For the latest stable version, please use Spring Security 6.4.1! |
Web Application Security
<debug>
Enables Spring Security debugging infrastructure. This will provide human-readable (multi-line) debugging information to monitor requests coming into the security filters. This may include sensitive information, such as request parameters or headers, and should only be used in a development environment.
<http>
If you use an <http>
element within your application, a FilterChainProxy
bean named "springSecurityFilterChain" is created and the configuration within the element is used to build a filter chain within
FilterChainProxy
As of Spring Security 3.1, additional http
elements can be used to add extra filter chains [1] for how to set up the mapping from your web.xml
Some core filters are always created in a filter chain and others will be added to the stack depending on the attributes and child elements which are present.
The positions of the standard filters are fixed (see
the filter order table in the namespace introduction), removing a common source of errors with previous versions of the framework when users had to configure the filter chain explicitly in the
FilterChainProxy
bean.
You can, of course, still do this if you need full control of the configuration.
All filters which require a reference to the AuthenticationManager
will be automatically injected with the internal instance created by the namespace configuration.
Each <http>
namespace block always creates an SecurityContextPersistenceFilter
, an ExceptionTranslationFilter
and a FilterSecurityInterceptor
These are fixed and cannot be replaced with alternatives.
<http> Attributes
The attributes on the <http>
element control some of the properties on the core filters.
access-decision-manager-ref Optional attribute specifying the ID of the
AccessDecisionManager
implementation which should be used for authorizing HTTP requests. By default anAffirmativeBased
implementation is used for with aRoleVoter
and anAuthenticatedVoter
authentication-manager-ref A reference to the
used for theFilterChain
created by this http element.
observation-registry-ref A reference to the
ObservationRegistry
and related components
auto-config Automatically registers a login form, BASIC authentication, logout services. If set to "true", all of these capabilities are added (although you can still customize the configuration of each by providing the respective element). If unspecified, defaults to "false". Use of this attribute is not recommended. Use explicit configuration elements instead to avoid confusion.
create-session Controls the eagerness with which an HTTP session is created by Spring Security classes. Options include:
always
- Spring Security will proactively create a session if one does not exist. -
ifRequired
- Spring Security will only create a session only if one is required (default value). -
never
- Spring Security will never create a session, but will make use of one if the application does. -
stateless
- Spring Security will not create a session and ignore the session for obtaining a SpringAuthentication
disable-url-rewriting Prevents session IDs from being appended to URLs in the application. Clients must use cookies if this attribute is set to
true
. The default istrue
entry-point-ref Normally the
AuthenticationEntryPoint
used will be set depending on which authentication mechanisms have been configured. This attribute allows this behaviour to be overridden by defining a customizedAuthenticationEntryPoint
bean which will start the authentication process.
jaas-api-provision If available, runs the request as the
Subject
acquired from theJaasAuthenticationToken
which is implemented by adding aJaasApiIntegrationFilter
bean to the stack. Defaults tofalse
name A bean identifier, used for referring to the bean elsewhere in the context.
once-per-request Corresponds to the
observeOncePerRequest
property ofFilterSecurityInterceptor
. Defaults tofalse
filter-all-dispatcher-types Corresponds to the
shouldFilterAllDispatcherTypes
property of theAuthorizationFilter
. Does not work whenuse-authorization-manager=false
. Defaults totrue
pattern Defining a pattern for the http element controls the requests which will be filtered through the list of filters which it defines. The interpretation is dependent on the configured request-matcher. If no pattern is defined, all requests will be matched, so the most specific patterns should be declared first.
realm Sets the realm name used for basic authentication (if enabled). Corresponds to the
realmName
property onBasicAuthenticationEntryPoint
request-matcher Defines the
RequestMatcher
strategy used in theFilterChainProxy
and the beans created by theintercept-url
to match incoming requests. Options are currentlymvc
,ant
,regex
andciRegex
, for Spring MVC, ant, regular-expression and case-insensitive regular-expression respectively. A separate instance is created for each intercept-url element using its pattern, method and servlet-path attributes. Ant paths are matched using anAntPathRequestMatcher
, regular expressions are matched using aRegexRequestMatcher
and for Spring MVC path matching theMvcRequestMatcher
is used. See the Javadoc for these classes for more details on exactly how the matching is performed. MVC is the default strategy if Spring MVC is present in the classpath, if not, Ant paths are used.
request-matcher-ref A reference to a bean that implements
RequestMatcher
that will determine if thisFilterChain
should be used. This is a more powerful alternative to pattern.
security A request pattern can be mapped to an empty filter chain, by setting this attribute to
none
. No security will be applied and none of Spring Security’s features will be available.
security-context-repository-ref Allows injection of a custom
SecurityContextHolderStrategy
intoSecurityContextPersistenceFilter
,SecurityContextHolderFilter
,BasicAuthenticationFilter
,UsernamePasswordAuthenticationFilter
,ExceptionTranslationFilter
,LogoutFilter
, and others.
security-context-explicit-save If true, use
instead ofSecurityContextPersistenceFilter
. Requires explicit save
SecurityContextRepository
into theSecurityContextPersistenceFilter
servlet-api-provision Provides versions of
HttpServletRequest
security methods such asisUserInRole()
andgetPrincipal()
which are implemented by adding aSecurityContextHolderAwareRequestFilter
bean to the stack. Defaults totrue
use-expressions Enables EL-expressions in the
access
attribute, as described in the chapter on expression-based access-control. The default value is true.
<access-denied-handler>
This element allows you to set the errorPage
property for the default AccessDeniedHandler
used by the ExceptionTranslationFilter
, using the error-page attribute, or to supply your own implementation using the ref attribute.
This is discussed in more detail in the section on the ExceptionTranslationFilter.
<cors>
This element allows for configuring a CorsFilter
If no CorsFilter
or CorsConfigurationSource
is specified and Spring MVC is on the classpath, a HandlerMappingIntrospector
is used as the CorsConfigurationSource
<cors> Attributes
The attributes on the <cors>
element control the headers element.
ref Optional attribute that specifies the bean name of a
CorsFilter
cors-configuration-source-ref Optional attribute that specifies the bean name of a
to be injected into aCorsFilter
created by the XML namespace.
<headers>
This element allows for configuring additional (security) headers to be send with the response. It enables easy configuration for several headers and also allows for setting custom headers through the header element. Additional information, can be found in the Security Headers section of the reference.
Cache-Control
,Pragma
, andExpires
- Can be set using the cache-control element. This ensures that the browser does not cache your secured pages. -
Strict-Transport-Security
- Can be set using the hsts element. This ensures that the browser automatically requests HTTPS for future requests. -
X-Frame-Options
- Can be set using the frame-options element. The X-Frame-Options header can be used to prevent clickjacking attacks. -
X-XSS-Protection
- Can be set using the xss-protection element. The X-XSS-Protection header can be used by browser to do basic control. -
X-Content-Type-Options
- Can be set using the content-type-options element. The X-Content-Type-Options header prevents Internet Explorer from MIME-sniffing a response away from the declared content-type. This also applies to Google Chrome, when downloading extensions. -
Public-Key-Pinning
orPublic-Key-Pinning-Report-Only
- Can be set using the hpkp element. This allows HTTPS websites to resist impersonation by attackers using mis-issued or otherwise fraudulent certificates. -
Content-Security-Policy
orContent-Security-Policy-Report-Only
- Can be set using the content-security-policy element. Content Security Policy (CSP) is a mechanism that web applications can leverage to mitigate content injection vulnerabilities, such as cross-site scripting (XSS). -
Referrer-Policy
- Can be set using the referrer-policy element, Referrer-Policy is a mechanism that web applications can leverage to manage the referrer field, which contains the last page the user was on. -
Feature-Policy
- Can be set using the feature-policy element, Feature-Policy is a mechanism that allows web developers to selectively enable, disable, and modify the behavior of certain APIs and web features in the browser. -
Cross-Origin-Opener-Policy
- Can be set using the cross-origin-opener-policy element, Cross-Origin-Opener-Policy is a mechanism that allows you to ensure a top-level document does not share a browsing context group with cross-origin documents. -
Cross-Origin-Embedder-Policy
- Can be set using the cross-origin-embedder-policy element, Cross-Origin-Embedder-Policy is a mechanism that prevents a document from loading any cross-origin resources that don’t explicitly grant the document permission. -
Cross-Origin-Resource-Policy
- Can be set using the cross-origin-resource-policy element, Cross-Origin-Resource-Policy is a mechanism that conveys a desire that the browser blocks no-cors cross-origin/cross-site requests to the given resource.
<headers> Attributes
The attributes on the <headers>
defaults-disabled Optional attribute that specifies to disable the default Spring Security’s HTTP response headers. The default is false (the default headers are included).
disabled Optional attribute that specifies to disable Spring Security’s HTTP response headers. The default is false (the headers are enabled).
<cache-control>
<hsts>
When enabled adds the Strict-Transport-Security header to the response for any secure request. This allows the server to instruct browsers to automatically use HTTPS for future requests.
<hsts> Attributes
disabled Specifies if Strict-Transport-Security should be disabled. Default false.
include-sub-domains Specifies if subdomains should be included. Default true.
max-age-seconds Specifies the maximum amount of time the host should be considered a Known HSTS Host. Default one year.
request-matcher-ref The RequestMatcher instance to be used to determine if the header should be set. Default is if HttpServletRequest.isSecure() is true.
preload Specifies if preload should be included. Default false.
<hpkp>
When enabled adds the Public Key Pinning Extension for HTTP header to the response for any secure request. This allows HTTPS websites to resist impersonation by attackers using mis-issued or otherwise fraudulent certificates.
<hpkp> Attributes
disabled Specifies if HTTP Public Key Pinning (HPKP) should be disabled. Default true.
include-sub-domains Specifies if subdomains should be included. Default false.
max-age-seconds Sets the value for the max-age directive of the Public-Key-Pins header. Default 60 days.
report-only Specifies if the browser should only report pin validation failures. Default true.
report-uri Specifies the URI to which the browser should report pin validation failures.
<pin>
<content-security-policy>
When enabled adds the Content Security Policy (CSP) header to the response. CSP is a mechanism that web applications can leverage to mitigate content injection vulnerabilities, such as cross-site scripting (XSS).
<content-security-policy> Attributes
policy-directives The security policy directive(s) for the Content-Security-Policy header or if report-only is set to true, then the Content-Security-Policy-Report-Only header is used.
report-only Set to true, to enable the Content-Security-Policy-Report-Only header for reporting policy violations only. Defaults to false.
<referrer-policy>
When enabled adds the Referrer Policy header to the response.
<referrer-policy> Attributes
policy The policy for the Referrer-Policy header. Default "no-referrer".
<feature-policy>
When enabled adds the Feature Policy header to the response.
<feature-policy> Attributes
policy-directives The security policy directive(s) for the Feature-Policy header.
<frame-options>
When enabled adds the X-Frame-Options header to the response, this allows newer browsers to do some security checks and prevent clickjacking attacks.
<frame-options> Attributes
disabled If disabled, the X-Frame-Options header will not be included. Default false.
policy
DENY
The page cannot be displayed in a frame, regardless of the site attempting to do so. This is the default when frame-options-policy is specified. -
SAMEORIGIN
The page can only be displayed in a frame on the same origin as the page itself
In other words, if you specify DENY, not only will attempts to load the page in a frame fail when loaded from other sites, attempts to do so will fail when loaded from the same site. On the other hand, if you specify SAMEORIGIN, you can still use the page in a frame as long as the site including it in a frame it is the same as the one serving the page.
<permissions-policy>
Adds the Permissions-Policy header to the response.
<xss-protection>
Adds the X-XSS-Protection header to the response to assist in protecting against reflected / Type-1 Cross-Site Scripting (XSS) attacks. This is in no-way a full protection to XSS attacks!
<xss-protection> Attributes
xss-protection-disabled Do not include the header for reflected / Type-1 Cross-Site Scripting (XSS) protection.
xss-protection-header-value Explicitly set the value for reflected / Type-1 Cross-Site Scripting (XSS) header. One of: "0", "1", "1; mode=block". Defaults to "0".
<content-type-options>
Add the X-Content-Type-Options header with the value of nosniff to the response. This disables MIME-sniffing for IE8+ and Chrome extensions.
<content-type-options> Attributes
disabled Specifies if Content Type Options should be disabled. Default false.
Parent Elements of <content-type-options>
<cross-origin-embedder-policy>
When enabled adds the Cross-Origin-Embedder-Policy header to the response.
<cross-origin-embedder-policy> Attributes
header.
<cross-origin-opener-policy>
When enabled adds the Cross-Origin-Opener-Policy header to the response.
<cross-origin-opener-policy> Attributes
header.
<cross-origin-resource-policy>
When enabled adds the Cross-Origin-Resource-Policy header to the response.
<cross-origin-resource-policy> Attributes
header.
<header>
<anonymous>
Adds an AnonymousAuthenticationFilter
to the stack and an AnonymousAuthenticationProvider
Required if you are using the IS_AUTHENTICATED_ANONYMOUSLY
attribute.
<anonymous> Attributes
enabled With the default namespace setup, the anonymous "authentication" facility is automatically enabled. You can disable it using this property.
key The key shared between the provider and filter. This generally does not need to be set. If unset, it will default to a secure randomly generated value. This means setting this value can improve startup time when using the anonymous functionality since secure random values can take a while to be generated.
username The username that should be assigned to the anonymous request. This allows the principal to be identified, which may be important for logging and auditing. if unset, defaults to
anonymousUser
<csrf>
This element will add Cross Site Request Forger (CSRF) protection to the application. It also updates the default RequestCache to only replay "GET" requests upon successful authentication. Additional information can be found in the Cross Site Request Forgery (CSRF) section of the reference.
<csrf> Attributes
disabled Optional attribute that specifies to disable Spring Security’s CSRF protection. The default is false (CSRF protection is enabled). It is highly recommended to leave CSRF protection enabled.
token-repository-ref The CsrfTokenRepository to use. The default is
HttpSessionCsrfTokenRepository
request-handler-ref The optional
CsrfTokenRequestHandler
to use. The default isCsrfTokenRequestAttributeHandler
request-matcher-ref The RequestMatcher instance to be used to determine if CSRF should be applied. Default is any HTTP method except "GET", "TRACE", "HEAD", "OPTIONS".
<custom-filter>
This element is used to add a filter to the filter chain.
It doesn’t create any additional beans but is used to select a bean of type jakarta.servlet.Filter
which is already defined in the application context and add that at a particular position in the filter chain maintained by Spring Security.
Full details can be found in the namespace chapter.
<custom-filter> Attributes
after The filter immediately after which the custom-filter should be placed in the chain. This feature will only be needed by advanced users who wish to mix their own filters into the security filter chain and have some knowledge of the standard Spring Security filters. The filter names map to specific Spring Security implementation filters.
before The filter immediately before which the custom-filter should be placed in the chain
position The explicit position at which the custom-filter should be placed in the chain. Use if you are replacing a standard filter.
ref Defines a reference to a Spring bean that implements
Filter
<expression-handler>
<form-login>
Used to add an UsernamePasswordAuthenticationFilter
to the filter stack and an LoginUrlAuthenticationEntryPoint
to the application context to provide authentication on demand.
This will always take precedence over other namespace-created entry points.
If no attributes are supplied, a login page will be generated automatically at the URL "/login" [2] The behaviour can be customized using the <form-login>
Attributes.
<form-login> Attributes
always-use-default-target If set to
true
, the user will always start at the value given by default-target-url, regardless of how they arrived at the login page. Maps to thealwaysUseDefaultTargetUrl
property ofUsernamePasswordAuthenticationFilter
. Default value isfalse
authentication-details-source-ref Reference to an
AuthenticationDetailsSource
which will be used by the authentication filter
authentication-failure-handler-ref Can be used as an alternative to authentication-failure-url, giving you full control over the navigation flow after an authentication failure. The value should be the name of an
AuthenticationFailureHandler
bean in the application context.
authentication-failure-url Maps to the
authenticationFailureUrl
. Defines the URL the browser will be redirected to on login failure. Defaults to/login?error
, which will be automatically handled by the automatic login page generator, re-rendering the login page with an error message.
authentication-success-handler-ref This can be used as an alternative to default-target-url and always-use-default-target, giving you full control over the navigation flow after a successful authentication. The value should be the name of an
AuthenticationSuccessHandler
bean in the application context. By default, an implementation ofSavedRequestAwareAuthenticationSuccessHandler
is used and injected with the default-target-url .
default-target-url Maps to the
defaultTargetUrl
. If not set, the default value is "/" (the application root). A user will be taken to this URL after logging in, provided they were not asked to login while attempting to access a secured resource, when they will be taken to the originally requested URL.
login-page The URL that should be used to render the login page. Maps to the
loginFormUrl
property of theLoginUrlAuthenticationEntryPoint
. Defaults to "/login".
login-processing-url Maps to the
filterProcessesUrl
. The default value is "/login".
password-parameter The name of the request parameter which contains the password. Defaults to "password".
username-parameter The name of the request parameter which contains the username. Defaults to "username".
authentication-success-forward-url Maps a
ForwardAuthenticationSuccessHandler
toauthenticationSuccessHandler
authentication-failure-forward-url Maps a
ForwardAuthenticationFailureHandler
toauthenticationFailureHandler
<oauth2-login>
The OAuth 2.0 Login feature configures authentication support using an OAuth 2.0 and/or OpenID Connect 1.0 Provider.
<oauth2-login> Attributes
client-registration-repository-ref Reference to the
ClientRegistrationRepository
access-token-response-client-ref Reference to the
OAuth2AccessTokenResponseClient
user-service-ref Reference to the
OAuth2UserService
oidc-user-service-ref Reference to the OpenID Connect
OAuth2UserService
login-processing-url The URI where the filter processes authentication requests.
login-page The URI to send users to login.
authentication-success-handler-ref Reference to the
authentication-failure-handler-ref Reference to the
jwt-decoder-factory-ref Reference to the
JwtDecoderFactory
used byOidcAuthorizationCodeAuthenticationProvider
<oauth2-client>
Configures OAuth 2.0 Client support.
<oauth2-client> Attributes
<authorization-code-grant>
Configures OAuth 2.0 Authorization Code Grant.
<client-registrations>
A container element for client(s) registered (ClientRegistration) with an OAuth 2.0 or OpenID Connect 1.0 Provider.
<client-registration>
Represents a client registered with an OAuth 2.0 or OpenID Connect 1.0 Provider.
<client-registration> Attributes
registration-id The ID that uniquely identifies the
ClientRegistration
client-id The client identifier.
client-secret The client secret.
client-authentication-method The method used to authenticate the Client with the Provider. The supported values are client_secret_basic, client_secret_post, private_key_jwt, client_secret_jwt and none (public clients).
redirect-uri The client’s registered redirect URI that the Authorization Server redirects the end-user’s user-agent to after the end-user has authenticated and authorized access to the client.
scope The scope(s) requested by the client during the Authorization Request flow, such as openid, email, or profile.
client-name A descriptive name used for the client. The name may be used in certain scenarios, such as when displaying the name of the client in the auto-generated login page.
provider-id A reference to the associated provider. May reference a
<provider>
element or use one of the common providers (google, github, facebook, okta).
<provider>
The configuration information for an OAuth 2.0 or OpenID Connect 1.0 Provider.
<provider> Attributes
provider-id The ID that uniquely identifies the provider.
token-uri The Token Endpoint URI for the Authorization Server.
user-info-uri The UserInfo Endpoint URI used to access the claims/attributes of the authenticated end-user.
user-info-authentication-method The authentication method used when sending the access token to the UserInfo Endpoint. The supported values are header, form and query.
user-info-user-name-attribute The name of the attribute returned in the UserInfo Response that references the Name or Identifier of the end-user.
jwk-set-uri The URI used to retrieve the JSON Web Key (JWK) Set from the Authorization Server, which contains the cryptographic key(s) used to verify the JSON Web Signature (JWS) of the ID Token and optionally the UserInfo Response.
issuer-uri The URI used to initially configure a
ClientRegistration
using discovery of an OpenID Connect Provider’s Configuration endpoint or an Authorization Server’s Metadata endpoint.
<oauth2-resource-server>
Adds a BearerTokenAuthenticationFilter
, BearerTokenAuthenticationEntryPoint
, and BearerTokenAccessDeniedHandler
to the configuration.
In addition, either <jwt>
or <opaque-token>
must be specified.
<oauth2-resource-server> Attributes
authentication-manager-resolver-ref Reference to an
AuthenticationManagerResolver
which will resolve theAuthenticationManager
at request time
bearer-token-resolver-ref Reference to a
BearerTokenResolver
which will retrieve the bearer token from the request
entry-point-ref Reference to a
which will handle unauthorized requests
<jwt>
Represents an OAuth 2.0 Resource Server that will authorize JWTs
<jwt> Attributes
jwt-authentication-converter-ref Reference to a
Converter<Jwt, AbstractAuthenticationToken>
jwt-decoder-ref Reference to a
JwtDecoder
. This is a larger component that overridesjwk-set-uri
jwk-set-uri The JWK Set Uri used to load signing verification keys from an OAuth 2.0 Authorization Server
<opaque-token>
Represents an OAuth 2.0 Resource Server that will authorize opaque tokens
<opaque-token> Attributes
introspector-ref Reference to an
OpaqueTokenIntrospector
. This is a larger component that overridesintrospection-uri
,client-id
, andclient-secret
introspection-uri The Introspection Uri used to introspect the details of an opaque token. Should be accompanied with a
client-id
andclient-secret
client-id The Client Id to use for client authentication against the provided
introspection-uri
client-secret The Client Secret to use for client authentication against the provided
introspection-uri
authentication-converter-ref Reference to an
OpaqueTokenAuthenticationConverter
. Responsible for converting successful introspection result into anAuthentication
instance.
<relying-party-registrations>
The container element for relying party(ies) registered (ClientRegistration) with a SAML 2.0 Identity Provider.
<relying-party-registrations> Attributes
RelyingPartyRegistrationRepository
<relying-party-registration>
Represents a relying party registered with a SAML 2.0 Identity Provider
<relying-party-registration> Attributes
metadata-location The asserting party metadata location.
client-id The relying party’s EntityID.
assertion-consumer-service-location The AssertionConsumerService Location. Equivalent to the value found in
<AssertionConsumerService Location="…"/>
in the relying party’s<SPSSODescriptor>
assertion-consumer-service-binding the AssertionConsumerService Binding. Equivalent to the value found in
<AssertionConsumerService Binding="…"/>
. The supported values are POST and REDIRECT.
single-logout-service-location The SingleLogoutService Location. Equivalent to the value found in <SingleLogoutService Location="…"/> in the relying party’s <SPSSODescriptor>.
single-logout-service-response-location The SingleLogoutService ResponseLocation. Equivalent to the value found in <SingleLogoutService ResponseLocation="…"/> in the relying party’s <SPSSODescriptor>.
single-logout-service-binding The SingleLogoutService Binding. Equivalent to the value found in <SingleLogoutService Binding="…"/> in the relying party’s <SPSSODescriptor>. The supported values are POST and REDIRECT.
asserting-party-id A reference to the associated asserting party. Must reference an
<asserting-party>
element.
<decryption-credential>
<signing-credential>
<asserting-party>
The configuration information for a SAML 2.0 Asserting Party.
<asserting-party> Attributes
asserting-party-id The ID that uniquely identifies the asserting party.
entity-id The EntityID of the Asserting Party
want-authn-requests-signed The
WantAuthnRequestsSigned
setting, indicating the asserting party’s preference that relying parties should sign theAuthnRequest
before sending.
single-sign-on-service-location The SingleSignOnService Location.
single-sign-on-service-binding The SingleSignOnService Binding. The supported values are POST and REDIRECT.
signing-algorithms The list of
org.opensaml.saml.ext.saml2alg.SigningMethod
Algorithms for this asserting party, in preference order.
single-logout-service-location The SingleLogoutService Location. Equivalent to the value found in <SingleLogoutService Location="…"/> in the asserting party’s <IDPSSODescriptor>.
single-logout-service-response-location The SingleLogoutService ResponseLocation. Equivalent to the value found in <SingleLogoutService ResponseLocation="…"/> in the asserting party’s <IDPSSODescriptor>.
single-logout-service-binding The SingleLogoutService Binding. Equivalent to the value found in <SingleLogoutService Binding="…"/> in the asserting party’s <IDPSSODescriptor>. The supported values are POST and REDIRECT.
<encryption-credential>
<verification-credential>
<http-basic>
<http-firewall> Element
This is a top-level element which can be used to inject a custom implementation of HttpFirewall
into the FilterChainProxy
created by the namespace.
The default implementation should be suitable for most applications.
<intercept-url>
This element is used to define the set of URL patterns that the application is interested in and to configure how they should be handled.
It is used to construct the FilterInvocationSecurityMetadataSource
used by the FilterSecurityInterceptor
It is also responsible for configuring a ChannelProcessingFilter
if particular URLs need to be accessed by HTTPS, for example.
When matching the specified patterns against an incoming request, the matching is done in the order in which the elements are declared.
So the most specific patterns should come first and the most general should come last.
<intercept-url> Attributes
access Lists the access attributes which will be stored in the
for the defined URL pattern/method combination. This should be a comma-separated list of the security configuration attributes (such as role names).
method The HTTP Method which will be used in combination with the pattern and servlet path (optional) to match an incoming request. If omitted, any method will match. If an identical pattern is specified with and without a method, the method-specific match will take precedence.
pattern The pattern which defines the URL path. The content will depend on the
request-matcher
attribute from the containing http element, so will default to MVC matcher if Spring MVC is in the classpath.
RequestMatcher
that will be used to determine if this<intercept-url>
is used.
requires-channel Can be "http" or "https" depending on whether a particular URL pattern should be accessed over HTTP or HTTPS respectively. Alternatively the value "any" can be used when there is no preference. If this attribute is present on any
<intercept-url>
element, then aChannelProcessingFilter
will be added to the filter stack and its additional dependencies added to the application context.
If a <port-mappings>
configuration is added, this will be used to by the SecureChannelProcessor
and InsecureChannelProcessor
beans to determine the ports used for redirecting to HTTP/HTTPS.
This property is invalid for filter-security-metadata-source |
servlet-path The servlet path which will be used in combination with the pattern and HTTP method to match an incoming request. This attribute is only applicable when request-matcher is 'mvc'. In addition, the value is only required in the following 2 use cases: 1) There are 2 or more
HttpServlet
's registered in theServletContext
that have mappings starting with'/'
and are different; 2) The pattern starts with the same value of a registeredHttpServlet
path, excluding the default (root)HttpServlet
<jee>
<logout>
Adds a LogoutFilter
to the filter stack.
This is configured with a SecurityContextLogoutHandler
<logout> Attributes
invalidate-session Maps to the
invalidateHttpSession
of theSecurityContextLogoutHandler
. Defaults to "true", so the session will be invalidated on logout.
logout-success-url The destination URL which the user will be taken to after logging out. Defaults to <form-login-login-page>/?logout (i.e. /login?logout)
Setting this attribute will inject the
SessionManagementFilter
with aSimpleRedirectInvalidSessionStrategy
configured with the attribute value. When an invalid session ID is submitted, the strategy will be invoked, redirecting to the configured URL.
logout-url The URL which will cause a logout (i.e. which will be processed by the filter). Defaults to "/logout".
success-handler-ref May be used to supply an instance of
LogoutSuccessHandler
which will be invoked to control the navigation after logging out.
<saml2-login>
The SAML 2.0 Login feature configures authentication support using an SAML 2.0 Service Provider.
<saml2-login> Attributes
relying-party-registration-repository-ref Reference to the
authentication-request-repository-ref Reference to the
Saml2AuthenticationRequestRepository
authentication-request-context-resolver-ref Reference to the
Saml2AuthenticationRequestResolver
authentication-converter-ref Reference to the
authentication-manager-ref Reference to the
<saml2-logout>
The SAML 2.0 Single Logout feature configures support for RP- and AP-initiated SAML 2.0 Single Logout.
<saml2-logout> Attributes
logout-url The URL by which the relying or asserting party can trigger logout.
logout-request-url The URL by which the asserting party can send a SAML 2.0 Logout Request.
logout-response-url The URL by which the asserting party can send a SAML 2.0 Logout Response.
logout-request-validator-ref Reference to the
Saml2LogoutRequestValidator
logout-request-resolver-ref Reference to the
Saml2LogoutRequestResolver
logout-request-repository-ref Reference to the
Saml2LogoutRequestRepository
logout-response-validator-ref Reference to the
Saml2LogoutResponseValidator
logout-response-resolver-ref Reference to the
Saml2LogoutResponseResolver
<password-management>
<port-mappings>
By default, an instance of PortMapperImpl
will be added to the configuration for use in redirecting to secure and insecure URLs.
This element can optionally be used to override the default mappings which that class defines.
Each child <port-mapping>
element defines a pair of HTTP:HTTPS ports.
The default mappings are 80:443 and 8080:8443.
An example of overriding these can be found in Redirect to HTTPS.
<port-mapping>
<remember-me>
Adds the RememberMeAuthenticationFilter
to the stack.
This in turn will be configured with either a TokenBasedRememberMeServices
, a PersistentTokenBasedRememberMeServices
or a user-specified bean implementing RememberMeServices
depending on the attribute settings.
<remember-me> Attributes
authentication-success-handler-ref Sets the
property on theRememberMeAuthenticationFilter
if custom navigation is required. The value should be the name of aAuthenticationSuccessHandler
data-source-ref A reference to a
DataSource
bean. If this is set,PersistentTokenBasedRememberMeServices
will be used and configured with aJdbcTokenRepositoryImpl
instance.
remember-me-parameter The name of the request parameter which toggles remember-me authentication. Defaults to "remember-me". Maps to the "parameter" property of
AbstractRememberMeServices
key Maps to the "key" property of
. Should be set to a unique value to ensure that remember-me cookies are only valid within the one application [3]. If this is not set a secure random value will be generated. Since generating secure random values can take a while, setting this value explicitly can help improve startup times when using the remember-me functionality.
services-alias Exports the internally defined
RememberMeServices
as a bean alias, allowing it to be used by other beans in the application context.
services-ref Allows complete control of the
RememberMeServices
implementation that will be used by the filter. The value should be theid
of a bean in the application context which implements this interface. Should also implementLogoutHandler
if a logout filter is in use.
token-repository-ref Configures a
but allows the use of a customPersistentTokenRepository
bean.
token-validity-seconds Maps to the
tokenValiditySeconds
property ofAbstractRememberMeServices
. Specifies the period in seconds for which the remember-me cookie should be valid. By default it will be valid for 14 days.
user-service-ref The remember-me services implementations require access to a
UserDetailsService
, so there has to be one defined in the application context. If there is only one, it will be selected and used automatically by the namespace configuration. If there are multiple instances, you can specify a beanid
explicitly using this attribute.
<request-cache> Element
<session-management>
Session-management related functionality is implemented by the addition of a SessionManagementFilter
<session-management> Attributes
authentication-strategy-explicit-invocation Setting this attribute to true will mean that
will not be injected and explicit invocation of SessionAuthenticationStrategy is required.
invalid-session-url Setting this attribute will inject the
invalid-session-url Allows injection of the InvalidSessionStrategy instance used by the SessionManagementFilter. Use either this or the
invalid-session-url
attribute but not both.
session-authentication-error-url Defines the URL of the error page which should be shown when the SessionAuthenticationStrategy raises an exception. If not set, an unauthorized (401) error code will be returned to the client. Note that this attribute doesn’t apply if the error occurs during a form-based login, where the URL for authentication failure will take precedence.
session-authentication-strategy-ref Allows injection of the SessionAuthenticationStrategy instance used by the SessionManagementFilter
session-fixation-protection Indicates how session fixation protection will be applied when a user authenticates. If set to "none", no protection will be applied. "newSession" will create a new empty session, with only Spring Security-related attributes migrated. "migrateSession" will create a new session and copy all session attributes to the new session. In Servlet 3.1 (Java EE 7) and newer containers, specifying "changeSessionId" will keep the existing session and use the container-supplied session fixation protection (HttpServletRequest#changeSessionId()). Defaults to "changeSessionId" in Servlet 3.1 and newer containers, "migrateSession" in older containers. Throws an exception if "changeSessionId" is used in older containers.
If session fixation protection is enabled, the
is injected with an appropriately configuredDefaultSessionAuthenticationStrategy
. See the Javadoc for this class for more details.
<concurrency-control>
Adds support for concurrent session control, allowing limits to be placed on the number of active sessions a user can have.
A ConcurrentSessionFilter
will be created, and a ConcurrentSessionControlAuthenticationStrategy
will be used with the SessionManagementFilter
If a form-login
element has been declared, the strategy object will also be injected into the created authentication filter.
An instance of SessionRegistry
(a SessionRegistryImpl
instance unless the user wishes to use a custom bean) will be created for use by the strategy.
<concurrency-control> Attributes
error-if-maximum-exceeded If set to "true" a
SessionAuthenticationException
will be raised when a user attempts to exceed the maximum allowed number of sessions. The default behaviour is to expire the original session.
expired-url The URL a user will be redirected to if they attempt to use a session which has been "expired" by the concurrent session controller because the user has exceeded the number of allowed sessions and has logged in again elsewhere. Should be set unless
exception-if-maximum-exceeded
is set. If no value is supplied, an expiry message will just be written directly back to the response.
expired-url Allows injection of the ExpiredSessionStrategy instance used by the ConcurrentSessionFilter
max-sessions Maps to the
maximumSessions
property ofConcurrentSessionControlAuthenticationStrategy
. Specify-1
as the value to support unlimited sessions.
session-registry-alias It can also be useful to have a reference to the internal session registry for use in your own beans or an admin interface. You can expose the internal bean using the
attribute, giving it a name that you can use elsewhere in your configuration.
session-registry-ref The user can supply their own
SessionRegistry
implementation using thesession-registry-ref
attribute. The other concurrent session control beans will be wired up to use it.
<x509>
Adds support for X.509 authentication.
An X509AuthenticationFilter
will be added to the stack and an Http403ForbiddenEntryPoint
bean will be created.
The latter will only be used if no other authentication mechanisms are in use (its only functionality is to return an HTTP 403 error code).
A PreAuthenticatedAuthenticationProvider
will also be created which delegates the loading of user authorities to a UserDetailsService
<x509> Attributes
authentication-details-source-ref A reference to an
subject-principal-regex Defines a regular expression which will be used to extract the username from the certificate (for use with the
UserDetailsService
user-service-ref Allows a specific
UserDetailsService
to be used with X.509 in the case where multiple instances are configured. If not set, an attempt will be made to locate a suitable instance automatically and use that.
<filter-chain-map>
Used to explicitly configure a FilterChainProxy instance with a FilterChainMap
<filter-chain-map> Attributes
request-matcher Defines the strategy to use for matching incoming requests. Currently the options are 'ant' (for ant path patterns), 'regex' for regular expressions and 'ciRegex' for case-insensitive regular expressions.
<filter-chain>
Used within to define a specific URL pattern and the list of filters which apply to the URLs matching that pattern. When multiple filter-chain elements are assembled in a list in order to configure a FilterChainProxy, the most specific patterns must be placed at the top of the list, with most general ones at the bottom.
<filter-chain> Attributes
filters A comma separated list of references to Spring beans that implement
Filter
. The value "none" means that noFilter
should be used for thisFilterChain
pattern A pattern that creates RequestMatcher in combination with the request-matcher
RequestMatcher
that will be used to determine if anyFilter
from thefilters
attribute should be invoked.
<filter-security-metadata-source>
Used to explicitly configure a FilterSecurityMetadataSource bean for use with a FilterSecurityInterceptor. Usually only needed if you are configuring a FilterChainProxy explicitly, rather than using the<http> element. The intercept-url elements used should only contain pattern, method and access attributes. Any others will result in a configuration error.
<filter-security-metadata-source> Attributes
id A bean identifier, used for referring to the bean elsewhere in the context.
request-matcher Defines the strategy use for matching incoming requests. Currently the options are 'ant' (for ant path patterns), 'regex' for regular expressions and 'ciRegex' for case-insensitive regular expressions.
use-expressions Enables the use of expressions in the 'access' attributes in <intercept-url> elements rather than the traditional list of configuration attributes. Defaults to 'true'. If enabled, each attribute should contain a single Boolean expression. If the expression evaluates to 'true', access will be granted.
DefaultLoginPageGeneratingFilter
is responsible for rendering the login page and will provide login forms for both normal form login and/or OIDC if required.
, where the tokens are stored on the server side.
