For the latest stable version, please use Spring Security 6.4.1! |
Authorization Grant Support
This section describes Spring Security’s support for authorization grants.
Authorization Code
See the OAuth 2.0 Authorization Framework for further details on the Authorization Code grant. |
Obtaining Authorization
See the Authorization Request/Response protocol flow for the Authorization Code grant. |
Initiating the Authorization Request
The OAuth2AuthorizationRequestRedirectFilter
uses an OAuth2AuthorizationRequestResolver
to resolve an OAuth2AuthorizationRequest
and initiate the Authorization Code grant flow by redirecting the end-user’s user-agent to the Authorization Server’s Authorization Endpoint.
The primary role of the OAuth2AuthorizationRequestResolver
is to resolve an OAuth2AuthorizationRequest
from the provided web request.
The default implementation DefaultOAuth2AuthorizationRequestResolver
matches on the (default) path /oauth2/authorization/{registrationId}
, extracting the registrationId
, and using it to build the OAuth2AuthorizationRequest
for the associated ClientRegistration
Consider the following Spring Boot properties for an OAuth 2.0 Client registration:
spring:
security:
oauth2:
client:
registration:
okta:
client-id: okta-client-id
authorization-grant-type: authorization_code
redirect-uri: "{baseUrl}/authorized/okta"
scope: read, write
provider:
okta:
authorization-uri: https://dev-1234.oktapreview.com/oauth2/v1/authorize
token-uri: https://dev-1234.oktapreview.com/oauth2/v1/token
Given the preceding properties, a request with the base path /oauth2/authorization/okta
initiates the Authorization Request redirect by the OAuth2AuthorizationRequestRedirectFilter
and ultimately starts the Authorization Code grant flow.
The |
If the OAuth 2.0 Client is a Public Client, configure the OAuth 2.0 Client registration as follows:
spring:
security:
oauth2:
client:
registration:
okta:
client-authentication-method: none
Public Clients are supported by using Proof Key for Code Exchange (PKCE). If the client is running in an untrusted environment (such as a native application or web browser-based application) and is therefore incapable of maintaining the confidentiality of its credentials, PKCE is automatically used when the following conditions are true:
client-secret
is omitted (or empty) -
is set tonone
(ClientAuthenticationMethod.NONE
If the OAuth 2.0 Provider supports PKCE for Confidential Clients, you may (optionally) configure it using DefaultOAuth2AuthorizationRequestResolver.setAuthorizationRequestCustomizer(OAuth2AuthorizationRequestCustomizers.withPkce()) .
The DefaultOAuth2AuthorizationRequestResolver
also supports URI
template variables for the redirect-uri
by using UriComponentsBuilder
The following configuration uses all the supported URI
template variables:
spring:
security:
oauth2:
client:
registration:
okta:
redirect-uri: "{baseScheme}://{baseHost}{basePort}{basePath}/authorized/{registrationId}"
Configuring the redirect-uri
with URI
template variables is especially useful when the OAuth 2.0 Client is running behind a Proxy Server.
Doing so ensures that the X-Forwarded-*
headers are used when expanding the redirect-uri
Customizing the Authorization Request
One of the primary use cases an OAuth2AuthorizationRequestResolver
can realize is the ability to customize the Authorization Request with additional parameters above the standard parameters defined in the OAuth 2.0 Authorization Framework.
For example, OpenID Connect defines additional OAuth 2.0 request parameters for the Authorization Code Flow extending from the standard parameters defined in the OAuth 2.0 Authorization Framework.
One of those extended parameters is the prompt
parameter.
The |
The following example shows how to configure the DefaultOAuth2AuthorizationRequestResolver
with a Consumer<OAuth2AuthorizationRequest.Builder>
that customizes the Authorization Request for oauth2Login()
, by including the request parameter prompt=consent
Java
Kotlin
@EnableWebSecurity
public class OAuth2LoginSecurityConfig {
@Autowired
private ClientRegistrationRepository clientRegistrationRepository;
http
.anyRequest().authenticated()
.oauth2Login(oauth2 -> oauth2
.authorizationEndpoint(authorization -> authorization
.authorizationRequestResolver(
authorizationRequestResolver(this.clientRegistrationRepository)
return http.build();
private OAuth2AuthorizationRequestResolver authorizationRequestResolver(
ClientRegistrationRepository clientRegistrationRepository) {
DefaultOAuth2AuthorizationRequestResolver authorizationRequestResolver =
new DefaultOAuth2AuthorizationRequestResolver(
clientRegistrationRepository, "/oauth2/authorization");
authorizationRequestResolver.setAuthorizationRequestCustomizer(
authorizationRequestCustomizer());
return authorizationRequestResolver;
private Consumer<OAuth2AuthorizationRequest.Builder> authorizationRequestCustomizer() {
return customizer -> customizer
.additionalParameters(params -> params.put("prompt", "consent"));
@EnableWebSecurity
class SecurityConfig {
@Autowired
private lateinit var customClientRegistrationRepository: ClientRegistrationRepository
http {
authorizeRequests {
oauth2Login {
authorizationEndpoint {
authorizationRequestResolver = authorizationRequestResolver(customClientRegistrationRepository)
return http.build()
private fun authorizationRequestResolver(
clientRegistrationRepository: ClientRegistrationRepository?): OAuth2AuthorizationRequestResolver? {
val authorizationRequestResolver = DefaultOAuth2AuthorizationRequestResolver(
private fun authorizationRequestCustomizer(): Consumer<OAuth2AuthorizationRequest.Builder> {
return Consumer { customizer ->
customizer
.additionalParameters { params -> params["prompt"] = "consent" }
For the simple use case where the additional request parameter is always the same for a specific provider, you can add it directly in the authorization-uri
property.
For example, if the value for the request parameter prompt
is always consent
for the provider okta
, you can configure it as follows:
spring:
security:
oauth2:
client:
provider:
okta:
authorization-uri: https://dev-1234.oktapreview.com/oauth2/v1/authorize?prompt=consent
The preceding example shows the common use case of adding a custom parameter on top of the standard parameters.
Alternatively, if your requirements are more advanced, you can take full control in building the Authorization Request URI by overriding the OAuth2AuthorizationRequest.authorizationRequestUri
property.
The following example shows a variation of authorizationRequestCustomizer()
from the preceding example and instead overrides the OAuth2AuthorizationRequest.authorizationRequestUri
property:
Java
Kotlin
.authorizationRequestUri(uriBuilder -> uriBuilder
.queryParam("prompt", "consent").build());
return Consumer { customizer: OAuth2AuthorizationRequest.Builder ->
customizer
.authorizationRequestUri { uriBuilder: UriBuilder ->
uriBuilder
Storing the Authorization Request
The AuthorizationRequestRepository
is responsible for the persistence of the OAuth2AuthorizationRequest
from the time the Authorization Request is initiated to the time the Authorization Response is received (the callback).
The |
The default implementation of AuthorizationRequestRepository
is HttpSessionOAuth2AuthorizationRequestRepository
, which stores the OAuth2AuthorizationRequest
in the HttpSession
If you have a custom implementation of AuthorizationRequestRepository
Java
Kotlin
Xml
@EnableWebSecurity
public class OAuth2ClientSecurityConfig {
http
.oauth2Client(oauth2 -> oauth2
.authorizationCodeGrant(codeGrant -> codeGrant
.authorizationRequestRepository(this.authorizationRequestRepository())
.authorizationEndpoint(endpoint -> endpoint
).build();
public AuthorizationRequestRepository<OAuth2AuthorizationRequest> authorizationRequestRepository() {
return new CustomOAuth2AuthorizationRequestRepository();
@EnableWebSecurity
http {
oauth2Client {
authorizationCodeGrant {
authorizationRequestRepository = authorizationRequestRepository()
return http.build()
<http>
<oauth2-client>
<authorization-code-grant authorization-request-repository-ref="authorizationRequestRepository"/>
</oauth2-client>
</http>
Requesting an Access Token
See the Access Token Request/Response protocol flow for the Authorization Code grant. |
The default implementation of OAuth2AccessTokenResponseClient
for the Authorization Code grant is DefaultAuthorizationCodeTokenResponseClient
, which uses a RestOperations
instance to exchange an authorization code for an access token at the Authorization Server’s Token Endpoint.
The DefaultAuthorizationCodeTokenResponseClient
is flexible, as it lets you customize the pre-processing of the Token Request and/or post-handling of the Token Response.
Customizing the Access Token Request
If you need to customize the pre-processing of the Token Request, you can provide DefaultAuthorizationCodeTokenResponseClient.setRequestEntityConverter()
with a custom Converter<OAuth2AuthorizationCodeGrantRequest, RequestEntity<?>>
The default implementation (OAuth2AuthorizationCodeGrantRequestEntityConverter
) builds a RequestEntity
representation of a standard OAuth 2.0 Access Token Request.
However, providing a custom Converter
would let you extend the standard Token Request and add custom parameter(s).
To customize only the parameters of the request, you can provide OAuth2AuthorizationCodeGrantRequestEntityConverter.setParametersConverter()
with a custom Converter<OAuth2AuthorizationCodeGrantRequest, MultiValueMap<String, String>>
to completely override the parameters sent with the request. This is often simpler than constructing a RequestEntity
directly.
If you prefer to only add additional parameters, you can provide |
The custom |
Customizing the Access Token Response
On the other end, if you need to customize the post-handling of the Token Response, you need to provide DefaultAuthorizationCodeTokenResponseClient.setRestOperations()
with a custom configured RestOperations
The default RestOperations
is configured as follows:
Java
Kotlin
RestTemplate restTemplate = new RestTemplate(Arrays.asList(
new FormHttpMessageConverter(),
new OAuth2AccessTokenResponseHttpMessageConverter()));
restTemplate.setErrorHandler(new OAuth2ErrorResponseErrorHandler());
val restTemplate = RestTemplate(listOf(
restTemplate.errorHandler = OAuth2ErrorResponseErrorHandler()
Spring MVC |
is an HttpMessageConverter
for an OAuth 2.0 Access Token Response.
You can provide OAuth2AccessTokenResponseHttpMessageConverter.setAccessTokenResponseConverter()
with a custom Converter<Map<String, Object>, OAuth2AccessTokenResponse>
that is used for converting the OAuth 2.0 Access Token Response parameters to an OAuth2AccessTokenResponse
is a ResponseErrorHandler
that can handle an OAuth 2.0 Error, such as 400 Bad Request
It uses an OAuth2ErrorHttpMessageConverter
for converting the OAuth 2.0 Error parameters to an OAuth2Error
Whether you customize DefaultAuthorizationCodeTokenResponseClient
or provide your own implementation of OAuth2AccessTokenResponseClient
, you need to configure it as follows:
Java
Kotlin
Xml
@EnableWebSecurity
http
.accessTokenResponseClient(this.accessTokenResponseClient())
@EnableWebSecurity
http {
oauth2Client {
accessTokenResponseClient = accessTokenResponseClient()
return http.build()
<http>
<oauth2-client>
<authorization-code-grant access-token-response-client-ref="accessTokenResponseClient"/>
</oauth2-client>
</http>
Refresh Token
See the OAuth 2.0 Authorization Framework for further details on the Refresh Token. |
Refreshing an Access Token
See the Access Token Request/Response protocol flow for the Refresh Token grant. |
for the Refresh Token grant is DefaultRefreshTokenTokenResponseClient
when refreshing an access token at the Authorization Server’s Token Endpoint.
The DefaultRefreshTokenTokenResponseClient
is flexible, as it lets you customize the pre-processing of the Token Request or post-handling of the Token Response.
If you need to customize the pre-processing of the Token Request, you can provide DefaultRefreshTokenTokenResponseClient.setRequestEntityConverter()
with a custom Converter<OAuth2RefreshTokenGrantRequest, RequestEntity<?>>
The default implementation (OAuth2RefreshTokenGrantRequestEntityConverter
To customize only the parameters of the request, you can provide OAuth2RefreshTokenGrantRequestEntityConverter.setParametersConverter()
with a custom Converter<OAuth2RefreshTokenGrantRequest, MultiValueMap<String, String>>
directly.
The custom |
On the other end, if you need to customize the post-handling of the Token Response, you need to provide DefaultRefreshTokenTokenResponseClient.setRestOperations()
Java
Kotlin
Spring MVC |
is a HttpMessageConverter
Whether you customize DefaultRefreshTokenTokenResponseClient
Java
Kotlin
// Customize
OAuth2AccessTokenResponseClient<OAuth2RefreshTokenGrantRequest> refreshTokenTokenResponseClient = ...
OAuth2AuthorizedClientProvider authorizedClientProvider =
OAuth2AuthorizedClientProviderBuilder.builder()
.authorizationCode()
.refreshToken(configurer -> configurer.accessTokenResponseClient(refreshTokenTokenResponseClient))
authorizedClientManager.setAuthorizedClientProvider(authorizedClientProvider);
// Customize
val refreshTokenTokenResponseClient: OAuth2AccessTokenResponseClient<OAuth2RefreshTokenGrantRequest> = ...
val authorizedClientProvider = OAuth2AuthorizedClientProviderBuilder.builder()
.refreshToken { it.accessTokenResponseClient(refreshTokenTokenResponseClient) }
.build()
The OAuth2RefreshToken
can optionally be returned in the Access Token Response for the authorization_code
and password
grant types.
If the OAuth2AuthorizedClient.getRefreshToken()
is available and the OAuth2AuthorizedClient.getAccessToken()
is expired, it is automatically refreshed by the RefreshTokenOAuth2AuthorizedClientProvider
Client Credentials
Please refer to the OAuth 2.0 Authorization Framework for further details on the Client Credentials grant. |
See the OAuth 2.0 Authorization Framework for further details on the Client Credentials grant. |
for the Client Credentials grant is DefaultClientCredentialsTokenResponseClient
when requesting an access token at the Authorization Server’s Token Endpoint.
The DefaultClientCredentialsTokenResponseClient
If you need to customize the pre-processing of the Token Request, you can provide DefaultClientCredentialsTokenResponseClient.setRequestEntityConverter()
with a custom Converter<OAuth2ClientCredentialsGrantRequest, RequestEntity<?>>
The default implementation (OAuth2ClientCredentialsGrantRequestEntityConverter
To customize only the parameters of the request, you can provide OAuth2ClientCredentialsGrantRequestEntityConverter.setParametersConverter()
with a custom Converter<OAuth2ClientCredentialsGrantRequest, MultiValueMap<String, String>>
directly.
The custom |
On the other end, if you need to customize the post-handling of the Token Response, you need to provide DefaultClientCredentialsTokenResponseClient.setRestOperations()
Java
Kotlin
Spring MVC |
to convert the OAuth 2.0 Error parameters to an OAuth2Error
Whether you customize DefaultClientCredentialsTokenResponseClient
Java
Kotlin
// Customize
OAuth2AccessTokenResponseClient<OAuth2ClientCredentialsGrantRequest> clientCredentialsTokenResponseClient = ...
.clientCredentials(configurer -> configurer.accessTokenResponseClient(clientCredentialsTokenResponseClient))
// Customize
val clientCredentialsTokenResponseClient: OAuth2AccessTokenResponseClient<OAuth2ClientCredentialsGrantRequest> = ...
.clientCredentials { it.accessTokenResponseClient(clientCredentialsTokenResponseClient) }
.build()
Using the Access Token
spring:
security:
oauth2:
client:
registration:
okta:
authorization-grant-type: client_credentials
scope: read, write
provider:
okta:
Further consider the following OAuth2AuthorizedClientManager
Java
Kotlin
public OAuth2AuthorizedClientManager authorizedClientManager(
ClientRegistrationRepository clientRegistrationRepository,
OAuth2AuthorizedClientRepository authorizedClientRepository) {
.clientCredentials()
DefaultOAuth2AuthorizedClientManager authorizedClientManager =
new DefaultOAuth2AuthorizedClientManager(
clientRegistrationRepository, authorizedClientRepository);
return authorizedClientManager;
fun authorizedClientManager(
clientRegistrationRepository: ClientRegistrationRepository,
authorizedClientRepository: OAuth2AuthorizedClientRepository): OAuth2AuthorizedClientManager {
.build()
val authorizedClientManager = DefaultOAuth2AuthorizedClientManager(
Given the preceding properties and bean, you can obtain the OAuth2AccessToken
as follows:
Java
Kotlin
@Controller
@Autowired
private OAuth2AuthorizedClientManager authorizedClientManager;
@GetMapping("/")
public String index(Authentication authentication,
HttpServletRequest servletRequest,
HttpServletResponse servletResponse) {
OAuth2AuthorizeRequest authorizeRequest = OAuth2AuthorizeRequest.withClientRegistrationId("okta")
.principal(authentication)
.attributes(attrs -> {
attrs.put(HttpServletRequest.class.getName(), servletRequest);
attrs.put(HttpServletResponse.class.getName(), servletResponse);
OAuth2AuthorizedClient authorizedClient = this.authorizedClientManager.authorize(authorizeRequest);
OAuth2AccessToken accessToken = authorizedClient.getAccessToken();
return "index";
@Autowired
private lateinit var authorizedClientManager: OAuth2AuthorizedClientManager
@GetMapping("/")
fun index(authentication: Authentication?,
servletRequest: HttpServletRequest,
servletResponse: HttpServletResponse): String {
val authorizeRequest: OAuth2AuthorizeRequest = OAuth2AuthorizeRequest.withClientRegistrationId("okta")
.attributes(Consumer { attrs: MutableMap<String, Any> ->
attrs[HttpServletRequest::class.java.name] = servletRequest
attrs[HttpServletResponse::class.java.name] = servletResponse
.build()
val authorizedClient = authorizedClientManager.authorize(authorizeRequest)
val accessToken: OAuth2AccessToken = authorizedClient.accessToken
return "index"
Resource Owner Password Credentials
See the OAuth 2.0 Authorization Framework for further details on the Resource Owner Password Credentials grant. |
See the Access Token Request/Response protocol flow for the Resource Owner Password Credentials grant. |
for the Resource Owner Password Credentials grant is DefaultPasswordTokenResponseClient
The DefaultPasswordTokenResponseClient
If you need to customize the pre-processing of the Token Request, you can provide DefaultPasswordTokenResponseClient.setRequestEntityConverter()
with a custom Converter<OAuth2PasswordGrantRequest, RequestEntity<?>>
The default implementation (OAuth2PasswordGrantRequestEntityConverter
To customize only the parameters of the request, you can provide OAuth2PasswordGrantRequestEntityConverter.setParametersConverter()
with a custom Converter<OAuth2PasswordGrantRequest, MultiValueMap<String, String>>
directly.
The custom |
On the other end, if you need to customize the post-handling of the Token Response, you need to provide DefaultPasswordTokenResponseClient.setRestOperations()
Java
Kotlin
Spring MVC |
You can provide OAuth2AccessTokenResponseHttpMessageConverter.setTokenResponseConverter()
with a custom Converter<Map<String, String>, OAuth2AccessTokenResponse>
that is used to convert the OAuth 2.0 Access Token Response parameters to an OAuth2AccessTokenResponse
Whether you customize DefaultPasswordTokenResponseClient
Java
Kotlin
// Customize
OAuth2AccessTokenResponseClient<OAuth2PasswordGrantRequest> passwordTokenResponseClient = ...
.password(configurer -> configurer.accessTokenResponseClient(passwordTokenResponseClient))
.refreshToken()
val passwordTokenResponseClient: OAuth2AccessTokenResponseClient<OAuth2PasswordGrantRequest> = ...
.password { it.accessTokenResponseClient(passwordTokenResponseClient) }
.refreshToken()
.build()
spring:
security:
oauth2:
client:
registration:
okta:
authorization-grant-type: password
scope: read, write
provider:
okta:
Further consider the OAuth2AuthorizedClientManager
Java
Kotlin
.password()
.refreshToken()
// Assuming the `username` and `password` are supplied as `HttpServletRequest` parameters,
// map the `HttpServletRequest` parameters to `OAuth2AuthorizationContext.getAttributes()`
authorizedClientManager.setContextAttributesMapper(contextAttributesMapper());
private Function<OAuth2AuthorizeRequest, Map<String, Object>> contextAttributesMapper() {
return authorizeRequest -> {
Map<String, Object> contextAttributes = Collections.emptyMap();
HttpServletRequest servletRequest = authorizeRequest.getAttribute(HttpServletRequest.class.getName());
String username = servletRequest.getParameter(OAuth2ParameterNames.USERNAME);
String password = servletRequest.getParameter(OAuth2ParameterNames.PASSWORD);
if (StringUtils.hasText(username) && StringUtils.hasText(password)) {
contextAttributes = new HashMap<>();
// `PasswordOAuth2AuthorizedClientProvider` requires both attributes
contextAttributes.put(OAuth2AuthorizationContext.USERNAME_ATTRIBUTE_NAME, username);
contextAttributes.put(OAuth2AuthorizationContext.PASSWORD_ATTRIBUTE_NAME, password);
return contextAttributes;
.password()
.refreshToken()
.build()
private fun contextAttributesMapper(): Function<OAuth2AuthorizeRequest, MutableMap<String, Any>> {
return Function { authorizeRequest ->
var contextAttributes: MutableMap<String, Any> = mutableMapOf()
val servletRequest: HttpServletRequest = authorizeRequest.getAttribute(HttpServletRequest::class.java.name)
val username = servletRequest.getParameter(OAuth2ParameterNames.USERNAME)
val password = servletRequest.getParameter(OAuth2ParameterNames.PASSWORD)
contextAttributes = hashMapOf()
contextAttributes[OAuth2AuthorizationContext.USERNAME_ATTRIBUTE_NAME] = username
contextAttributes[OAuth2AuthorizationContext.PASSWORD_ATTRIBUTE_NAME] = password
contextAttributes
as follows:
Java
Kotlin
@Controller
@Autowired
@GetMapping("/")
return "index";
@Controller
@Autowired
@GetMapping("/")
it[HttpServletRequest::class.java.name] = servletRequest
it[HttpServletResponse::class.java.name] = servletResponse
.build()
return "index"
JWT Bearer
Please refer to JSON Web Token (JWT) Profile for OAuth 2.0 Client Authentication and Authorization Grants for further details on the JWT Bearer grant. |
Please refer to the Access Token Request/Response protocol flow for the JWT Bearer grant. |
for the JWT Bearer grant is DefaultJwtBearerTokenResponseClient
The DefaultJwtBearerTokenResponseClient
is quite flexible as it allows you to customize the pre-processing of the Token Request and/or post-handling of the Token Response.
If you need to customize the pre-processing of the Token Request, you can provide DefaultJwtBearerTokenResponseClient.setRequestEntityConverter()
with a custom Converter<JwtBearerGrantRequest, RequestEntity<?>>
The default implementation JwtBearerGrantRequestEntityConverter
representation of a OAuth 2.0 Access Token Request.
, would allow you to extend the Token Request and add custom parameter(s).
To customize only the parameters of the request, you can provide JwtBearerGrantRequestEntityConverter.setParametersConverter()
with a custom Converter<JwtBearerGrantRequest, MultiValueMap<String, String>>
directly.
If you prefer to only add additional parameters, you can provide JwtBearerGrantRequestEntityConverter.addParametersConverter() with a custom Converter<JwtBearerGrantRequest, MultiValueMap<String, String>> which constructs an aggregate Converter .
On the other end, if you need to customize the post-handling of the Token Response, you will need to provide DefaultJwtBearerTokenResponseClient.setRestOperations()
Java
Kotlin
Spring MVC |
that can handle an OAuth 2.0 Error, eg. 400 Bad Request.
Whether you customize DefaultJwtBearerTokenResponseClient
, you’ll need to configure it as shown in the following example:
Java
Kotlin
// Customize
OAuth2AccessTokenResponseClient<JwtBearerGrantRequest> jwtBearerTokenResponseClient = ...
JwtBearerOAuth2AuthorizedClientProvider jwtBearerAuthorizedClientProvider = new JwtBearerOAuth2AuthorizedClientProvider();
jwtBearerAuthorizedClientProvider.setAccessTokenResponseClient(jwtBearerTokenResponseClient);
.provider(jwtBearerAuthorizedClientProvider)
// Customize
val jwtBearerTokenResponseClient: OAuth2AccessTokenResponseClient<JwtBearerGrantRequest> = ...
val jwtBearerAuthorizedClientProvider = JwtBearerOAuth2AuthorizedClientProvider()
.build()
Given the following Spring Boot properties for an OAuth 2.0 Client registration:
spring:
security:
oauth2:
client:
registration:
okta:
authorization-grant-type: urn:ietf:params:oauth:grant-type:jwt-bearer
scope: read
provider:
okta:
…and the OAuth2AuthorizedClientManager
Java
Kotlin
.build()
You may obtain the OAuth2AccessToken
as follows:
Java
Kotlin
@RestController
public class OAuth2ResourceServerController {
@Autowired
@GetMapping("/resource")
public String resource(JwtAuthenticationToken jwtAuthentication) {
.principal(jwtAuthentication)
@Autowired
fun resource(jwtAuthentication: JwtAuthenticationToken?): String {
.build()
JwtBearerOAuth2AuthorizedClientProvider resolves the Jwt assertion via OAuth2AuthorizationContext.getPrincipal().getPrincipal() by default, hence the use of JwtAuthenticationToken in the preceding example.
If you need to resolve the Jwt assertion from a different source, you can provide JwtBearerOAuth2AuthorizedClientProvider.setJwtAssertionResolver() with a custom Function<OAuth2AuthorizationContext, Jwt> .
Token Exchange
Please refer to OAuth 2.0 Token Exchange for further details on the Token Exchange grant. |
Please refer to the Token Exchange Request and Response protocol flow for the Token Exchange grant. |
for the Token Exchange grant is DefaultTokenExchangeTokenResponseClient
The DefaultTokenExchangeTokenResponseClient
If you need to customize the pre-processing of the Token Request, you can provide DefaultTokenExchangeTokenResponseClient.setRequestEntityConverter()
with a custom Converter<TokenExchangeGrantRequest, RequestEntity<?>>
The default implementation TokenExchangeGrantRequestEntityConverter
To customize only the parameters of the request, you can provide TokenExchangeGrantRequestEntityConverter.setParametersConverter()
with a custom Converter<TokenExchangeGrantRequest, MultiValueMap<String, String>>
directly.
If you prefer to only add additional parameters, you can provide TokenExchangeGrantRequestEntityConverter.addParametersConverter() with a custom Converter<TokenExchangeGrantRequest, MultiValueMap<String, String>> which constructs an aggregate Converter .
On the other end, if you need to customize the post-handling of the Token Response, you will need to provide DefaultTokenExchangeTokenResponseClient.setRestOperations()
Java
Kotlin
Spring MVC |
Whether you customize DefaultTokenExchangeTokenResponseClient
Java
Kotlin
// Customize
OAuth2AccessTokenResponseClient<TokenExchangeGrantRequest> tokenExchangeTokenResponseClient = ...
TokenExchangeOAuth2AuthorizedClientProvider tokenExchangeAuthorizedClientProvider = new TokenExchangeOAuth2AuthorizedClientProvider();
tokenExchangeAuthorizedClientProvider.setAccessTokenResponseClient(tokenExchangeTokenResponseClient);
.provider(tokenExchangeAuthorizedClientProvider)
// Customize
val tokenExchangeTokenResponseClient: OAuth2AccessTokenResponseClient<TokenExchangeGrantRequest> = ...
val tokenExchangeAuthorizedClientProvider = TokenExchangeOAuth2AuthorizedClientProvider()
.build()
spring:
security:
oauth2:
client:
registration:
okta:
authorization-grant-type: urn:ietf:params:oauth:grant-type:token-exchange
scope: read
provider:
okta:
Java
Kotlin
.build()
as follows:
Java
Kotlin
@RestController
@Autowired
@Autowired
.build()
TokenExchangeOAuth2AuthorizedClientProvider resolves the subject token (as an OAuth2Token ) via OAuth2AuthorizationContext.getPrincipal().getPrincipal() by default, hence the use of JwtAuthenticationToken in the preceding example.
An actor token is not resolved by default.
If you need to resolve the subject token from a different source, you can provide TokenExchangeOAuth2AuthorizedClientProvider.setSubjectTokenResolver() with a custom Function<OAuth2AuthorizationContext, OAuth2Token> .
If you need to resolve an actor token, you can provide TokenExchangeOAuth2AuthorizedClientProvider.setActorTokenResolver() with a custom Function<OAuth2AuthorizationContext, OAuth2Token> .
