LDAP Authentication
LDAP is often used by organizations as a central repository for user information and as an authentication service. It can also be used to store the role information for application users.spring-doc.cn
Spring Security’s LDAP based authentication is used by Spring Security when it is configured to accept a username/password for authentication. However, despite leveraging a username/password for authentication it does not integrate using UserDetailsService because in bind authentication the LDAP server does not return the password so the application cannot perform validation of the password.spring-doc.cn
There are many different scenarios for how an LDAP server may be configured so Spring Security’s LDAP provider is fully configurable. It uses separate strategy interfaces for authentication and role retrieval and provides default implementations which can be configured to handle a wide range of situations.spring-doc.cn
Required Dependencies
To get started, add the spring-security-ldap dependency to your project. When using Spring Boot, add the following dependencies:spring-doc.cn
Spring Security LDAP Dependencies
<dependency>
    <artifactId>spring-boot-starter-data-ldap</artifactId>
</dependency>
<dependency>
    <groupId>org.springframework.security</groupId>
    <artifactId>spring-security-ldap</artifactId>
</dependency>
depenendencies {
    implementation "org.springframework.boot:spring-boot-starter-data-ldap"
    implementation "org.springframework.security:spring-security-ldap"
Prerequisites
You should be familiar with LDAP before trying to use it with Spring Security. The following link provides a good introduction to the concepts involved and a guide to setting up a directory using the free LDAP server OpenLDAP: www.zytrax.com/books/ldap/. Some familiarity with the JNDI APIs used to access LDAP from Java may also be useful. We don’t use any third-party LDAP libraries (Mozilla, JLDAP etc.) in the LDAP provider, but extensive use is made of Spring LDAP, so some familiarity with that project may be useful if you plan on adding your own customizations.spring-doc.cn
When using LDAP authentication, it is important to ensure that you configure LDAP connection pooling properly. If you are unfamiliar with how to do this, you can refer to the Java LDAP documentation.spring-doc.cn
Setting up an Embedded LDAP Server
The first thing you will need to do is to ensure that you have an LDAP Server to point your configuration to. For simplicity, it is often best to start with an embedded LDAP Server. Spring Security supports using either:spring-doc.cn
In the samples below, we expose the following as users.ldif as a classpath resource to initialize the embedded LDAP server with the users user and admin both of which have a password of password.spring-doc.cn
users.ldif
dn: ou=groups,dc=springframework,dc=org
objectclass: top
objectclass: organizationalUnit
ou: groups
dn: ou=people,dc=springframework,dc=org
objectclass: top
ou: people
dn: uid=admin,ou=people,dc=springframework,dc=org
objectclass: top
objectclass: person
objectclass: organizationalPerson
objectclass: inetOrgPerson
cn: Rod Johnson
sn: Johnson
uid: admin
userPassword: password
dn: uid=user,ou=people,dc=springframework,dc=org
objectclass: top
objectclass: person
cn: Dianne Emu
sn: Emu
uid: user
dn: cn=user,ou=groups,dc=springframework,dc=org
objectclass: top
objectclass: groupOfNames
cn: user
member: uid=admin,ou=people,dc=springframework,dc=org
member: uid=user,ou=people,dc=springframework,dc=org
dn: cn=admin,ou=groups,dc=springframework,dc=org
objectclass: top
cn: admin
Embedded UnboundID Server
If you wish to use UnboundID, then specify the following dependencies:spring-doc.cn
UnboundID Dependencies
<dependency>
	<groupId>com.unboundid</groupId>
	<artifactId>unboundid-ldapsdk</artifactId>
	<version>4.0.14</version>
	<scope>runtime</scope>
</dependency>
depenendencies {
	runtimeOnly "com.unboundid:unboundid-ldapsdk:4.0.14"
You can then configure the Embedded LDAP Server using an EmbeddedLdapServerContextSourceFactoryBean. This will instruct Spring Security to start an in-memory LDAP server.spring-doc.cn
Embedded LDAP Server Configuration
public EmbeddedLdapServerContextSourceFactoryBean contextSourceFactoryBean() {
	return EmbeddedLdapServerContextSourceFactoryBean.fromEmbeddedLdapServer();
fun contextSourceFactoryBean(): EmbeddedLdapServerContextSourceFactoryBean {
Alternatively, you can manually configure the Embedded LDAP Server. If you choose this approach, you will be responsible for managing the lifecycle of the Embedded LDAP Server.spring-doc.cn
Explicit Embedded LDAP Server Configuration
UnboundIdContainer ldapContainer() {
	return new UnboundIdContainer("dc=springframework,dc=org",
				"classpath:users.ldif");
<b:bean class="org.springframework.security.ldap.server.UnboundIdContainer"
	c:defaultPartitionSuffix="dc=springframework,dc=org"
	c:ldif="classpath:users.ldif"/>
fun ldapContainer(): UnboundIdContainer {
    return UnboundIdContainer("dc=springframework,dc=org","classpath:users.ldif")
Embedded ApacheDS Server
Spring Security uses ApacheDS 1.x which is no longer maintained. Unfortunately, ApacheDS 2.x has only released milestone versions with no stable release. Once a stable release of ApacheDS 2.x is available, we will consider updating.spring-doc.cn
If you wish to use Apache DS, then specify the following dependencies:spring-doc.cn
ApacheDS Dependencies
<dependency>
	<groupId>org.apache.directory.server</groupId>
	<artifactId>apacheds-core</artifactId>
	<version>1.5.5</version>
</dependency>
<dependency>
	<artifactId>apacheds-server-jndi</artifactId>
</dependency>
depenendencies {
	runtimeOnly "org.apache.directory.server:apacheds-core:1.5.5"
	runtimeOnly "org.apache.directory.server:apacheds-server-jndi:1.5.5"
You can then configure the Embedded LDAP Serverspring-doc.cn
ApacheDSContainer ldapContainer() {
	return new ApacheDSContainer("dc=springframework,dc=org",
<b:bean class="org.springframework.security.ldap.server.ApacheDSContainer"
fun ldapContainer(): ApacheDSContainer {
    return ApacheDSContainer("dc=springframework,dc=org", "classpath:users.ldif")
LDAP ContextSource
Once you have an LDAP Server to point your configuration to, you need configure Spring Security to point to an LDAP server that should be used to authenticate users. This is done by creating an LDAP ContextSource, which is the equivalent of a JDBC DataSource. If you have already configured an EmbeddedLdapServerContextSourceFactoryBean, Spring Security will create an LDAP ContextSource that points to the embedded LDAP server.spring-doc.cn
LDAP Context Source with Embedded LDAP Server
	EmbeddedLdapServerContextSourceFactoryBean contextSourceFactoryBean =
	contextSourceFactoryBean.setPort(0);
	return contextSourceFactoryBean;
    val contextSourceFactoryBean = EmbeddedLdapServerContextSourceFactoryBean.fromEmbeddedLdapServer()
Alternatively, you can explicitly configure the LDAP ContextSource to connect to the supplied LDAP server.spring-doc.cn
LDAP Context Source
ContextSource contextSource(UnboundIdContainer container) {
	return new DefaultSpringSecurityContextSource("ldap://localhost:53389/dc=springframework,dc=org");
<ldap-server
	url="ldap://localhost:53389/dc=springframework,dc=org" />
fun contextSource(container: UnboundIdContainer): ContextSource {
    return DefaultSpringSecurityContextSource("ldap://localhost:53389/dc=springframework,dc=org")
Authentication
Spring Security’s LDAP support does not use the UserDetailsService because LDAP bind authentication does not allow clients to read the password or even a hashed version of the password. This means there is no way a password to be read and then authenticated by Spring Security.spring-doc.cn
For this reason, LDAP support is implemented using the LdapAuthenticator interface. The LdapAuthenticator is also responsible for retrieving any required user attributes. This is because the permissions on the attributes may depend on the type of authentication being used. For example, if binding as the user, it may be necessary to read them with the user’s own permissions.spring-doc.cn
There are two LdapAuthenticator implementations supplied with Spring Security:spring-doc.cn
Using Bind Authentication
Bind Authentication is the most common mechanism for authenticating users with LDAP. In bind authentication the users credentials (i.e. username/password) are submitted to the LDAP server which authenticates them. The advantage to using bind authentication is that the user’s secrets (i.e. password) do not need to be exposed to clients which helps to protect them from leaking.spring-doc.cn
An example of bind authentication configuration can be found below.spring-doc.cn
Bind Authentication
AuthenticationManager authenticationManager(BaseLdapPathContextSource contextSource) {
	LdapBindAuthenticationManagerFactory factory = new LdapBindAuthenticationManagerFactory(contextSource);
	factory.setUserDnPatterns("uid={0},ou=people");
	return factory.createAuthenticationManager();
<ldap-authentication-provider
	user-dn-pattern="uid={0},ou=people"/>
fun authenticationManager(contextSource: BaseLdapPathContextSource): AuthenticationManager {
    val factory = LdapBindAuthenticationManagerFactory(contextSource)
This simple example would obtain the DN for the user by substituting the user login name in the supplied pattern and attempting to bind as that user with the login password. This is OK if all your users are stored under a single node in the directory. If instead you wished to configure an LDAP search filter to locate the user, you could use the following:spring-doc.cn
Bind Authentication with Search Filter
	factory.setUserSearchFilter("(uid={0})");
	factory.setUserSearchBase("ou=people");
		user-search-filter="(uid={0})"
	user-search-base="ou=people"/>
If used with the ContextSource definition above, this would perform a search under the DN ou=people,dc=springframework,dc=org using (uid={0}) as a filter. Again the user login name is substituted for the parameter in the filter name, so it will search for an entry with the uid attribute equal to the user name. If a user search base isn’t supplied, the search will be performed from the root.spring-doc.cn
Using Password Authentication
Password comparison is when the password supplied by the user is compared with the one stored in the repository. This can either be done by retrieving the value of the password attribute and checking it locally or by performing an LDAP "compare" operation, where the supplied password is passed to the server for comparison and the real password value is never retrieved. An LDAP compare cannot be done when the password is properly hashed with a random salt.spring-doc.cn
Minimal Password Compare Configuration
	LdapPasswordComparisonAuthenticationManagerFactory factory = new LdapPasswordComparisonAuthenticationManagerFactory(
			contextSource, NoOpPasswordEncoder.getInstance());
		user-dn-pattern="uid={0},ou=people">
	<password-compare />
</ldap-authentication-provider>
fun authenticationManager(contextSource: BaseLdapPathContextSource?): AuthenticationManager? {
    val factory = LdapPasswordComparisonAuthenticationManagerFactory(
A more advanced configuration with some customizations can be found below.spring-doc.cn
			contextSource, new BCryptPasswordEncoder());
	factory.setPasswordAttribute("pwd");  (1)
	<password-compare password-attribute="pwd"> (1)
		<password-encoder ref="passwordEncoder" /> (2)
	</password-compare>
<b:bean id="passwordEncoder"
	class="org.springframework.security.crypto.bcrypt.BCryptPasswordEncoder" />
        contextSource, BCryptPasswordEncoder()
    factory.setPasswordAttribute("pwd") (1)
1 Specify the password attribute as pwd
LdapAuthoritiesPopulator
Spring Security’s LdapAuthoritiesPopulator is used to determine what authorites are returned for the user.spring-doc.cn
LdapAuthoritiesPopulator Configuration
LdapAuthoritiesPopulator authorities(BaseLdapPathContextSource contextSource) {
	String groupSearchBase = "";
	DefaultLdapAuthoritiesPopulator authorities =
		new DefaultLdapAuthoritiesPopulator(contextSource, groupSearchBase);
	authorities.setGroupSearchFilter("member={0}");
	return authorities;
AuthenticationManager authenticationManager(BaseLdapPathContextSource contextSource, LdapAuthoritiesPopulator authorities) {
	factory.setLdapAuthoritiesPopulator(authorities);
	group-search-filter="member={0}"/>
fun authorities(contextSource: BaseLdapPathContextSource): LdapAuthoritiesPopulator {
    val groupSearchBase = ""
    val authorities = DefaultLdapAuthoritiesPopulator(contextSource, groupSearchBase)
    return authorities
    contextSource: BaseLdapPathContextSource,
    authorities: LdapAuthoritiesPopulator): AuthenticationManager {
Active Directory
Active Directory supports its own non-standard authentication options, and the normal usage pattern doesn’t fit too cleanly with the standard LdapAuthenticationProvider. Typically authentication is performed using the domain username (in the form user@domain), rather than using an LDAP distinguished name. To make this easier, Spring Security has an authentication provider which is customized for a typical Active Directory setup.spring-doc.cn
Configuring ActiveDirectoryLdapAuthenticationProvider is quite straightforward. You just need to supply the domain name and an LDAP URL supplying the address of the server [1]. An example configuration can be seen below:spring-doc.cn
Example Active Directory Configuration
ActiveDirectoryLdapAuthenticationProvider authenticationProvider() {
	return new ActiveDirectoryLdapAuthenticationProvider("example.com", "ldap://company.example.com/");
<bean id="authenticationProvider"
        class="org.springframework.security.ldap.authentication.ad.ActiveDirectoryLdapAuthenticationProvider">
	<constructor-arg value="example.com" />
	<constructor-arg value="ldap://company.example.com/" />
</bean>
fun authenticationProvider(): ActiveDirectoryLdapAuthenticationProvider {
    return ActiveDirectoryLdapAuthenticationProvider("example.com", "ldap://company.example.com/")
1. It is also possible to obtain the server’s IP address using a DNS lookup. This is not currently supported, but hopefully will be in a future version.
