)
Mono.just(1)
When the maximum number of sessions is exceeded, by default, the least recently used session(s) will be expired. If you want to change that behavior, you can customize the strategy used when the maximum number of sessions is exceeded.
The Concurrent Session Management is not aware if there is another session in some Identity Provider that you might use via OAuth 2 Login for example.
If you also need to invalidate the session against the Identity Provider you must include your own implementation of |
Handling Maximum Number of Sessions Exceeded
By default, when the maximum number of sessions is exceeded, the least recently used session(s) will be expired by using the InvalidateLeastUsedMaximumSessionsExceededHandler. Spring Security also provides another implementation that prevents the user from creating new sessions by using the PreventLoginMaximumSessionsExceededHandler. If you want to use your own strategy, you can provide a different implementation of ServerMaximumSessionsExceededHandler.
Java
Kotlin
http
.maximumSessionsExceededHandler(new PreventLoginMaximumSessionsExceededHandler())
return http {
sessionManagement {
maximumSessionsExceededHandler = PreventLoginMaximumSessionsExceededHandler()
Specifying a ReactiveSessionRegistry
In order to keep track of the user’s sessions, Spring Security uses a ReactiveSessionRegistry, and, every time a user logs in, their session information is saved.
Spring Security ships with InMemoryReactiveSessionRegistry implementation of ReactiveSessionRegistry
To specify a ReactiveSessionRegistry
implementation you can either declare it as a bean:
Java
Kotlin
http
return new MyReactiveSessionRegistry();
return http {
sessionManagement {
return MyReactiveSessionRegistry()
or you can use the sessionRegistry
DSL method:
Java
Kotlin
http
.sessionRegistry(new MyReactiveSessionRegistry())
return http {
sessionManagement {
sessionRegistry = MyReactiveSessionRegistry()
Invalidating Registered User’s Sessions
At times, it is handy to be able to invalidate all or some of a user’s sessions.
For example, when a user changes their password, you may want to invalidate all of their sessions so that they are forced to log in again.
To do that, you can use the ReactiveSessionRegistry
bean to retrieve all the user’s sessions, invalidate them, and them remove them from the WebSessionStore
Java
public class SessionControl {
private final ReactiveSessionRegistry reactiveSessionRegistry;
private final WebSessionStore webSessionStore;
public Mono<Void> invalidateSessions(String username) {
return this.reactiveSessionRegistry.getAllSessions(username)
.flatMap((session) -> session.invalidate().thenReturn(session))
.flatMap((session) -> this.webSessionStore.removeSession(session.getSessionId()))
.then();
Disabling It for Some Authentication Filters
By default, Concurrent Sessions Control will be configured automatically for Form Login, OAuth 2.0 Login, and HTTP Basic authentication as long as they do not specify an ServerAuthenticationSuccessHandler
themselves.
For example, the following configuration will disable Concurrent Sessions Control for Form Login:
Java
Kotlin
http
.formLogin((login) -> login
.authenticationSuccessHandler(new RedirectServerAuthenticationSuccessHandler("/"))
return http {
formLogin {
authenticationSuccessHandler = RedirectServerAuthenticationSuccessHandler("/")
sessionManagement {
Adding Additional Success Handlers Without Disabling Concurrent Sessions Control
You can also include additional ServerAuthenticationSuccessHandler
instances to the list of handlers used by the authentication filter without disabling Concurrent Sessions Control.
To do that you can use the authenticationSuccessHandler(Consumer<List<ServerAuthenticationSuccessHandler>>)
method:
Java
http
.authenticationSuccessHandler((handlers) -> handlers.add(new MyAuthenticationSuccessHandler()))
Checking a Sample Application
You can check the sample application here.
