For the latest stable version, please use Spring Security 6.4.1! |
Authorization Grant Support
Authorization Code
Please refer to the OAuth 2.0 Authorization Framework for further details on the Authorization Code grant. |
Obtaining Authorization
Please refer to the Authorization Request/Response protocol flow for the Authorization Code grant. |
Initiating the Authorization Request
The OAuth2AuthorizationRequestRedirectWebFilter
uses a ServerOAuth2AuthorizationRequestResolver
to resolve an OAuth2AuthorizationRequest
and initiate the Authorization Code grant flow by redirecting the end-user’s user-agent to the Authorization Server’s Authorization Endpoint.
The primary role of the ServerOAuth2AuthorizationRequestResolver
is to resolve an OAuth2AuthorizationRequest
from the provided web request.
The default implementation DefaultServerOAuth2AuthorizationRequestResolver
matches on the (default) path /oauth2/authorization/{registrationId}
extracting the registrationId
and using it to build the OAuth2AuthorizationRequest
for the associated ClientRegistration
Given the following Spring Boot properties for an OAuth 2.0 Client registration:
spring:
security:
oauth2:
client:
registration:
okta:
client-id: okta-client-id
authorization-grant-type: authorization_code
redirect-uri: "{baseUrl}/authorized/okta"
scope: read, write
provider:
okta:
authorization-uri: https://dev-1234.oktapreview.com/oauth2/v1/authorize
token-uri: https://dev-1234.oktapreview.com/oauth2/v1/token
A request with the base path /oauth2/authorization/okta
will initiate the Authorization Request redirect by the OAuth2AuthorizationRequestRedirectWebFilter
and ultimately start the Authorization Code grant flow.
The AuthorizationCodeReactiveOAuth2AuthorizedClientProvider is an implementation of ReactiveOAuth2AuthorizedClientProvider for the Authorization Code grant,
which also initiates the Authorization Request redirect by the OAuth2AuthorizationRequestRedirectWebFilter .
If the OAuth 2.0 Client is a Public Client, then configure the OAuth 2.0 Client registration as follows:
spring:
security:
oauth2:
client:
registration:
okta:
client-authentication-method: none
Public Clients are supported using Proof Key for Code Exchange (PKCE). If the client is running in an untrusted environment (eg. native application or web browser-based application) and therefore incapable of maintaining the confidentiality of it’s credentials, PKCE will automatically be used when the following conditions are true:
client-secret
is omitted (or empty) -
is set to "none" (ClientAuthenticationMethod.NONE
If the OAuth 2.0 Provider supports PKCE for Confidential Clients, you may (optionally) configure it using DefaultServerOAuth2AuthorizationRequestResolver.setAuthorizationRequestCustomizer(OAuth2AuthorizationRequestCustomizers.withPkce()) .
The DefaultServerOAuth2AuthorizationRequestResolver
also supports URI
template variables for the redirect-uri
using UriComponentsBuilder
The following configuration uses all the supported URI
template variables:
spring:
security:
oauth2:
client:
registration:
okta:
redirect-uri: "{baseScheme}://{baseHost}{basePort}{basePath}/authorized/{registrationId}"
{baseUrl} resolves to {baseScheme}://{baseHost}{basePort}{basePath}
Configuring the redirect-uri
with URI
template variables is especially useful when the OAuth 2.0 Client is running behind a Proxy Server.
This ensures that the X-Forwarded-*
headers are used when expanding the redirect-uri
Customizing the Authorization Request
One of the primary use cases a ServerOAuth2AuthorizationRequestResolver
can realize is the ability to customize the Authorization Request with additional parameters above the standard parameters defined in the OAuth 2.0 Authorization Framework.
For example, OpenID Connect defines additional OAuth 2.0 request parameters for the Authorization Code Flow extending from the standard parameters defined in the OAuth 2.0 Authorization Framework.
One of those extended parameters is the prompt
parameter.
The |
The following example shows how to configure the DefaultServerOAuth2AuthorizationRequestResolver
with a Consumer<OAuth2AuthorizationRequest.Builder>
that customizes the Authorization Request for oauth2Login()
, by including the request parameter prompt=consent
Java
Kotlin
@EnableWebFluxSecurity
public class OAuth2LoginSecurityConfig {
@Autowired
private ReactiveClientRegistrationRepository clientRegistrationRepository;
public SecurityWebFilterChain securityWebFilterChain(ServerHttpSecurity http) {
http
.authorizeExchange(authorize -> authorize
.oauth2Login(oauth2 -> oauth2
.authorizationRequestResolver(
authorizationRequestResolver(this.clientRegistrationRepository)
return http.build();
private ServerOAuth2AuthorizationRequestResolver authorizationRequestResolver(
ReactiveClientRegistrationRepository clientRegistrationRepository) {
DefaultServerOAuth2AuthorizationRequestResolver authorizationRequestResolver =
new DefaultServerOAuth2AuthorizationRequestResolver(
clientRegistrationRepository);
authorizationRequestResolver.setAuthorizationRequestCustomizer(
authorizationRequestCustomizer());
return authorizationRequestResolver;
private Consumer<OAuth2AuthorizationRequest.Builder> authorizationRequestCustomizer() {
return customizer -> customizer
.additionalParameters(params -> params.put("prompt", "consent"));
class SecurityConfig {
@Autowired
private lateinit var customClientRegistrationRepository: ReactiveClientRegistrationRepository
fun securityFilterChain(http: ServerHttpSecurity): SecurityWebFilterChain {
http {
authorizeExchange {
oauth2Login {
authorizationRequestResolver = authorizationRequestResolver(customClientRegistrationRepository)
return http.build()
private fun authorizationRequestResolver(
clientRegistrationRepository: ReactiveClientRegistrationRepository): ServerOAuth2AuthorizationRequestResolver {
val authorizationRequestResolver = DefaultServerOAuth2AuthorizationRequestResolver(
private fun authorizationRequestCustomizer(): Consumer<OAuth2AuthorizationRequest.Builder> {
return Consumer { customizer ->
customizer
.additionalParameters { params -> params["prompt"] = "consent" }
For the simple use case, where the additional request parameter is always the same for a specific provider, it may be added directly in the authorization-uri
property.
For example, if the value for the request parameter prompt
is always consent
for the provider okta
, than simply configure as follows:
spring:
security:
oauth2:
client:
provider:
okta:
authorization-uri: https://dev-1234.oktapreview.com/oauth2/v1/authorize?prompt=consent
The preceding example shows the common use case of adding a custom parameter on top of the standard parameters.
Alternatively, if your requirements are more advanced, you can take full control in building the Authorization Request URI by simply overriding the OAuth2AuthorizationRequest.authorizationRequestUri
property.
OAuth2AuthorizationRequest.Builder.build() constructs the OAuth2AuthorizationRequest.authorizationRequestUri , which represents the Authorization Request URI including all query parameters using the application/x-www-form-urlencoded format.
The following example shows a variation of authorizationRequestCustomizer()
from the preceding example, and instead overrides the OAuth2AuthorizationRequest.authorizationRequestUri
property.
Java
Kotlin
.authorizationRequestUri(uriBuilder -> uriBuilder
.queryParam("prompt", "consent").build());
return Consumer { customizer: OAuth2AuthorizationRequest.Builder ->
customizer
.authorizationRequestUri { uriBuilder: UriBuilder ->
uriBuilder
Storing the Authorization Request
The ServerAuthorizationRequestRepository
is responsible for the persistence of the OAuth2AuthorizationRequest
from the time the Authorization Request is initiated to the time the Authorization Response is received (the callback).
The OAuth2AuthorizationRequest is used to correlate and validate the Authorization Response.
The default implementation of ServerAuthorizationRequestRepository
is WebSessionOAuth2ServerAuthorizationRequestRepository
, which stores the OAuth2AuthorizationRequest
in the WebSession
If you have a custom implementation of ServerAuthorizationRequestRepository
, you may configure it as shown in the following example:
Java
Kotlin
public class OAuth2ClientSecurityConfig {
http
.oauth2Client(oauth2 -> oauth2
.authorizationRequestRepository(this.authorizationRequestRepository())
http {
oauth2Client {
authorizationRequestRepository = authorizationRequestRepository()
return http.build()
Requesting an Access Token
Please refer to the Access Token Request/Response protocol flow for the Authorization Code grant. |
The default implementation of ReactiveOAuth2AccessTokenResponseClient
for the Authorization Code grant is WebClientReactiveAuthorizationCodeTokenResponseClient
, which uses a WebClient
for exchanging an authorization code for an access token at the Authorization Server’s Token Endpoint.
The WebClientReactiveAuthorizationCodeTokenResponseClient
is quite flexible as it allows you to customize the pre-processing of the Token Request and/or post-handling of the Token Response.
Customizing the Access Token Request
If you need to customize the pre-processing of the Token Request, you can provide WebClientReactiveAuthorizationCodeTokenResponseClient.setParametersConverter()
with a custom Converter<OAuth2AuthorizationCodeGrantRequest, MultiValueMap<String, String>>
The default implementation builds a MultiValueMap<String, String>
containing only the grant_type
parameter of a standard OAuth 2.0 Access Token Request which is used to construct the request. Other parameters required by the Authorization Code grant are added directly to the body of the request by the WebClientReactiveAuthorizationCodeTokenResponseClient
However, providing a custom Converter
, would allow you to extend the standard Token Request and add custom parameter(s).
If you prefer to only add additional parameters, you can instead provide WebClientReactiveAuthorizationCodeTokenResponseClient.addParametersConverter() with a custom Converter<OAuth2AuthorizationCodeGrantRequest, MultiValueMap<String, String>> which constructs an aggregate Converter .
The custom Converter must return valid parameters of an OAuth 2.0 Access Token Request that is understood by the intended OAuth 2.0 Provider.
Customizing the Access Token Response
On the other end, if you need to customize the post-handling of the Token Response, you will need to provide WebClientReactiveAuthorizationCodeTokenResponseClient.setBodyExtractor()
with a custom configured BodyExtractor<Mono<OAuth2AccessTokenResponse>, ReactiveHttpInputMessage>
that is used for converting the OAuth 2.0 Access Token Response to an OAuth2AccessTokenResponse
The default implementation provided by OAuth2BodyExtractors.oauth2AccessTokenResponse()
parses the response and handles errors accordingly.
Customizing the WebClient
Alternatively, if your requirements are more advanced, you can take full control of the request/response by simply providing WebClientReactiveAuthorizationCodeTokenResponseClient.setWebClient()
with a custom configured WebClient
Whether you customize WebClientReactiveAuthorizationCodeTokenResponseClient
or provide your own implementation of ReactiveOAuth2AccessTokenResponseClient
, you’ll need to configure it as shown in the following example:
Java
Kotlin
http
.authenticationManager(this.authorizationCodeAuthenticationManager())
private ReactiveAuthenticationManager authorizationCodeAuthenticationManager() {
WebClientReactiveAuthorizationCodeTokenResponseClient accessTokenResponseClient =
new WebClientReactiveAuthorizationCodeTokenResponseClient();
return new OAuth2AuthorizationCodeReactiveAuthenticationManager(accessTokenResponseClient);
http {
oauth2Client {
authenticationManager = authorizationCodeAuthenticationManager()
return http.build()
private fun authorizationCodeAuthenticationManager(): ReactiveAuthenticationManager {
val accessTokenResponseClient = WebClientReactiveAuthorizationCodeTokenResponseClient()
return OAuth2AuthorizationCodeReactiveAuthenticationManager(accessTokenResponseClient)
Refresh Token
Please refer to the OAuth 2.0 Authorization Framework for further details on the Refresh Token. |
Refreshing an Access Token
Please refer to the Access Token Request/Response protocol flow for the Refresh Token grant. |
for the Refresh Token grant is WebClientReactiveRefreshTokenTokenResponseClient
when refreshing an access token at the Authorization Server’s Token Endpoint.
The WebClientReactiveRefreshTokenTokenResponseClient
If you need to customize the pre-processing of the Token Request, you can provide WebClientReactiveRefreshTokenTokenResponseClient.setParametersConverter()
with a custom Converter<OAuth2RefreshTokenGrantRequest, MultiValueMap<String, String>>
parameter of a standard OAuth 2.0 Access Token Request which is used to construct the request. Other parameters required by the Refresh Token grant are added directly to the body of the request by the WebClientReactiveRefreshTokenTokenResponseClient
If you prefer to only add additional parameters, you can instead provide WebClientReactiveRefreshTokenTokenResponseClient.addParametersConverter() with a custom Converter<OAuth2RefreshTokenGrantRequest, MultiValueMap<String, String>> which constructs an aggregate Converter .
On the other end, if you need to customize the post-handling of the Token Response, you will need to provide WebClientReactiveRefreshTokenTokenResponseClient.setBodyExtractor()
Alternatively, if your requirements are more advanced, you can take full control of the request/response by simply providing WebClientReactiveRefreshTokenTokenResponseClient.setWebClient()
Whether you customize WebClientReactiveRefreshTokenTokenResponseClient
Java
Kotlin
// Customize
ReactiveOAuth2AccessTokenResponseClient<OAuth2RefreshTokenGrantRequest> refreshTokenTokenResponseClient = ...
ReactiveOAuth2AuthorizedClientProvider authorizedClientProvider =
ReactiveOAuth2AuthorizedClientProviderBuilder.builder()
.authorizationCode()
.refreshToken(configurer -> configurer.accessTokenResponseClient(refreshTokenTokenResponseClient))
authorizedClientManager.setAuthorizedClientProvider(authorizedClientProvider);
// Customize
val refreshTokenTokenResponseClient: ReactiveOAuth2AccessTokenResponseClient<OAuth2RefreshTokenGrantRequest> = ...
val authorizedClientProvider: ReactiveOAuth2AuthorizedClientProvider = ReactiveOAuth2AuthorizedClientProviderBuilder.builder()
.refreshToken { it.accessTokenResponseClient(refreshTokenTokenResponseClient) }
.build()
ReactiveOAuth2AuthorizedClientProviderBuilder.builder().refreshToken() configures a RefreshTokenReactiveOAuth2AuthorizedClientProvider ,
which is an implementation of a ReactiveOAuth2AuthorizedClientProvider for the Refresh Token grant.
The OAuth2RefreshToken
may optionally be returned in the Access Token Response for the authorization_code
and password
grant types.
If the OAuth2AuthorizedClient.getRefreshToken()
is available and the OAuth2AuthorizedClient.getAccessToken()
is expired, it will automatically be refreshed by the RefreshTokenReactiveOAuth2AuthorizedClientProvider
Client Credentials
Please refer to the OAuth 2.0 Authorization Framework for further details on the Client Credentials grant. |
Please refer to the Access Token Request/Response protocol flow for the Client Credentials grant. |
for the Client Credentials grant is WebClientReactiveClientCredentialsTokenResponseClient
when requesting an access token at the Authorization Server’s Token Endpoint.
The WebClientReactiveClientCredentialsTokenResponseClient
If you need to customize the pre-processing of the Token Request, you can provide WebClientReactiveClientCredentialsTokenResponseClient.setParametersConverter()
with a custom Converter<OAuth2ClientCredentialsGrantRequest, MultiValueMap<String, String>>
parameter of a standard OAuth 2.0 Access Token Request which is used to construct the request. Other parameters required by the Client Credentials grant are added directly to the body of the request by the WebClientReactiveClientCredentialsTokenResponseClient
If you prefer to only add additional parameters, you can instead provide WebClientReactiveClientCredentialsTokenResponseClient.addParametersConverter() with a custom Converter<OAuth2ClientCredentialsGrantRequest, MultiValueMap<String, String>> which constructs an aggregate Converter .
On the other end, if you need to customize the post-handling of the Token Response, you will need to provide WebClientReactiveClientCredentialsTokenResponseClient.setBodyExtractor()
Alternatively, if your requirements are more advanced, you can take full control of the request/response by simply providing WebClientReactiveClientCredentialsTokenResponseClient.setWebClient()
Whether you customize WebClientReactiveClientCredentialsTokenResponseClient
Java
Kotlin
// Customize
ReactiveOAuth2AccessTokenResponseClient<OAuth2ClientCredentialsGrantRequest> clientCredentialsTokenResponseClient = ...
.clientCredentials(configurer -> configurer.accessTokenResponseClient(clientCredentialsTokenResponseClient))
// Customize
val clientCredentialsTokenResponseClient: ReactiveOAuth2AccessTokenResponseClient<OAuth2ClientCredentialsGrantRequest> = ...
.clientCredentials { it.accessTokenResponseClient(clientCredentialsTokenResponseClient) }
.build()
ReactiveOAuth2AuthorizedClientProviderBuilder.builder().clientCredentials() configures a ClientCredentialsReactiveOAuth2AuthorizedClientProvider ,
which is an implementation of a ReactiveOAuth2AuthorizedClientProvider for the Client Credentials grant.
Using the Access Token
spring:
security:
oauth2:
client:
registration:
okta:
authorization-grant-type: client_credentials
scope: read, write
provider:
okta:
…and the ReactiveOAuth2AuthorizedClientManager
Java
Kotlin
public ReactiveOAuth2AuthorizedClientManager authorizedClientManager(
ReactiveClientRegistrationRepository clientRegistrationRepository,
ServerOAuth2AuthorizedClientRepository authorizedClientRepository) {
DefaultReactiveOAuth2AuthorizedClientManager authorizedClientManager =
new DefaultReactiveOAuth2AuthorizedClientManager(
clientRegistrationRepository, authorizedClientRepository);
return authorizedClientManager;
fun authorizedClientManager(
clientRegistrationRepository: ReactiveClientRegistrationRepository,
authorizedClientRepository: ServerOAuth2AuthorizedClientRepository): ReactiveOAuth2AuthorizedClientManager {
.build()
val authorizedClientManager = DefaultReactiveOAuth2AuthorizedClientManager(
You may obtain the OAuth2AccessToken
as follows:
Java
Kotlin
@Controller
@Autowired
private ReactiveOAuth2AuthorizedClientManager authorizedClientManager;
@GetMapping("/")
public Mono<String> index(Authentication authentication, ServerWebExchange exchange) {
OAuth2AuthorizeRequest authorizeRequest = OAuth2AuthorizeRequest.withClientRegistrationId("okta")
.principal(authentication)
.attribute(ServerWebExchange.class.getName(), exchange)
return this.authorizedClientManager.authorize(authorizeRequest)
.map(OAuth2AuthorizedClient::getAccessToken)
.thenReturn("index");
@Autowired
private lateinit var authorizedClientManager: ReactiveOAuth2AuthorizedClientManager
@GetMapping("/")
fun index(authentication: Authentication, exchange: ServerWebExchange): Mono<String> {
val authorizeRequest = OAuth2AuthorizeRequest.withClientRegistrationId("okta")
.attribute(ServerWebExchange::class.java.name, exchange)
.build()
return authorizedClientManager.authorize(authorizeRequest)
.map { it.accessToken }
ServerWebExchange is an OPTIONAL attribute.
If not provided, it will be obtained from the Reactor’s Context via the key ServerWebExchange.class .
Resource Owner Password Credentials
Please refer to the OAuth 2.0 Authorization Framework for further details on the Resource Owner Password Credentials grant. |
Please refer to the Access Token Request/Response protocol flow for the Resource Owner Password Credentials grant. |
for the Resource Owner Password Credentials grant is WebClientReactivePasswordTokenResponseClient
The WebClientReactivePasswordTokenResponseClient
If you need to customize the pre-processing of the Token Request, you can provide WebClientReactivePasswordTokenResponseClient.setParametersConverter()
with a custom Converter<OAuth2PasswordGrantRequest, MultiValueMap<String, String>>
parameter of a standard OAuth 2.0 Access Token Request which is used to construct the request. Other parameters required by the Resource Owner Password Credentials grant are added directly to the body of the request by the WebClientReactivePasswordTokenResponseClient
If you prefer to only add additional parameters, you can instead provide WebClientReactivePasswordTokenResponseClient.addParametersConverter() with a custom Converter<OAuth2PasswordGrantRequest, MultiValueMap<String, String>> which constructs an aggregate Converter .
On the other end, if you need to customize the post-handling of the Token Response, you will need to provide WebClientReactivePasswordTokenResponseClient.setBodyExtractor()
Alternatively, if your requirements are more advanced, you can take full control of the request/response by simply providing WebClientReactivePasswordTokenResponseClient.setWebClient()
Whether you customize WebClientReactivePasswordTokenResponseClient
Java
Kotlin
// Customize
ReactiveOAuth2AccessTokenResponseClient<OAuth2PasswordGrantRequest> passwordTokenResponseClient = ...
.password(configurer -> configurer.accessTokenResponseClient(passwordTokenResponseClient))
.refreshToken()
val passwordTokenResponseClient: ReactiveOAuth2AccessTokenResponseClient<OAuth2PasswordGrantRequest> = ...
val authorizedClientProvider = ReactiveOAuth2AuthorizedClientProviderBuilder.builder()
.password { it.accessTokenResponseClient(passwordTokenResponseClient) }
.refreshToken()
.build()
ReactiveOAuth2AuthorizedClientProviderBuilder.builder().password() configures a PasswordReactiveOAuth2AuthorizedClientProvider ,
which is an implementation of a ReactiveOAuth2AuthorizedClientProvider for the Resource Owner Password Credentials grant.
spring:
security:
oauth2:
client:
registration:
okta:
authorization-grant-type: password
scope: read, write
provider:
okta:
Java
Kotlin
.password()
.refreshToken()
// Assuming the `username` and `password` are supplied as `ServerHttpRequest` parameters,
// map the `ServerHttpRequest` parameters to `OAuth2AuthorizationContext.getAttributes()`
authorizedClientManager.setContextAttributesMapper(contextAttributesMapper());
private Function<OAuth2AuthorizeRequest, Mono<Map<String, Object>>> contextAttributesMapper() {
return authorizeRequest -> {
Map<String, Object> contextAttributes = Collections.emptyMap();
ServerWebExchange exchange = authorizeRequest.getAttribute(ServerWebExchange.class.getName());
ServerHttpRequest request = exchange.getRequest();
String username = request.getQueryParams().getFirst(OAuth2ParameterNames.USERNAME);
String password = request.getQueryParams().getFirst(OAuth2ParameterNames.PASSWORD);
if (StringUtils.hasText(username) && StringUtils.hasText(password)) {
contextAttributes = new HashMap<>();
// `PasswordReactiveOAuth2AuthorizedClientProvider` requires both attributes
contextAttributes.put(OAuth2AuthorizationContext.USERNAME_ATTRIBUTE_NAME, username);
contextAttributes.put(OAuth2AuthorizationContext.PASSWORD_ATTRIBUTE_NAME, password);
return Mono.just(contextAttributes);
.password()
.refreshToken()
.build()
private fun contextAttributesMapper(): Function<OAuth2AuthorizeRequest, Mono<MutableMap<String, Any>>> {
return Function { authorizeRequest ->
var contextAttributes: MutableMap<String, Any> = mutableMapOf()
val exchange: ServerWebExchange = authorizeRequest.getAttribute(ServerWebExchange::class.java.name)!!
val request: ServerHttpRequest = exchange.request
val username: String? = request.queryParams.getFirst(OAuth2ParameterNames.USERNAME)
val password: String? = request.queryParams.getFirst(OAuth2ParameterNames.PASSWORD)
contextAttributes = hashMapOf()
contextAttributes[OAuth2AuthorizationContext.USERNAME_ATTRIBUTE_NAME] = username!!
contextAttributes[OAuth2AuthorizationContext.PASSWORD_ATTRIBUTE_NAME] = password!!
as follows:
Java
Kotlin
@Controller
@Autowired
@GetMapping("/")
@Controller
@Autowired
@GetMapping("/")
.build()
JWT Bearer
Please refer to JSON Web Token (JWT) Profile for OAuth 2.0 Client Authentication and Authorization Grants for further details on the JWT Bearer grant. |
Please refer to the Access Token Request/Response protocol flow for the JWT Bearer grant. |
for the JWT Bearer grant is WebClientReactiveJwtBearerTokenResponseClient
The WebClientReactiveJwtBearerTokenResponseClient
If you need to customize the pre-processing of the Token Request, you can provide WebClientReactiveJwtBearerTokenResponseClient.setParametersConverter()
with a custom Converter<JwtBearerGrantRequest, MultiValueMap<String, String>>
parameter of a standard OAuth 2.0 Access Token Request which is used to construct the request. Other parameters required by the JWT Bearer grant are added directly to the body of the request by the WebClientReactiveJwtBearerTokenResponseClient
If you prefer to only add additional parameters, you can instead provide WebClientReactiveJwtBearerTokenResponseClient.addParametersConverter() with a custom Converter<JwtBearerGrantRequest, MultiValueMap<String, String>> which constructs an aggregate Converter .
On the other end, if you need to customize the post-handling of the Token Response, you will need to provide WebClientReactiveJwtBearerTokenResponseClient.setBodyExtractor()
Alternatively, if your requirements are more advanced, you can take full control of the request/response by simply providing WebClientReactiveJwtBearerTokenResponseClient.setWebClient()
Whether you customize WebClientReactiveJwtBearerTokenResponseClient
Java
Kotlin
// Customize
ReactiveOAuth2AccessTokenResponseClient<JwtBearerGrantRequest> jwtBearerTokenResponseClient = ...
JwtBearerReactiveOAuth2AuthorizedClientProvider jwtBearerAuthorizedClientProvider = new JwtBearerReactiveOAuth2AuthorizedClientProvider();
jwtBearerAuthorizedClientProvider.setAccessTokenResponseClient(jwtBearerTokenResponseClient);
.provider(jwtBearerAuthorizedClientProvider)
// Customize
val jwtBearerTokenResponseClient: ReactiveOAuth2AccessTokenResponseClient<JwtBearerGrantRequest> = ...
val jwtBearerAuthorizedClientProvider = JwtBearerReactiveOAuth2AuthorizedClientProvider()
.build()
spring:
security:
oauth2:
client:
registration:
okta:
authorization-grant-type: urn:ietf:params:oauth:grant-type:jwt-bearer
scope: read
provider:
okta:
…and the OAuth2AuthorizedClientManager
Java
Kotlin
.build()
as follows:
Java
Kotlin
@RestController
public class OAuth2ResourceServerController {
@Autowired
@GetMapping("/resource")
public Mono<String> resource(JwtAuthenticationToken jwtAuthentication, ServerWebExchange exchange) {
.principal(jwtAuthentication)
@Autowired
fun resource(jwtAuthentication: JwtAuthenticationToken, exchange: ServerWebExchange): Mono<String> {
.build()
JwtBearerReactiveOAuth2AuthorizedClientProvider resolves the Jwt assertion via OAuth2AuthorizationContext.getPrincipal().getPrincipal() by default, hence the use of JwtAuthenticationToken in the preceding example.
If you need to resolve the Jwt assertion from a different source, you can provide JwtBearerReactiveOAuth2AuthorizedClientProvider.setJwtAssertionResolver() with a custom Function<OAuth2AuthorizationContext, Mono<Jwt>> .
Token Exchange
Please refer to OAuth 2.0 Token Exchange for further details on the Token Exchange grant. |
Please refer to the Token Exchange Request and Response protocol flow for the Token Exchange grant. |
for the Token Exchange grant is WebClientReactiveTokenExchangeTokenResponseClient
The WebClientReactiveTokenExchangeTokenResponseClient
If you need to customize the pre-processing of the Token Request, you can provide WebClientReactiveTokenExchangeTokenResponseClient.setParametersConverter()
with a custom Converter<TokenExchangeGrantRequest, MultiValueMap<String, String>>
Other parameters required by the Token Exchange grant are added directly to the body of the request by the WebClientReactiveTokenExchangeTokenResponseClient
If you prefer to only add additional parameters, you can instead provide WebClientReactiveTokenExchangeTokenResponseClient.addParametersConverter() with a custom Converter<TokenExchangeGrantRequest, MultiValueMap<String, String>> which constructs an aggregate Converter .
On the other end, if you need to customize the post-handling of the Token Response, you will need to provide WebClientReactiveTokenExchangeTokenResponseClient.setBodyExtractor()
Alternatively, if your requirements are more advanced, you can take full control of the request/response by simply providing WebClientReactiveTokenExchangeTokenResponseClient.setWebClient()
Whether you customize WebClientReactiveTokenExchangeTokenResponseClient
Java
Kotlin
// Customize
ReactiveOAuth2AccessTokenResponseClient<TokenExchangeGrantRequest> tokenExchangeTokenResponseClient = ...
TokenExchangeReactiveOAuth2AuthorizedClientProvider tokenExchangeAuthorizedClientProvider = new TokenExchangeReactiveOAuth2AuthorizedClientProvider();
tokenExchangeAuthorizedClientProvider.setAccessTokenResponseClient(tokenExchangeTokenResponseClient);
.provider(tokenExchangeAuthorizedClientProvider)
// Customize
val tokenExchangeTokenResponseClient: ReactiveOAuth2AccessTokenResponseClient<TokenExchangeGrantRequest> = ...
val tokenExchangeAuthorizedClientProvider = TokenExchangeReactiveOAuth2AuthorizedClientProvider()
.build()
spring:
security:
oauth2:
client:
registration:
okta:
authorization-grant-type: urn:ietf:params:oauth:grant-type:token-exchange
scope: read
provider:
okta:
Java
Kotlin
.build()
as follows:
Java
Kotlin
@RestController
@Autowired
public Mono<String> resource(JwtAuthenticationToken jwtAuthentication) {
@Autowired
fun resource(jwtAuthentication: JwtAuthenticationToken): Mono<String> {
.build()
TokenExchangeReactiveOAuth2AuthorizedClientProvider resolves the subject token (as an OAuth2Token ) via OAuth2AuthorizationContext.getPrincipal().getPrincipal() by default, hence the use of JwtAuthenticationToken in the preceding example.
An actor token is not resolved by default.
If you need to resolve the subject token from a different source, you can provide TokenExchangeReactiveOAuth2AuthorizedClientProvider.setSubjectTokenResolver() with a custom Function<OAuth2AuthorizationContext, Mono<OAuth2Token>> .
If you need to resolve an actor token, you can provide TokenExchangeReactiveOAuth2AuthorizedClientProvider.setActorTokenResolver() with a custom Function<OAuth2AuthorizationContext, Mono<OAuth2Token>> .
