对于最新的稳定版本,请使用 Spring Security 6.3.1! |
对于每个被拒绝的授权,都会触发一个。
此外,还可以为授予的授权触发 an。AuthorizationDeniedEvent
AuthorizationGrantedEvent
若要侦听这些事件,必须首先发布 .AuthorizationEventPublisher
Spring Security 可能会做得很好。
它使用 Spring 的 :SpringAuthorizationEventPublisher
ApplicationEventPublisher
Java
Kotlin
public AuthorizationEventPublisher authorizationEventPublisher
(ApplicationEventPublisher applicationEventPublisher) {
return new SpringAuthorizationEventPublisher(applicationEventPublisher);
fun authorizationEventPublisher
(applicationEventPublisher: ApplicationEventPublisher?): AuthorizationEventPublisher {
return SpringAuthorizationEventPublisher(applicationEventPublisher)
然后,您可以使用 Spring 的支持:@EventListener
Java
Kotlin
@Component
public class AuthenticationEvents {
@EventListener
public void onFailure(AuthorizationDeniedEvent failure) {
@Component
@EventListener
fun onFailure(failure: AuthorizationDeniedEvent?) {
授权授予事件
由于 s 可能会非常嘈杂,因此默认情况下不会发布它们。AuthorizationGrantedEvent
事实上,发布这些事件可能需要您执行一些业务逻辑,以确保您的应用程序不会被嘈杂的授权事件淹没。
您可以创建自己的事件发布者来筛选成功事件。
例如,以下发布者仅在需要时发布授权:ROLE_ADMIN
Java
Kotlin
@Component
public class MyAuthorizationEventPublisher implements AuthorizationEventPublisher {
private final ApplicationEventPublisher publisher;
private final AuthorizationEventPublisher delegate;
public MyAuthorizationEventPublisher(ApplicationEventPublisher publisher) {
this.publisher = publisher;
this.delegate = new SpringAuthorizationEventPublisher(publisher);
public <T> void publishAuthorizationEvent(Supplier<Authentication> authentication,
T object, AuthorizationDecision decision) {
if (decision == null) {
return;
if (!decision.isGranted()) {
this.delegate.publishAuthorizationEvent(authentication, object, decision);
return;
if (shouldThisEventBePublished(decision)) {
AuthorizationGrantedEvent granted = new AuthorizationGrantedEvent(
this.publisher.publishEvent(granted);
private boolean shouldThisEventBePublished(AuthorizationDecision decision) {
if (!(decision instanceof AuthorityAuthorizationDecision)) {
return false;
Collection<GrantedAuthority> authorities = ((AuthorityAuthorizationDecision) decision).getAuthorities();
for (GrantedAuthority authority : authorities) {
if ("ROLE_ADMIN".equals(authority.getAuthority())) {
return true;
return false;
@Component
class MyAuthorizationEventPublisher(val publisher: ApplicationEventPublisher,
val delegate: SpringAuthorizationEventPublisher = SpringAuthorizationEventPublisher(publisher)):
override fun <T : Any?> publishAuthorizationEvent(
authentication: Supplier<Authentication>?,
`object`: T,
decision: AuthorizationDecision?
return
if (!decision.isGranted) {
this.delegate.publishAuthorizationEvent(authentication, `object`, decision)
return
val granted = AuthorizationGrantedEvent(authentication, `object`, decision)
private fun shouldThisEventBePublished(decision: AuthorizationDecision): Boolean {
if (decision !is AuthorityAuthorizationDecision) {
return false
val authorities = decision.authorities
for (authority in authorities) {
if ("ROLE_ADMIN" == authority.authority) {
return true
return false
